- Configuring LinuxCNC
- Configuration Tools
- PnCConf Wizard
- Something funny with my .hal created in pncconf
- Thank you received: 5298
15 Oct 2013 23:03 #39887
Replied by PCW on topic Something funny with my .hal created in pncconf
can you do this is a terminal window:
sudo dmesg -c
halrun
halcmd: loadrt hostmot2
halcmd: loadrt hm2_pci
halcmd: exit
dmesg >hm2.txt
and then paste hm2.txt here
sudo dmesg -c
halrun
halcmd: exit
dmesg >hm2.txt
- macona
15 Oct 2013 23:09 #39889
by macona
Replied by macona on topic Something funny with my .hal created in pncconf
Ill give that a try tonight when I get home from work.
- macona
16 Oct 2013 12:07 #39937
by macona
I checked power, 4.99v on the jumper coming in from the computer. I also checked the dspic and I am getting 3.3v on Vdd. I am starting to think there is something wrong with my 7i76.
Here is the text from running the terminal commands:
[50533.592139] I-pipe: Domain RTAI registered.
[50533.592163] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[50533.592170] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[50533.592188] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[50533.592195] PIPELINE layers:
[50533.592203] e1135e20 9ac15d93 RTAI 200
[50533.592210] c085cb20 0 Linux 100
[50533.722413] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[50533.722929] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[50533.722945] RTAI[sched]: hard timer type/freq = APIC/8352287(Hz); default timing: periodic; linear timed lists.
[50533.722955] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 935522000 hz.
[50533.722963] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[50533.723217] RTAI[usi]: enabled.
[50534.011074] RTAI[math]: loaded.
[50542.807383] hm2: loading Mesa HostMot2 driver version 0.15
[50558.830323] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[50558.830406] hm2_pci 0000:00:12.0: found PCI INT A -> IRQ 11
[50558.830432] hm2_pci 0000:00:12.0: sharing IRQ 11 with 0000:00:07.2
[50558.830470] hm2_pci: discovered 5i25 at 0000:00:12.0
[50558.830537] hm2: no firmware specified in config modparam! the board had better have firmware configured already, or this won't work
[50558.830970] hm2/hm2_5i25.0: Smart Serial Firmware Version 38
[50558.913674] hm2/hm2_5i25.0: 34 I/O Pins used:
[50558.913691] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[50558.913702] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[50558.913712] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[50558.913722] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[50558.913732] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[50558.913742] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[50558.913752] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
[50558.913762] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
[50558.913772] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
[50558.913782] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
[50558.913791] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[50558.913799] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[50558.913807] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[50558.913815] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[50558.913824] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[50558.913834] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[50558.913844] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[50558.913854] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #5, pin Direction (Output)
[50558.913864] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #5, pin Step (Output)
[50558.913874] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #6, pin Direction (Output)
[50558.913884] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #6, pin Step (Output)
[50558.913894] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #7, pin Direction (Output)
[50558.913905] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #7, pin Step (Output)
[50558.913915] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #8, pin Direction (Output)
[50558.913925] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #8, pin Step (Output)
[50558.913935] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #9, pin Direction (Output)
[50558.913945] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #9, pin Step (Output)
[50558.913953] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[50558.913962] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[50558.913970] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[50558.913978] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[50558.913987] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Encoder #1, pin Index (Input)
[50558.913997] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Encoder #1, pin B (Input)
[50558.914006] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Encoder #1, pin A (Input)
[50558.914213] hm2/hm2_5i25.0: registered
[50558.914221] hm2_5i25.0: initialized AnyIO board at 0000:00:12.0
[50578.494428] hm2_5i25.0: dropping AnyIO board at 0000:00:12.0
[50578.494450] hm2/hm2_5i25.0: unregistered
[50578.496553] hm2_pci: driver unloaded
[50578.510384] hm2: unloading
[50578.605142] RTAI[math]: unloaded.
[50578.744909] SCHED releases registered named ALIEN RTGLBH
[50578.758865] RTAI[malloc]: unloaded.
[50578.858195] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[50578.867159] I-pipe: Domain RTAI unregistered.
[50578.867184] RTAI[hal]: unmounted.
- cncbasher
- Thank you received: 288
16 Oct 2013 15:01 #39939
by cncbasher
Replied by cncbasher on topic Something funny with my .hal created in pncconf
are you powering the encoder from the same 5v , i'll bet your loading the 5v rail to much or the pc power supply is dragging down ,
this is just about the same problem i had mentioned earlier , what else are you supplying the 5v to , limits , encoders etc , it may be these
try swapping the pc power supply for one thats higher rated at least 400w or more
- macona
16 Oct 2013 15:05 #39940
by macona
Again, there is nothing connected to the board, no drives, no encoders, nothing. Just the two boards on a piece of din rail on the table. With or without the 7i69 it makes no difference in the above results.
5v rail is 4.99v.
5v rail is 4.99v.
- cncbasher
16 Oct 2013 15:31 #39942
by cncbasher
ok try another pc power supply , it's no good just checking voltages once it's powered up , it's either delaying the 5v on power up or fluctuating on power up .
also can you confirm your jumper positions on the 5i25 and the 7i76 .
- Thank you received: 5015
16 Oct 2013 17:14 - 16 Oct 2013 17:18 #39948
Thanks for that. I think we are going to need to persuade it to give us a bit more detail.
Can you open _two_ terminal windows?
In terminal 1:
then in terminal 2: (this turns on maximum-level debugging)
then in terminal 1: (the same as before, basically, but with even more debugging)
And put the hm2.txt into a reply.
Replied by andypugh on topic Something funny with my .hal created in pncconf
In terminal 1:
sudo dmesg -c
halrun
echo 5 > /proc/rtapi/debug
loadrt hostmot2 debug_idrom=1 debug_module_descriptors=1 debug_pin_descriptors=1 debug_modules=1
loadrt hm2_pci
exit
dmesg >hm2.txt
Last edit: 16 Oct 2013 17:18 by andypugh.
- macona
16 Oct 2013 21:31 #39964
by macona
Here you go:
[86376.525396] I-pipe: Domain RTAI registered.
[86376.525417] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[86376.525424] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[86376.525439] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[86376.525446] PIPELINE layers:
[86376.525454] e0a4ce20 9ac15d93 RTAI 200
[86376.525461] c085cb20 0 Linux 100
[86376.606386] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[86376.606893] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[86376.606911] RTAI[sched]: hard timer type/freq = APIC/8352287(Hz); default timing: periodic; linear timed lists.
[86376.606921] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 935522000 hz.
[86376.606929] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[86376.607169] RTAI[usi]: enabled.
[86376.840235] RTAI[math]: loaded.
