- Thank you received: 4153
RuntimeError: module compiled against ABI version 0x1000009 but this version of numpy is 0x2000000
Thanks, but I already found out.
[/code][/code][/code][/code]Code:[code][code][code][code]If you post the full traceback, I can tell you which module it is.
Works. Thanks.Did you try
Code:pipx install bcnc? That should install it in its own env, and not conflict with qtDragon at all...
