5i25 and 7i78x2 support in Pncconf
07 Jul 2012 00:06 #21660 by cmorley
Replied by cmorley on topic Re:5i25 and 7i78x2 support in Pncconf
Ah so this just use the hostmot2/hal pi names ?
perfect that is much easier.
Thanks.
07 Jul 2012 00:15 - 07 Jul 2012 00:16 #21662 by cmorley
hmm looking at the manual it says the spindle output is like a potentiometer .
Does this still use the hostmot2/HAL PWM component?
eg.
setp hm2_5i25.0.pwmgen.00.output-type 1
setp hm2_5i25.0.pwmgen.00.scale [SPINDLE_9]OUTPUT_SCALE
net spindle-vel-cmd => hm2_5i25.0.pwmgen.00.value
net spindle-enable => hm2_5i25.0.pwmgen.00.enable
Thanks Chris
Last edit: 07 Jul 2012 00:16 by cmorley.
07 Jul 2012 00:32 #21664 by andypugh
Replied by andypugh on topic Re:5i25 and 7i78x2 support in Pncconf
I guess so. My spindle control is a PWM to a totem-pole opto and filter.
Specifically this:
docs-europe.electrocomponents.com/webdoc...0900766b80f8ba5d.pdf
and a resistor and capacitor.
Because it is a totem-pole output it drives both ways, so actively discharges the cap at 0 input current, and charges it at 10mA input current.
So, it will take a 5V logic PWM and create a scaled version of pretty much any voltage you apply to pins 6 and 4
07 Jul 2012 02:22 - 07 Jul 2012 02:25 #21665 by PCW
Replied by PCW on topic Re:5i25 and 7i78x2 support in Pncconf
Yes its just stock HM2 so the spindle analog out is just a standard mode 1
PWMGEN though it wants about 5KHz for best linearity/ripple compromise
It does have an expansion sserial port so anything can go there
Last edit: 07 Jul 2012 02:25 by PCW. Reason: sp/missing
07 Jul 2012 02:25 #21666 by cmorley
Thanks Peter!
07 Jul 2012 17:16 #21675 by diegoroman17
Replied by diegoroman17 on topic Re:5i25 and 7i78x2 support in Pncconf
cmorley in you thread 5i25_xml file to Pncconf you post 5i25 and 7i76/7i77 xml files. Is posible create xml files to 7i78?
07 Jul 2012 17:51 #21676 by diegoroman17
oh I see cmorley you have created 7i78xml file. thanks :)
07 Jul 2012 18:00 #21677 by cmorley
I didn't announce it to you because you need the bug fixed version of pncconf to use it properly.
The buildbot is still not up yet (the easiest way to get the latest version)
But it can't hurt to try it. It probably will work fine if you don't want the serial ports for anything.
07 Jul 2012 18:13 #21679 by cmorley
hey the buildbot may be working now...buildbot.linuxcnc.org/
08 Jul 2012 23:54 #21703 by diegoroman17
How I can use the buildbot?I dont understand it