[86405.957721] hm2: loading Mesa HostMot2 driver version 0.15
[86405.957737] HAL: initializing component 'hostmot2'
[86405.957745] RTAPI: initing module HAL_hostmot2
[86405.957756] RTAPI: module 'HAL_hostmot2' loaded, ID: 4
[86405.957766] HAL: component 'hostmot2' initialized, ID = 04
[86423.212943] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[86423.212960] HAL: initializing component 'hm2_pci'
[86423.212969] RTAPI: initing module HAL_hm2_pci
[86423.212979] RTAPI: module 'HAL_hm2_pci' loaded, ID: 5
[86423.212990] HAL: component 'hm2_pci' initialized, ID = 05
[86423.213073] hm2_pci 0000:00:12.0: found PCI INT A -> IRQ 11
[86423.213100] hm2_pci 0000:00:12.0: sharing IRQ 11 with 0000:00:07.2
[86423.213139] hm2_pci: discovered 5i25 at 0000:00:12.0
[86423.213201] hm2: no firmware specified in config modparam! the board had better have firmware configured already, or this won't work
[86423.213220] HAL: creating parameter 'hm2_5i25.0.io_error'
[86423.213245] hm2/hm2_5i25.0: IDRom:
[86423.213252] hm2/hm2_5i25.0: IDRom Type: 0x00000003
[86423.213259] hm2/hm2_5i25.0: Offset to Modules: 0x00000040
[86423.213267] hm2/hm2_5i25.0: Offset to Pin Description: 0x000001C0
[86423.213275] hm2/hm2_5i25.0: Board Name: MESA5I25
[86423.213282] hm2/hm2_5i25.0: FPGA Size: 9
[86423.213289] hm2/hm2_5i25.0: FPGA Pins: 144
[86423.213296] hm2/hm2_5i25.0: Port Width: 17
[86423.213303] hm2/hm2_5i25.0: IO Ports: 2
[86423.213309] hm2/hm2_5i25.0: IO Width: 34
[86423.213318] hm2/hm2_5i25.0: Clock Low: 33333333 Hz (33333 KHz, 33 MHz)
[86423.213327] hm2/hm2_5i25.0: Clock High: 200000000 Hz (200000 KHz, 200 MHz)
[86423.213336] hm2/hm2_5i25.0: Instance Stride 0: 0x00000004
[86423.213343] hm2/hm2_5i25.0: Instance Stride 1: 0x00000040
[86423.213351] hm2/hm2_5i25.0: Register Stride 0: 0x00000100
[86423.213359] hm2/hm2_5i25.0: Register Stride 1: 0x00000100
[86423.213387] hm2/hm2_5i25.0: 34 HM2 Pin Descriptors:
[86423.213394] hm2/hm2_5i25.0: pin 0:
[86423.213402] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213410] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.213418] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.213427] hm2/hm2_5i25.0: Secondary Pin: 0x82 (Direction, Output)
[86423.213435] hm2/hm2_5i25.0: pin 1:
[86423.213442] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213449] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.213457] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.213465] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Step, Output)
[86423.213472] hm2/hm2_5i25.0: pin 2:
[86423.213479] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213487] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.213494] hm2/hm2_5i25.0: Secondary Unit: 0x01
[86423.213502] hm2/hm2_5i25.0: Secondary Pin: 0x82 (Direction, Output)
[86423.213510] hm2/hm2_5i25.0: pin 3:
[86423.213517] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213525] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.213532] hm2/hm2_5i25.0: Secondary Unit: 0x01
[86423.213540] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Step, Output)
[86423.213547] hm2/hm2_5i25.0: pin 4:
[86423.213554] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213562] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.213569] hm2/hm2_5i25.0: Secondary Unit: 0x02
[86423.213577] hm2/hm2_5i25.0: Secondary Pin: 0x82 (Direction, Output)
[86423.213585] hm2/hm2_5i25.0: pin 5:
[86423.213592] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213600] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.213607] hm2/hm2_5i25.0: Secondary Unit: 0x02
[86423.213615] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Step, Output)
[86423.213622] hm2/hm2_5i25.0: pin 6:
[86423.213629] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213637] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.213645] hm2/hm2_5i25.0: Secondary Unit: 0x03
[86423.213653] hm2/hm2_5i25.0: Secondary Pin: 0x82 (Direction, Output)
[86423.213660] hm2/hm2_5i25.0: pin 7:
[86423.213667] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213675] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.213682] hm2/hm2_5i25.0: Secondary Unit: 0x03
[86423.213690] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Step, Output)
[86423.213697] hm2/hm2_5i25.0: pin 8:
[86423.213704] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213712] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.213720] hm2/hm2_5i25.0: Secondary Unit: 0x04
[86423.213728] hm2/hm2_5i25.0: Secondary Pin: 0x82 (Direction, Output)
[86423.213735] hm2/hm2_5i25.0: pin 9:
[86423.213742] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213750] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.213809] hm2/hm2_5i25.0: Secondary Unit: 0x04
[86423.213818] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Step, Output)
[86423.213825] hm2/hm2_5i25.0: pin 10:
[86423.213833] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213841] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[86423.213849] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.213858] hm2/hm2_5i25.0: Secondary Pin: 0x81 (TxData0, Output)
[86423.213865] hm2/hm2_5i25.0: pin 11:
[86423.213872] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213881] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[86423.213889] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.213897] hm2/hm2_5i25.0: Secondary Pin: 0x01 (RxData0, Input)
