5i25 and 7i78x2 support in Pncconf
- diegoroman17
I have 5i25 and 7i78 mesa cards but in Pncconf I not found support for this cards. How I can to solve this problem?thanks
- Thank you received: 5015
You can build the HAL file by hand. I prefer doing it that way and it isn't all that difficult (though it is slightly tedious)I have 5i25 and 7i78 mesa cards but in Pncconf I not found support for this cards. How I can to solve this problem?thanks
You need a list of the 7i78 pins, which can be obtained by following the instructions here:
www.linuxcnc.org/index.php/english/compo...id=49&id=21529#21540
You can then edit them into one of the sample Hostmot2 configurations.
The 7i78 is a cut-down 7i76, so you could just follow the instructions elsewhere for configuring a 7i76 in pncconf and change the names afterwards.
- diegoroman17
In the 5i25 manual in the section "supplied configurations" say that 7i78x2 is supplied for mesa is this true? In 7i78x2 say that 7i78 configuration have two pwm and gpio but 7i76 dont have pwm output and I need pwm outputs.
The PWM output may drive the spindle speed analogue output.
I could re-flash my 6i25 with the 7i78x2 firmware, but that would be slightly awkward at the moment.
PCW probably knows the answer, but might not be around at the moment.
If you open a console and type:
halrun
loadrt hostmot2
loadrt hm2_pci
exit
dmesg
Do you see any mention of PWM outputs?
- diegoroman17
- Online
- Thank you received: 5300
there no reason that a new configuration could not be made with one of the 4 STEP/DIR output
pairs sacrificed to give a couple more 5V buffered PWM outputs
- diegoroman17
- Thank you received: 2167
If someone could post the HAL pin and param names for the 7i78 that would be great.
Chris M
- Online
4 stepgens
1 PWM (for spindle analog)
1 encoder
1 sserial (expansion, theres no I/O on the 7I78 except whats listed))
so the 7i78x2 config has ths set of I/O on both connectors
freeby.mesanet.com/7i78x2.pin has the pinout
- diegoroman17
