5i25, 7i77 problem
09 Oct 2012 15:11 #25168 by jlviloria
5i25, 7i77 problem was created by jlviloria
hello.
well first thanks for all the help you have given me, is that sometimes i ask such trivial things.
Now I have a problem, I do not move the jumper and try to feed the 5 volts the board "7i77" but the W5 jumpers (jumpers that manufactures) and the board jumper W2 "5i25" (I have not moved the jumpers that comes by default in any of the two cards) I burned both jumpers.
Now the question is, is damaged?
what would be the correct way to feed the 5volts the board "7i77"
thank you very much.
Jorge
09 Oct 2012 15:42 #25171 by PCW
Replied by PCW on topic Re:5i25, 7i77 problem
Please please read the 5I25 and 7I77 manuals before applying power and set the jumpers appropriately
If you want to supply external 5V power to the 7I77 you should set 5I25 jumper W3 down (no cable power)
and 7I77 W5 to the right hand position
The 5I25 and 7I77 have PTC protection on the 5V power but there is no protection
if the 7I77 is jumpered for cable power and the 5I25 for no cable power
09 Oct 2012 15:53 #25173 by jlviloria
Replied by jlviloria on topic Re:5i25, 7i77 problem
thanks peter.
Now I solved my problem is in the interpretation of the English, I am just a 20% knowledge of English, and thank God it worked.
Now if testing ....
Friend I also buy the 7i64, with cable.
I need to connect it to remove the connector TB6 and connect the cable coming from the 7i64?
thanks ...!
09 Oct 2012 19:49 #25181 by PCW
If you have the cable yes, remove the connector on the
7I77s TB6 and install the 7I64 cable there
If you do not have the cable, there are instructions in
the 7I77 manual for making one
09 Oct 2012 20:53 #25183 by jlviloria
Thanks peter ...
Already did. now if.
Peter, although I have a question regarding ENAX-and ENAX +, no where in my drive siemens connect?
Could you tell me one more time please.
thanks for all your cooperation.
09 Oct 2012 21:13 #25186 by PCW
Do you have a link to the drive manual?
09 Oct 2012 21:50 #25187 by emad_ahmed2
Replied by emad_ahmed2 on topic Re:5i25, 7i77 problem
sory this my first time to use linux and need somone to help me to run 5i25+7i77
09 Oct 2012 21:53 #25188 by BigJohnT
Replied by BigJohnT on topic Re:5i25, 7i77 problem
Please start a new thread, it's not polite to hijack a thread.
09 Oct 2012 23:10 #25192 by jlviloria
john greetings,
I connect in ENAX-and ENAX +? You use siemens drives also can help me.
I'm using a table "5i25" + "7i77" + "7i64"
Else friend, Rick (LAIR82) that I can not square the spindle motor of your machine because it was DC, how complicated is squaring these types of engines?
Reliance maxpak plus 50hp.
09 Oct 2012 23:49 #25193 by BigJohnT
jlviloria wrote:
john greetings,
I have one Siemens drive in my CHNC and I made connections to velocity input and enable to make it run.
I don't understand what you mean my "squaring these types of engines"... by engines do you mean servos? I don't have a clue what you mean my squaring.
Time to create page: 0.127 seconds