[86423.213905] hm2/hm2_5i25.0: pin 12:
[86423.213912] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213920] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[86423.213928] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.213936] hm2/hm2_5i25.0: Secondary Pin: 0x82 (TxData1, Output)
[86423.213944] hm2/hm2_5i25.0: pin 13:
[86423.213951] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213959] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[86423.213967] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.213975] hm2/hm2_5i25.0: Secondary Pin: 0x02 (RxData1, Input)
[86423.213983] hm2/hm2_5i25.0: pin 14:
[86423.213990] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.213998] hm2/hm2_5i25.0: Secondary Tag: 0x04 (Encoder)
[86423.214005] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.214014] hm2/hm2_5i25.0: Secondary Pin: 0x03 (Index, Input)
[86423.214021] hm2/hm2_5i25.0: pin 15:
[86423.214028] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214036] hm2/hm2_5i25.0: Secondary Tag: 0x04 (Encoder)
[86423.214044] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.214052] hm2/hm2_5i25.0: Secondary Pin: 0x02 (B, Input)
[86423.214059] hm2/hm2_5i25.0: pin 16:
[86423.214066] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214074] hm2/hm2_5i25.0: Secondary Tag: 0x04 (Encoder)
[86423.214081] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.214089] hm2/hm2_5i25.0: Secondary Pin: 0x01 (A, Input)
[86423.214108] hm2/hm2_5i25.0: pin 17:
[86423.214115] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214123] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.214131] hm2/hm2_5i25.0: Secondary Unit: 0x05
[86423.214139] hm2/hm2_5i25.0: Secondary Pin: 0x82 (Direction, Output)
[86423.214147] hm2/hm2_5i25.0: pin 18:
[86423.214154] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214162] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.214169] hm2/hm2_5i25.0: Secondary Unit: 0x05
[86423.214177] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Step, Output)
[86423.214184] hm2/hm2_5i25.0: pin 19:
[86423.214192] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214199] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.214207] hm2/hm2_5i25.0: Secondary Unit: 0x06
[86423.214215] hm2/hm2_5i25.0: Secondary Pin: 0x82 (Direction, Output)
[86423.214223] hm2/hm2_5i25.0: pin 20:
[86423.214230] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214238] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.214245] hm2/hm2_5i25.0: Secondary Unit: 0x06
[86423.214253] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Step, Output)
[86423.214261] hm2/hm2_5i25.0: pin 21:
[86423.214268] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214276] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.214283] hm2/hm2_5i25.0: Secondary Unit: 0x07
[86423.214291] hm2/hm2_5i25.0: Secondary Pin: 0x82 (Direction, Output)
[86423.214299] hm2/hm2_5i25.0: pin 22:
[86423.214306] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214314] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.214321] hm2/hm2_5i25.0: Secondary Unit: 0x07
[86423.214329] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Step, Output)
[86423.214337] hm2/hm2_5i25.0: pin 23:
[86423.214344] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214352] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.214359] hm2/hm2_5i25.0: Secondary Unit: 0x08
[86423.214367] hm2/hm2_5i25.0: Secondary Pin: 0x82 (Direction, Output)
[86423.214375] hm2/hm2_5i25.0: pin 24:
[86423.214382] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214390] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.214398] hm2/hm2_5i25.0: Secondary Unit: 0x08
[86423.214406] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Step, Output)
[86423.214413] hm2/hm2_5i25.0: pin 25:
[86423.214420] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214428] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.214436] hm2/hm2_5i25.0: Secondary Unit: 0x09
[86423.214444] hm2/hm2_5i25.0: Secondary Pin: 0x82 (Direction, Output)
[86423.214451] hm2/hm2_5i25.0: pin 26:
[86423.214458] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214466] hm2/hm2_5i25.0: Secondary Tag: 0x05 (StepGen)
[86423.214474] hm2/hm2_5i25.0: Secondary Unit: 0x09
[86423.214482] hm2/hm2_5i25.0: Secondary Pin: 0x81 (Step, Output)
[86423.214489] hm2/hm2_5i25.0: pin 27:
[86423.214496] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214504] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[86423.214513] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.214521] hm2/hm2_5i25.0: Secondary Pin: 0x83 (TxData2, Output)
[86423.214528] hm2/hm2_5i25.0: pin 28:
[86423.214535] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214544] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[86423.214552] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.214560] hm2/hm2_5i25.0: Secondary Pin: 0x03 (RxData2, Input)
[86423.214567] hm2/hm2_5i25.0: pin 29:
[86423.214574] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214583] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[86423.214591] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.214599] hm2/hm2_5i25.0: Secondary Pin: 0x84 (TxData3, Output)
[86423.214606] hm2/hm2_5i25.0: pin 30:
