5i25 and 7i78x2 support in Pncconf
09 Jul 2012 00:06 #21704 by andypugh
Replied by andypugh on topic Re:5i25 and 7i78x2 support in Pncconf
diegoroman17 wrote:
How I can use the buildbot?I dont understand it
I am not sure it is actually working, there seem to be issues. However.
Open a terminal window:
sudo gedit /etc/apt/sources.list.d/linuxcnc-buildbot.list
Then paste the required stanza into that file: In my case I wanted the 2.5 version for Lucid (Ubuntu 10.04) so it was
deb buildbot.linuxcnc.org/ lucid v2.5_branch-rt
deb-src buildbot.linuxcnc.org/ lucid v2.5_branch-rt
Then save the file.
Back to the terminal window:
sudo apt-get update
sudo apt-get install linuxcnc
However, I just tried it and got a proxy error for the buildbot, so it looks like it isn't working properly.
09 Jul 2012 00:15 #21705 by diegoroman17
Replied by diegoroman17 on topic Re:5i25 and 7i78x2 support in Pncconf
I think that is a general problem. I try the same and I obtain err 502 proxy server in the terminal
09 Jul 2012 00:21 #21706 by andypugh
Yes, the buildbot is not working at the moment. You can see that the links from the main page are all broken.
Hopefully Seb is aware of the problem and has the time to fix it.
09 Jul 2012 18:00 #21725 by andypugh
The buildbot is up and running. I just used it to pull down a new build of V2.5
Time to create page: 0.052 seconds
