5i25 with Probotix Bob
  • 1Mustang
  • 1Mustang's Avatar Topic Author
  • Visitor
  • Visitor
12 Mar 2013 03:53 #31260 by 1Mustang
Replied by 1Mustang on topic 5i25 with Probotix Bob
You are right...i have moved the 5i25 W1 (P2 power) to the up position....and still nothing
12 Mar 2013 04:18 #31262 by PCW
Replied by PCW on topic 5i25 with Probotix Bob
the 7I76 is most likely connected to P3
  • 1Mustang
  • Visitor
  • Visitor
12 Mar 2013 04:38 #31263 by 1Mustang
OMG yer awesome...W1 back to default....moved W2 to enable and now after 4 hours i get a goofy yellow light on upper left on the 7i76.
So now it'd probably take 100+hrs to get Linuxcnc to use the setup lol
12 Mar 2013 04:45 #31264 by andypugh
Replied by andypugh on topic 5i25 with Probotix Bob
Apply field power and you can have _two_ yellow lights.
12 Mar 2013 04:51 #31265 by BigJohnT
  • 1Mustang
  • Visitor
  • Visitor
08 Apr 2013 02:52 #32397 by 1Mustang
The 7i76 I/O needs 8 - 32vdc field power connected to TB1 Pins 1(+) and 8(0vdc) to work.
Was wondering at what amperage is suggested, i'am just trying to set up the limit/home switches as well as the E-Stop
08 Apr 2013 04:05 #32400 by PCW
The card itself needs about 40 mA with 12V field power (and 20 mA at 24V)
You need to add any output and input loads to this
(input loads are ~0.6 ma each at 12V or ~1.2 mA each at 24V)
  • 1Mustang
  • Visitor
  • Visitor
08 Apr 2013 04:33 #32402 by 1Mustang
So 6 limit/homing switches and 1 E-stop and the card would be around ~~ 5-6amps plus at 12 volts. maybe i can find a Wall wart, safe to assume its DC the 7i76 takes?.
08 Apr 2013 04:37 - 08 Apr 2013 04:51 #32403 by PCW
No, around 44 mA (40 mA + 7 inputs x 0.6 mA)
This 0.044 Amps
And yes, DC
Last edit: 08 Apr 2013 04:51 by PCW.
  • 1Mustang
  • Visitor
  • Visitor
08 Apr 2013 04:50 #32404 by 1Mustang
Ooh ok micro amps. thanks again :). Does others use a WalWart?.
Time to create page: 0.092 seconds