[86423.214613] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214622] hm2/hm2_5i25.0: Secondary Tag: 0xC1 (Smart Serial Interface)
[86423.214630] hm2/hm2_5i25.0: Secondary Unit: 0x00
[86423.214638] hm2/hm2_5i25.0: Secondary Pin: 0x04 (RxData3, Input)
[86423.214645] hm2/hm2_5i25.0: pin 31:
[86423.214652] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214660] hm2/hm2_5i25.0: Secondary Tag: 0x04 (Encoder)
[86423.214668] hm2/hm2_5i25.0: Secondary Unit: 0x01
[86423.214676] hm2/hm2_5i25.0: Secondary Pin: 0x03 (Index, Input)
[86423.214683] hm2/hm2_5i25.0: pin 32:
[86423.214690] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214698] hm2/hm2_5i25.0: Secondary Tag: 0x04 (Encoder)
[86423.214706] hm2/hm2_5i25.0: Secondary Unit: 0x01
[86423.214714] hm2/hm2_5i25.0: Secondary Pin: 0x02 (B, Input)
[86423.214721] hm2/hm2_5i25.0: pin 33:
[86423.214728] hm2/hm2_5i25.0: Primary Tag: 0x03 (IOPort)
[86423.214736] hm2/hm2_5i25.0: Secondary Tag: 0x04 (Encoder)
[86423.214743] hm2/hm2_5i25.0: Secondary Unit: 0x01
[86423.214804] hm2/hm2_5i25.0: Secondary Pin: 0x01 (A, Input)
[86423.214817] hm2/hm2_5i25.0: Module Descriptor 0 at 0x0440:
[86423.214825] hm2/hm2_5i25.0: General Function Tag: 2 (Watchdog)
[86423.214833] hm2/hm2_5i25.0: Version: 0
[86423.214842] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[86423.214849] hm2/hm2_5i25.0: Instances: 1
[86423.214856] hm2/hm2_5i25.0: Base Address: 0x0C00
[86423.214863] hm2/hm2_5i25.0: -- Num Registers: 3
[86423.214871] hm2/hm2_5i25.0: Register Stride: 0x00000100
[86423.214879] hm2/hm2_5i25.0: -- Instance Stride: 0x00000004
[86423.214887] hm2/hm2_5i25.0: -- Multiple Registers: 0x00000000
[86423.214896] hm2/hm2_5i25.0: Module Descriptor 1 at 0x044C:
[86423.214904] hm2/hm2_5i25.0: General Function Tag: 3 (IOPort)
[86423.214911] hm2/hm2_5i25.0: Version: 0
[86423.214919] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[86423.214926] hm2/hm2_5i25.0: Instances: 2
[86423.214933] hm2/hm2_5i25.0: Base Address: 0x1000
[86423.214940] hm2/hm2_5i25.0: -- Num Registers: 5
[86423.214948] hm2/hm2_5i25.0: Register Stride: 0x00000100
[86423.214955] hm2/hm2_5i25.0: -- Instance Stride: 0x00000004
[86423.214963] hm2/hm2_5i25.0: -- Multiple Registers: 0x0000001F
[86423.214972] hm2/hm2_5i25.0: Module Descriptor 2 at 0x0458:
[86423.214980] hm2/hm2_5i25.0: General Function Tag: 4 (Encoder)
[86423.214987] hm2/hm2_5i25.0: Version: 2
[86423.214996] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[86423.215002] hm2/hm2_5i25.0: Instances: 2
[86423.215010] hm2/hm2_5i25.0: Base Address: 0x3000
[86423.215017] hm2/hm2_5i25.0: -- Num Registers: 5
[86423.215024] hm2/hm2_5i25.0: Register Stride: 0x00000100
[86423.215032] hm2/hm2_5i25.0: -- Instance Stride: 0x00000004
[86423.215039] hm2/hm2_5i25.0: -- Multiple Registers: 0x00000003
[86423.215049] hm2/hm2_5i25.0: Module Descriptor 3 at 0x0464:
[86423.215058] hm2/hm2_5i25.0: General Function Tag: 193 (Smart Serial Interface)
[86423.215065] hm2/hm2_5i25.0: Version: 0
[86423.215074] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[86423.215081] hm2/hm2_5i25.0: Instances: 1
[86423.215088] hm2/hm2_5i25.0: Base Address: 0x5A00
[86423.215095] hm2/hm2_5i25.0: -- Num Registers: 6
[86423.215102] hm2/hm2_5i25.0: Register Stride: 0x00000100
[86423.215110] hm2/hm2_5i25.0: -- Instance Stride: 0x00000040
[86423.215118] hm2/hm2_5i25.0: -- Multiple Registers: 0x0000003C
[86423.215127] hm2/hm2_5i25.0: Module Descriptor 4 at 0x0470:
[86423.215134] hm2/hm2_5i25.0: General Function Tag: 5 (StepGen)
[86423.215142] hm2/hm2_5i25.0: Version: 2
[86423.215150] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[86423.215157] hm2/hm2_5i25.0: Instances: 10
[86423.215164] hm2/hm2_5i25.0: Base Address: 0x2000
[86423.215171] hm2/hm2_5i25.0: -- Num Registers: 10
[86423.215179] hm2/hm2_5i25.0: Register Stride: 0x00000100
[86423.215186] hm2/hm2_5i25.0: -- Instance Stride: 0x00000004
[86423.215194] hm2/hm2_5i25.0: -- Multiple Registers: 0x000001FF
[86423.215204] hm2/hm2_5i25.0: Module Descriptor 5 at 0x047C:
[86423.215212] hm2/hm2_5i25.0: General Function Tag: 128 (LED)
[86423.215219] hm2/hm2_5i25.0: Version: 0
[86423.215227] hm2/hm2_5i25.0: Clock Tag: 1 (33.333 MHz)
[86423.215234] hm2/hm2_5i25.0: Instances: 1
[86423.215241] hm2/hm2_5i25.0: Base Address: 0x0200
[86423.215248] hm2/hm2_5i25.0: -- Num Registers: 1
[86423.215256] hm2/hm2_5i25.0: Register Stride: 0x00000100
[86423.215263] hm2/hm2_5i25.0: -- Instance Stride: 0x00000004
[86423.215271] hm2/hm2_5i25.0: -- Multiple Registers: 0x00000000
[86423.228005] hm2/hm2_5i25.0: MD 1: 2x IOPort v0: accepted, using 2
[86423.228028] HAL: creating pin 'hm2_5i25.0.watchdog.has_bit'
[86423.228040] HAL: creating parameter 'hm2_5i25.0.watchdog.timeout_ns'
[86423.228052] HAL: exporting function 'hm2_5i25.0.pet_watchdog'
[86423.228062] HAL: creating parameter 'hm2_5i25.0.pet_watchdog.time'
[86423.228072] HAL: creating parameter 'hm2_5i25.0.pet_watchdog.tmax'
[86423.228083] hm2/hm2_5i25.0: MD 0: 1x Watchdog v0: accepted, using 1
[86423.228091] hm2/hm2_5i25.0: MD 1: 2x IOPort v0: ignored
[86423.228103] HAL: creating pin 'hm2_5i25.0.encoder.00.rawcounts'
[86423.228114] HAL: creating pin 'hm2_5i25.0.encoder.00.rawlatch'
[86423.228123] HAL: creating pin 'hm2_5i25.0.encoder.00.count'
[86423.228133] HAL: creating pin 'hm2_5i25.0.encoder.00.count-latched'
