Gantry oxyfuel / plasma type machine from scratch
- saxa
- Thank you received: 4
24 Jul 2026 11:16 #348027
by saxa
Replied by saxa on topic Gantry oxyfuel / plasma type machine from scratch
Hi RodW, yeah, sure. I am aware of that. The idea is just to get comfortable and experiment withe the Linuxcnc functionalities, configs etc.... of course later when I get all the stuff set up then will be a dedicated computer with real hardware.
- NWE
- Thank you received: 84
24 Jul 2026 14:16 - 24 Jul 2026 20:53 #348032
by NWE
Replied by NWE on topic Gantry oxyfuel / plasma type machine from scratch
That works. I run several versions of LinuxCNC as virtual machines at once in virsh during development/testing efforts. Virtualbox is great, too, but I got to fighting it all the time on my headless server. Virsh played nicer for me in configuring virtual machines on the headless server over ssh, then I connect with those VMs using Remmina remote desktop.LinuxCNC will run on VirtualBox and so on and this is handy to do basic testing and configuration. There is a limit on what can be done on a sim without real hardware.
Last edit: 24 Jul 2026 20:53 by NWE.
The following user(s) said Thank You: saxa
- Thank you received: 4150
25 Jul 2026 03:25 #348048
Replied by rodw on topic Gantry oxyfuel / plasma type machine from scratch
QEMM on Linux is more to my taste than Virtual Box in Windows. On Linux VB kept getting in a tangle over UEFI
- Thank you received: 7488
25 Jul 2026 03:37 #348049
Replied by tommylight on topic Gantry oxyfuel / plasma type machine from scratch
QEMU?
25 Jul 2026 08:21 #348052
Dislexic
- saxa
27 Jul 2026 12:54 #348098
by saxa
The idea of starting with and virtual environment is just because i still have no dedicated machine, and to not to loose time learning and testing various GUIs to see how I will be doing the workflow of the production of the pieces , configurations and other stuff which is not really related on
testing servos and other hardware things. This will permit me to get more comfortable with the software.
27 Jul 2026 13:15 #348099
You can not test servos and other hardware from a virtual box, but you can from a live session when booting from USB.
- saxa
05 Aug 2026 16:07 - 05 Aug 2026 16:07 #348467
by saxa
Hi another question from my side is in case I have to replace the servo drives and motors, as it seems that they have lost them, which brand would be the best one to go ? Also in that case would it be worth going directly with EtherCAT type of drives ?
Last edit: 05 Aug 2026 16:07 by saxa.
06 Aug 2026 10:05 #348488
Depends on budget, good ones are from Yaskawa and Delta, all the way down to cheap china ones that do work, but getting there might be very hard as usually they are not tested or tuned to the motor you get.
I am still skipping EtherCAT due to feedback latency issues.
- saxa
06 Aug 2026 11:06 #348490
by saxa
Tommy thanks. So Yaskawa would be preferred correct ? What kind of latency issues are there with EtherCAT ? Is it on the LinuxCNC side or due to network ?
Time to create page: 0.261 seconds
