5i25 with Probotix Bob
- Thank you received: 5203
12 Mar 2013 02:42 - 12 Mar 2013 02:46 #31249
Replied by PCW on topic 5i25 with Probotix Bob
The 7I76 uses 2 power sources
1. 5VDC this can come from the 5I25 (left top yellow LED is 5V indicator)
2. Field power 8-32VDC. This is supplied to 7I76 TB1 (right top yellow LED is indicator)
Last edit: 12 Mar 2013 02:46 by PCW.
- 1Mustang
- Visitor
12 Mar 2013 02:49 #31250
by 1Mustang
Replied by 1Mustang on topic 5i25 with Probotix Bob
As i posted before there are no lite lights on the 5i25
12 Mar 2013 02:50 #31251
And thats a good sign!
The LEDS I mentioned are on the 7I76
- 1Mustang
- Visitor
12 Mar 2013 02:57 #31253
by 1Mustang
Thanx for the help guys.
No lights on the 7i76.....and yes the cable is attached
- Thank you received: 4966
12 Mar 2013 03:00 #31254
Replied by andypugh on topic 5i25 with Probotix Bob
W2 to the left?No lights on the 7i76.....and yes the cable is attached
- 1Mustang
- Visitor
12 Mar 2013 03:01 #31255
by 1Mustang
W1 is to the left and yes W2 is to the left
- 1Mustang
- Visitor
12 Mar 2013 03:15 #31256
by 1Mustang
A quick test from Multi meter. I measured the traces under the Parallel tabs on the 7i76....some Volt measured .19-.20 to full 5V.
No traces of power under W2 or anywhere else on the board for that matter
12 Mar 2013 03:21 #31257
This probably means the 5I25 is not jumpered to supply 5V power to the 7i76
Please read the BREAKOUT POWER OPTION section of the 5I25 manual
- 1Mustang
- Visitor
12 Mar 2013 03:31 #31258
by 1Mustang
I ordered these from Mesa as a Combo package, Under their plug and go Kit...in there manual they even say its setup.
12 Mar 2013 03:40 - 12 Mar 2013 03:41 #31259
The 5i25 manual states that the cable power option default setting is 'disabled'
Last edit: 12 Mar 2013 03:41 by PCW.
Time to create page: 0.092 seconds