[86423.228143] HAL: creating pin 'hm2_5i25.0.encoder.00.position'
[86423.228154] HAL: creating pin 'hm2_5i25.0.encoder.00.position-latched'
[86423.228165] HAL: creating pin 'hm2_5i25.0.encoder.00.velocity'
[86423.228177] HAL: creating pin 'hm2_5i25.0.encoder.00.reset'
[86423.228188] HAL: creating pin 'hm2_5i25.0.encoder.00.index-enable'
[86423.228199] HAL: creating pin 'hm2_5i25.0.encoder.00.latch-enable'
[86423.228210] HAL: creating pin 'hm2_5i25.0.encoder.00.latch-polarity'
[86423.228221] HAL: creating parameter 'hm2_5i25.0.encoder.00.scale'
[86423.228231] HAL: creating parameter 'hm2_5i25.0.encoder.00.index-invert'
[86423.228241] HAL: creating parameter 'hm2_5i25.0.encoder.00.index-mask'
[86423.228251] HAL: creating parameter 'hm2_5i25.0.encoder.00.index-mask-invert'
[86423.228263] HAL: creating parameter 'hm2_5i25.0.encoder.00.counter-mode'
[86423.228273] HAL: creating parameter 'hm2_5i25.0.encoder.00.filter'
[86423.228283] HAL: creating parameter 'hm2_5i25.0.encoder.00.vel-timeout'
[86423.228295] HAL: creating pin 'hm2_5i25.0.encoder.01.rawcounts'
[86423.228308] HAL: creating pin 'hm2_5i25.0.encoder.01.rawlatch'
[86423.228321] HAL: creating pin 'hm2_5i25.0.encoder.01.count'
[86423.228334] HAL: creating pin 'hm2_5i25.0.encoder.01.count-latched'
[86423.228347] HAL: creating pin 'hm2_5i25.0.encoder.01.position'
[86423.228361] HAL: creating pin 'hm2_5i25.0.encoder.01.position-latched'
[86423.228375] HAL: creating pin 'hm2_5i25.0.encoder.01.velocity'
[86423.228389] HAL: creating pin 'hm2_5i25.0.encoder.01.reset'
[86423.228404] HAL: creating pin 'hm2_5i25.0.encoder.01.index-enable'
[86423.228418] HAL: creating pin 'hm2_5i25.0.encoder.01.latch-enable'
[86423.228432] HAL: creating pin 'hm2_5i25.0.encoder.01.latch-polarity'
[86423.228446] HAL: creating parameter 'hm2_5i25.0.encoder.01.scale'
[86423.228458] HAL: creating parameter 'hm2_5i25.0.encoder.01.index-invert'
[86423.228470] HAL: creating parameter 'hm2_5i25.0.encoder.01.index-mask'
[86423.228482] HAL: creating parameter 'hm2_5i25.0.encoder.01.index-mask-invert'
[86423.228496] HAL: creating parameter 'hm2_5i25.0.encoder.01.counter-mode'
[86423.228508] HAL: creating parameter 'hm2_5i25.0.encoder.01.filter'
[86423.228520] HAL: creating parameter 'hm2_5i25.0.encoder.01.vel-timeout'
[86423.228539] hm2/hm2_5i25.0: MD 2: 2x Encoder v2: accepted, using 2
[86423.228548] hm2/hm2_5i25.0: sserial_num_instances = 1
[86423.228557] hm2/hm2_5i25.0: sec unit = 0, sec pin = 1
[86423.228564] hm2/hm2_5i25.0: sec unit = 0, sec pin = 1
[86423.228572] hm2/hm2_5i25.0: sec unit = 0, sec pin = 2
[86423.228579] hm2/hm2_5i25.0: sec unit = 0, sec pin = 2
[86423.228588] hm2/hm2_5i25.0: sec unit = 0, sec pin = 3
[86423.228595] hm2/hm2_5i25.0: sec unit = 0, sec pin = 3
[86423.228602] hm2/hm2_5i25.0: sec unit = 0, sec pin = 4
[86423.228609] hm2/hm2_5i25.0: sec unit = 0, sec pin = 4
[86423.228617] hm2/hm2_5i25.0: num channels = 4
[86423.228820] hm2/hm2_5i25.0: Smart Serial Firmware Version 38
[86423.228976] hm2/hm2_5i25.0: Start-mode = f01
[86423.228982] hm2/hm2_5i25.0: Start-mode = f03
[86423.228989] hm2/hm2_5i25.0: Start-mode = f07
[86423.228996] hm2/hm2_5i25.0: Start-mode = f0f
[86423.269913] hm2/hm2_5i25.0: MD 3: 1x Smart Serial Interface v0: accepted, using 0
[86423.370358] HAL: creating pin 'hm2_5i25.0.stepgen.00.position-cmd'
[86423.370387] HAL: creating pin 'hm2_5i25.0.stepgen.00.velocity-cmd'
[86423.370401] HAL: creating pin 'hm2_5i25.0.stepgen.00.velocity-fb'
[86423.370416] HAL: creating pin 'hm2_5i25.0.stepgen.00.position-fb'
[86423.370430] HAL: creating pin 'hm2_5i25.0.stepgen.00.counts'
[86423.370443] HAL: creating pin 'hm2_5i25.0.stepgen.00.enable'
[86423.370457] HAL: creating pin 'hm2_5i25.0.stepgen.00.control-type'
[86423.370472] HAL: creating pin 'hm2_5i25.0.stepgen.00.dbg_pos_minus_prev_'
[86423.370487] HAL: creating pin 'hm2_5i25.0.stepgen.00.dbg_ff_vel'
[86423.370501] HAL: creating pin 'hm2_5i25.0.stepgen.00.dbg_s_to_match'
[86423.370517] HAL: creating pin 'hm2_5i25.0.stepgen.00.dbg_vel_error'
[86423.370532] HAL: creating pin 'hm2_5i25.0.stepgen.00.dbg_err_at_match'
[86423.370547] HAL: creating pin 'hm2_5i25.0.stepgen.00.dbg_step_rate'
[86423.370564] HAL: creating parameter 'hm2_5i25.0.stepgen.00.position-scale'
[86423.370581] HAL: creating parameter 'hm2_5i25.0.stepgen.00.maxvel'
[86423.370594] HAL: creating parameter 'hm2_5i25.0.stepgen.00.maxaccel'
[86423.370607] HAL: creating parameter 'hm2_5i25.0.stepgen.00.steplen'
[86423.370621] HAL: creating parameter 'hm2_5i25.0.stepgen.00.stepspace'
[86423.370635] HAL: creating parameter 'hm2_5i25.0.stepgen.00.dirsetup'
[86423.370648] HAL: creating parameter 'hm2_5i25.0.stepgen.00.dirhold'
[86423.370661] HAL: creating parameter 'hm2_5i25.0.stepgen.00.step_type'
[86423.370681] HAL: creating pin 'hm2_5i25.0.stepgen.01.position-cmd'
[86423.370699] HAL: creating pin 'hm2_5i25.0.stepgen.01.velocity-cmd'
[86423.370716] HAL: creating pin 'hm2_5i25.0.stepgen.01.velocity-fb'
[86423.370735] HAL: creating pin 'hm2_5i25.0.stepgen.01.position-fb'
[86423.370752] HAL: creating pin 'hm2_5i25.0.stepgen.01.counts'
[86423.370769] HAL: creating pin 'hm2_5i25.0.stepgen.01.enable'
[86423.370787] HAL: creating pin 'hm2_5i25.0.stepgen.01.control-type'
[86423.370805] HAL: creating pin 'hm2_5i25.0.stepgen.01.dbg_pos_minus_prev_'
[86423.370823] HAL: creating pin 'hm2_5i25.0.stepgen.01.dbg_ff_vel'
