Upgrade question
- psantangeli
20 Nov 2026 20:49 #350865
by psantangeli
Upgrade question was created by psantangeli
I've been happily running LinuxCNC for 10+ years. I'm currently on 2.5 on a Celeron PC running Ubunto.
All is good, but a combination of all the recent security incidents (though the machine is NOT on the internet) and curiosity makes me wonder whether I should upgrade (which would no doubt be a reinstall at this point).
I use a Gecko540, so I worry that newer Kernels might actually be worse.
Opinions?
Opinions?
- Thank you received: 7509
20 Nov 2026 21:24 #350867
Replied by tommylight on topic Upgrade question
Short answer: no.
Long answer: PC to old so new Linux and Kernel will need more resources, and new RT kernels do not work nicely with old PC's as they might be missing drivers (outdated and removed).
If you plan to upgrade the PC, get a used "Enterprise" from HP or Dell or Lenovo or Fujitsu, usually they are very good at running LinuxCNC.
Here are some tested used PC's and the results:
forum.linuxcnc.org/18-computer/38838-har...ency-tests-used-pc-s
And some laptops, just be aware that laptops are never guarantied to work, even the same make model might not be the same.
forum.linuxcnc.org/18-computer/54369-use...mesa-ethernet-boards
Time to create page: 0.098 seconds