[86423.370841] HAL: creating pin 'hm2_5i25.0.stepgen.01.dbg_s_to_match'
[86423.370860] HAL: creating pin 'hm2_5i25.0.stepgen.01.dbg_vel_error'
[86423.370880] HAL: creating pin 'hm2_5i25.0.stepgen.01.dbg_err_at_match'
[86423.370898] HAL: creating pin 'hm2_5i25.0.stepgen.01.dbg_step_rate'
[86423.370918] HAL: creating parameter 'hm2_5i25.0.stepgen.01.position-scale'
[86423.370933] HAL: creating parameter 'hm2_5i25.0.stepgen.01.maxvel'
[86423.370948] HAL: creating parameter 'hm2_5i25.0.stepgen.01.maxaccel'
[86423.370963] HAL: creating parameter 'hm2_5i25.0.stepgen.01.steplen'
[86423.370979] HAL: creating parameter 'hm2_5i25.0.stepgen.01.stepspace'
[86423.370995] HAL: creating parameter 'hm2_5i25.0.stepgen.01.dirsetup'
[86423.371010] HAL: creating parameter 'hm2_5i25.0.stepgen.01.dirhold'
[86423.371025] HAL: creating parameter 'hm2_5i25.0.stepgen.01.step_type'
[86423.371043] HAL: creating pin 'hm2_5i25.0.stepgen.02.position-cmd'
[86423.371064] HAL: creating pin 'hm2_5i25.0.stepgen.02.velocity-cmd'
[86423.371085] HAL: creating pin 'hm2_5i25.0.stepgen.02.velocity-fb'
[86423.371107] HAL: creating pin 'hm2_5i25.0.stepgen.02.position-fb'
[86423.371128] HAL: creating pin 'hm2_5i25.0.stepgen.02.counts'
[86423.371149] HAL: creating pin 'hm2_5i25.0.stepgen.02.enable'
[86423.371170] HAL: creating pin 'hm2_5i25.0.stepgen.02.control-type'
[86423.371192] HAL: creating pin 'hm2_5i25.0.stepgen.02.dbg_pos_minus_prev_'
[86423.371214] HAL: creating pin 'hm2_5i25.0.stepgen.02.dbg_ff_vel'
[86423.371236] HAL: creating pin 'hm2_5i25.0.stepgen.02.dbg_s_to_match'
[86423.371258] HAL: creating pin 'hm2_5i25.0.stepgen.02.dbg_vel_error'
[86423.371281] HAL: creating pin 'hm2_5i25.0.stepgen.02.dbg_err_at_match'
[86423.371303] HAL: creating pin 'hm2_5i25.0.stepgen.02.dbg_step_rate'
[86423.371327] HAL: creating parameter 'hm2_5i25.0.stepgen.02.position-scale'
[86423.371344] HAL: creating parameter 'hm2_5i25.0.stepgen.02.maxvel'
[86423.371362] HAL: creating parameter 'hm2_5i25.0.stepgen.02.maxaccel'
[86423.371379] HAL: creating parameter 'hm2_5i25.0.stepgen.02.steplen'
[86423.371397] HAL: creating parameter 'hm2_5i25.0.stepgen.02.stepspace'
[86423.371416] HAL: creating parameter 'hm2_5i25.0.stepgen.02.dirsetup'
[86423.371433] HAL: creating parameter 'hm2_5i25.0.stepgen.02.dirhold'
[86423.371450] HAL: creating parameter 'hm2_5i25.0.stepgen.02.step_type'
[86423.371470] HAL: creating pin 'hm2_5i25.0.stepgen.03.position-cmd'
[86423.371495] HAL: creating pin 'hm2_5i25.0.stepgen.03.velocity-cmd'
[86423.371520] HAL: creating pin 'hm2_5i25.0.stepgen.03.velocity-fb'
[86423.371545] HAL: creating pin 'hm2_5i25.0.stepgen.03.position-fb'
[86423.371570] HAL: creating pin 'hm2_5i25.0.stepgen.03.counts'
[86423.371595] HAL: creating pin 'hm2_5i25.0.stepgen.03.enable'
[86423.371619] HAL: creating pin 'hm2_5i25.0.stepgen.03.control-type'
[86423.371645] HAL: creating pin 'hm2_5i25.0.stepgen.03.dbg_pos_minus_prev_'
[86423.371671] HAL: creating pin 'hm2_5i25.0.stepgen.03.dbg_ff_vel'
[86423.371696] HAL: creating pin 'hm2_5i25.0.stepgen.03.dbg_s_to_match'
[86423.371722] HAL: creating pin 'hm2_5i25.0.stepgen.03.dbg_vel_error'
[86423.371749] HAL: creating pin 'hm2_5i25.0.stepgen.03.dbg_err_at_match'
[86423.371775] HAL: creating pin 'hm2_5i25.0.stepgen.03.dbg_step_rate'
[86423.371802] HAL: creating parameter 'hm2_5i25.0.stepgen.03.position-scale'
[86423.371822] HAL: creating parameter 'hm2_5i25.0.stepgen.03.maxvel'
[86423.371841] HAL: creating parameter 'hm2_5i25.0.stepgen.03.maxaccel'
[86423.371861] HAL: creating parameter 'hm2_5i25.0.stepgen.03.steplen'
[86423.371881] HAL: creating parameter 'hm2_5i25.0.stepgen.03.stepspace'
[86423.371902] HAL: creating parameter 'hm2_5i25.0.stepgen.03.dirsetup'
[86423.371921] HAL: creating parameter 'hm2_5i25.0.stepgen.03.dirhold'
[86423.371941] HAL: creating parameter 'hm2_5i25.0.stepgen.03.step_type'
[86423.371963] HAL: creating pin 'hm2_5i25.0.stepgen.04.position-cmd'
[86423.371992] HAL: creating pin 'hm2_5i25.0.stepgen.04.velocity-cmd'
[86423.372020] HAL: creating pin 'hm2_5i25.0.stepgen.04.velocity-fb'
[86423.372049] HAL: creating pin 'hm2_5i25.0.stepgen.04.position-fb'
[86423.372078] HAL: creating pin 'hm2_5i25.0.stepgen.04.counts'
[86423.372106] HAL: creating pin 'hm2_5i25.0.stepgen.04.enable'
[86423.372134] HAL: creating pin 'hm2_5i25.0.stepgen.04.control-type'
[86423.372163] HAL: creating pin 'hm2_5i25.0.stepgen.04.dbg_pos_minus_prev_'
[86423.372193] HAL: creating pin 'hm2_5i25.0.stepgen.04.dbg_ff_vel'
[86423.372222] HAL: creating pin 'hm2_5i25.0.stepgen.04.dbg_s_to_match'
[86423.372252] HAL: creating pin 'hm2_5i25.0.stepgen.04.dbg_vel_error'
[86423.372282] HAL: creating pin 'hm2_5i25.0.stepgen.04.dbg_err_at_match'
[86423.372311] HAL: creating pin 'hm2_5i25.0.stepgen.04.dbg_step_rate'
[86423.372342] HAL: creating parameter 'hm2_5i25.0.stepgen.04.position-scale'
[86423.372364] HAL: creating parameter 'hm2_5i25.0.stepgen.04.maxvel'
[86423.372386] HAL: creating parameter 'hm2_5i25.0.stepgen.04.maxaccel'
[86423.372408] HAL: creating parameter 'hm2_5i25.0.stepgen.04.steplen'
[86423.372431] HAL: creating parameter 'hm2_5i25.0.stepgen.04.stepspace'
[86423.372454] HAL: creating parameter 'hm2_5i25.0.stepgen.04.dirsetup'
[86423.372476] HAL: creating parameter 'hm2_5i25.0.stepgen.04.dirhold'
[86423.372497] HAL: creating parameter 'hm2_5i25.0.stepgen.04.step_type'
[86423.372522] HAL: creating pin 'hm2_5i25.0.stepgen.05.position-cmd'
[86423.372554] HAL: creating pin 'hm2_5i25.0.stepgen.05.velocity-cmd'
[86423.372586] HAL: creating pin 'hm2_5i25.0.stepgen.05.velocity-fb'
[86423.372619] HAL: creating pin 'hm2_5i25.0.stepgen.05.position-fb'
[86423.372651] HAL: creating pin 'hm2_5i25.0.stepgen.05.counts'
[86423.372683] HAL: creating pin 'hm2_5i25.0.stepgen.05.enable'
[86423.372715] HAL: creating pin 'hm2_5i25.0.stepgen.05.control-type'
[86423.372748] HAL: creating pin 'hm2_5i25.0.stepgen.05.dbg_pos_minus_prev_'
[86423.372781] HAL: creating pin 'hm2_5i25.0.stepgen.05.dbg_ff_vel'
[86423.372813] HAL: creating pin 'hm2_5i25.0.stepgen.05.dbg_s_to_match'
[86423.372847] HAL: creating pin 'hm2_5i25.0.stepgen.05.dbg_vel_error'
[86423.372881] HAL: creating pin 'hm2_5i25.0.stepgen.05.dbg_err_at_match'
[86423.372914] HAL: creating pin 'hm2_5i25.0.stepgen.05.dbg_step_rate'
[86423.372948] HAL: creating parameter 'hm2_5i25.0.stepgen.05.position-scale'
[86423.372973] HAL: creating parameter 'hm2_5i25.0.stepgen.05.maxvel'
[86423.372997] HAL: creating parameter 'hm2_5i25.0.stepgen.05.maxaccel'
[86423.373021] HAL: creating parameter 'hm2_5i25.0.stepgen.05.steplen'
[86423.373046] HAL: creating parameter 'hm2_5i25.0.stepgen.05.stepspace'
[86423.373071] HAL: creating parameter 'hm2_5i25.0.stepgen.05.dirsetup'
[86423.373095] HAL: creating parameter 'hm2_5i25.0.stepgen.05.dirhold'
[86423.373119] HAL: creating parameter 'hm2_5i25.0.stepgen.05.step_type'
[86423.373146] HAL: creating pin 'hm2_5i25.0.stepgen.06.position-cmd'
[86423.373182] HAL: creating pin 'hm2_5i25.0.stepgen.06.velocity-cmd'
[86423.373218] HAL: creating pin 'hm2_5i25.0.stepgen.06.velocity-fb'
[86423.373254] HAL: creating pin 'hm2_5i25.0.stepgen.06.position-fb'
[86423.373290] HAL: creating pin 'hm2_5i25.0.stepgen.06.counts'
[86423.373325] HAL: creating pin 'hm2_5i25.0.stepgen.06.enable'
[86423.373361] HAL: creating pin 'hm2_5i25.0.stepgen.06.control-type'
[86423.373398] HAL: creating pin 'hm2_5i25.0.stepgen.06.dbg_pos_minus_prev_'
[86423.373434] HAL: creating pin 'hm2_5i25.0.stepgen.06.dbg_ff_vel'
[86423.373471] HAL: creating pin 'hm2_5i25.0.stepgen.06.dbg_s_to_match'
[86423.373508] HAL: creating pin 'hm2_5i25.0.stepgen.06.dbg_vel_error'
[86423.373546] HAL: creating pin 'hm2_5i25.0.stepgen.06.dbg_err_at_match'
[86423.373582] HAL: creating pin 'hm2_5i25.0.stepgen.06.dbg_step_rate'
[86423.373620] HAL: creating parameter 'hm2_5i25.0.stepgen.06.position-scale'
[86423.373647] HAL: creating parameter 'hm2_5i25.0.stepgen.06.maxvel'
[86423.373673] HAL: creating parameter 'hm2_5i25.0.stepgen.06.maxaccel'
[86423.373700] HAL: creating parameter 'hm2_5i25.0.stepgen.06.steplen'
[86423.373727] HAL: creating parameter 'hm2_5i25.0.stepgen.06.stepspace'
[86423.373787] HAL: creating parameter 'hm2_5i25.0.stepgen.06.dirsetup'
[86423.373814] HAL: creating parameter 'hm2_5i25.0.stepgen.06.dirhold'
[86423.373841] HAL: creating parameter 'hm2_5i25.0.stepgen.06.step_type'
[86423.373870] HAL: creating pin 'hm2_5i25.0.stepgen.07.position-cmd'
[86423.373910] HAL: creating pin 'hm2_5i25.0.stepgen.07.velocity-cmd'
[86423.373950] HAL: creating pin 'hm2_5i25.0.stepgen.07.velocity-fb'
[86423.373990] HAL: creating pin 'hm2_5i25.0.stepgen.07.position-fb'
[86423.374030] HAL: creating pin 'hm2_5i25.0.stepgen.07.counts'
[86423.374069] HAL: creating pin 'hm2_5i25.0.stepgen.07.enable'
[86423.374115] HAL: creating pin 'hm2_5i25.0.stepgen.07.control-type'
[86423.374155] HAL: creating pin 'hm2_5i25.0.stepgen.07.dbg_pos_minus_prev_'
[86423.374196] HAL: creating pin 'hm2_5i25.0.stepgen.07.dbg_ff_vel'
[86423.374236] HAL: creating pin 'hm2_5i25.0.stepgen.07.dbg_s_to_match'
[86423.374277] HAL: creating pin 'hm2_5i25.0.stepgen.07.dbg_vel_error'
[86423.374318] HAL: creating pin 'hm2_5i25.0.stepgen.07.dbg_err_at_match'
[86423.374359] HAL: creating pin 'hm2_5i25.0.stepgen.07.dbg_step_rate'
[86423.374401] HAL: creating parameter 'hm2_5i25.0.stepgen.07.position-scale'
[86423.374430] HAL: creating parameter 'hm2_5i25.0.stepgen.07.maxvel'
[86423.374459] HAL: creating parameter 'hm2_5i25.0.stepgen.07.maxaccel'
[86423.374487] HAL: creating parameter 'hm2_5i25.0.stepgen.07.steplen'
[86423.374517] HAL: creating parameter 'hm2_5i25.0.stepgen.07.stepspace'
[86423.374547] HAL: creating parameter 'hm2_5i25.0.stepgen.07.dirsetup'
[86423.374575] HAL: creating parameter 'hm2_5i25.0.stepgen.07.dirhold'
[86423.374604] HAL: creating parameter 'hm2_5i25.0.stepgen.07.step_type'
[86423.374636] HAL: creating pin 'hm2_5i25.0.stepgen.08.position-cmd'
[86423.374679] HAL: creating pin 'hm2_5i25.0.stepgen.08.velocity-cmd'
[86423.374723] HAL: creating pin 'hm2_5i25.0.stepgen.08.velocity-fb'
[86423.374767] HAL: creating pin 'hm2_5i25.0.stepgen.08.position-fb'
[86423.374810] HAL: creating pin 'hm2_5i25.0.stepgen.08.counts'
[86423.374853] HAL: creating pin 'hm2_5i25.0.stepgen.08.enable'
[86423.374896] HAL: creating pin 'hm2_5i25.0.stepgen.08.control-type'
[86423.374940] HAL: creating pin 'hm2_5i25.0.stepgen.08.dbg_pos_minus_prev_'
[86423.374984] HAL: creating pin 'hm2_5i25.0.stepgen.08.dbg_ff_vel'
[86423.375028] HAL: creating pin 'hm2_5i25.0.stepgen.08.dbg_s_to_match'
[86423.375072] HAL: creating pin 'hm2_5i25.0.stepgen.08.dbg_vel_error'
[86423.375118] HAL: creating pin 'hm2_5i25.0.stepgen.08.dbg_err_at_match'
[86423.375162] HAL: creating pin 'hm2_5i25.0.stepgen.08.dbg_step_rate'
[86423.375207] HAL: creating parameter 'hm2_5i25.0.stepgen.08.position-scale'
[86423.375239] HAL: creating parameter 'hm2_5i25.0.stepgen.08.maxvel'
[86423.375270] HAL: creating parameter 'hm2_5i25.0.stepgen.08.maxaccel'
[86423.375301] HAL: creating parameter 'hm2_5i25.0.stepgen.08.steplen'
[86423.375332] HAL: creating parameter 'hm2_5i25.0.stepgen.08.stepspace'
[86423.375364] HAL: creating parameter 'hm2_5i25.0.stepgen.08.dirsetup'
[86423.375395] HAL: creating parameter 'hm2_5i25.0.stepgen.08.dirhold'
[86423.375426] HAL: creating parameter 'hm2_5i25.0.stepgen.08.step_type'
[86423.375460] HAL: creating pin 'hm2_5i25.0.stepgen.09.position-cmd'
[86423.375507] HAL: creating pin 'hm2_5i25.0.stepgen.09.velocity-cmd'
[86423.375554] HAL: creating pin 'hm2_5i25.0.stepgen.09.velocity-fb'
[86423.375602] HAL: creating pin 'hm2_5i25.0.stepgen.09.position-fb'
[86423.375649] HAL: creating pin 'hm2_5i25.0.stepgen.09.counts'
[86423.375695] HAL: creating pin 'hm2_5i25.0.stepgen.09.enable'
[86423.375742] HAL: creating pin 'hm2_5i25.0.stepgen.09.control-type'
[86423.375790] HAL: creating pin 'hm2_5i25.0.stepgen.09.dbg_pos_minus_prev_'
[86423.375838] HAL: creating pin 'hm2_5i25.0.stepgen.09.dbg_ff_vel'
[86423.375885] HAL: creating pin 'hm2_5i25.0.stepgen.09.dbg_s_to_match'
[86423.375934] HAL: creating pin 'hm2_5i25.0.stepgen.09.dbg_vel_error'
[86423.375983] HAL: creating pin 'hm2_5i25.0.stepgen.09.dbg_err_at_match'
[86423.376031] HAL: creating pin 'hm2_5i25.0.stepgen.09.dbg_step_rate'
[86423.376080] HAL: creating parameter 'hm2_5i25.0.stepgen.09.position-scale'
[86423.376114] HAL: creating parameter 'hm2_5i25.0.stepgen.09.maxvel'
[86423.376147] HAL: creating parameter 'hm2_5i25.0.stepgen.09.maxaccel'
[86423.376180] HAL: creating parameter 'hm2_5i25.0.stepgen.09.steplen'
[86423.376214] HAL: creating parameter 'hm2_5i25.0.stepgen.09.stepspace'
[86423.376248] HAL: creating parameter 'hm2_5i25.0.stepgen.09.dirsetup'
[86423.376281] HAL: creating parameter 'hm2_5i25.0.stepgen.09.dirhold'
[86423.376315] HAL: creating parameter 'hm2_5i25.0.stepgen.09.step_type'
[86423.376353] hm2/hm2_5i25.0: MD 4: 10x StepGen v2: accepted, using 10
[86423.387115] HAL: creating pin 'hm2_5i25.0.led.CR01'
[86423.387143] HAL: creating pin 'hm2_5i25.0.led.CR02'
[86423.387159] hm2/hm2_5i25.0: MD 5: 1x LED v0: accepted, using 1
[86423.387171] hm2/hm2_5i25.0: allocating Translation RAM buffers (reading 60 bytes, writing 48 bytes)
[86423.387183] hm2/hm2_5i25.0: Translation RAM read buffer:
[86423.387192] hm2/hm2_5i25.0: addr=0x1000, size=8, buffer=d747a780
[86423.387201] hm2/hm2_5i25.0: addr=0x3300, size=4, buffer=d747a788
[86423.387210] hm2/hm2_5i25.0: addr=0x3000, size=8, buffer=d747a78c
[86423.387220] hm2/hm2_5i25.0: addr=0x2100, size=40, buffer=d747a794
[86423.387227] hm2/hm2_5i25.0: Translation RAM write buffer:
[86423.387236] hm2/hm2_5i25.0: addr=0x1000, size=8, buffer=d747a880
[86423.387245] hm2/hm2_5i25.0: addr=0x2000, size=40, buffer=d747a888
[86423.387268] HAL: creating pin 'hm2_5i25.0.gpio.000.in'
[86423.387282] HAL: creating pin 'hm2_5i25.0.gpio.000.in_not'
[86423.387297] HAL: creating parameter 'hm2_5i25.0.gpio.000.invert_output'
[86423.387314] HAL: creating parameter 'hm2_5i25.0.gpio.000.is_opendrain'
[86423.387327] HAL: creating pin 'hm2_5i25.0.gpio.001.in'
[86423.387341] HAL: creating pin 'hm2_5i25.0.gpio.001.in_not'
[86423.387355] HAL: creating parameter 'hm2_5i25.0.gpio.001.invert_output'
[86423.387369] HAL: creating parameter 'hm2_5i25.0.gpio.001.is_opendrain'
[86423.387382] HAL: creating pin 'hm2_5i25.0.gpio.002.in'
[86423.387396] HAL: creating pin 'hm2_5i25.0.gpio.002.in_not'
[86423.387411] HAL: creating parameter 'hm2_5i25.0.gpio.002.invert_output'
[86423.387425] HAL: creating parameter 'hm2_5i25.0.gpio.002.is_opendrain'
[86423.387438] HAL: creating pin 'hm2_5i25.0.gpio.003.in'
[86423.387453] HAL: creating pin 'hm2_5i25.0.gpio.003.in_not'
[86423.387469] HAL: creating parameter 'hm2_5i25.0.gpio.003.invert_output'
[86423.387483] HAL: creating parameter 'hm2_5i25.0.gpio.003.is_opendrain'
[86423.387497] HAL: creating pin 'hm2_5i25.0.gpio.004.in'
[86423.387512] HAL: creating pin 'hm2_5i25.0.gpio.004.in_not'
[86423.387528] HAL: creating parameter 'hm2_5i25.0.gpio.004.invert_output'
[86423.387543] HAL: creating parameter 'hm2_5i25.0.gpio.004.is_opendrain'
[86423.387558] HAL: creating pin 'hm2_5i25.0.gpio.005.in'
[86423.387573] HAL: creating pin 'hm2_5i25.0.gpio.005.in_not'
[86423.387590] HAL: creating parameter 'hm2_5i25.0.gpio.005.invert_output'
[86423.387605] HAL: creating parameter 'hm2_5i25.0.gpio.005.is_opendrain'
[86423.387620] HAL: creating pin 'hm2_5i25.0.gpio.006.in'
[86423.387637] HAL: creating pin 'hm2_5i25.0.gpio.006.in_not'
[86423.387654] HAL: creating parameter 'hm2_5i25.0.gpio.006.invert_output'
[86423.387669] HAL: creating parameter 'hm2_5i25.0.gpio.006.is_opendrain'
[86423.387685] HAL: creating pin 'hm2_5i25.0.gpio.007.in'
[86423.387702] HAL: creating pin 'hm2_5i25.0.gpio.007.in_not'
[86423.387719] HAL: creating parameter 'hm2_5i25.0.gpio.007.invert_output'
[86423.387736] HAL: creating parameter 'hm2_5i25.0.gpio.007.is_opendrain'
[86423.387752] HAL: creating pin 'hm2_5i25.0.gpio.008.in'
[86423.387769] HAL: creating pin 'hm2_5i25.0.gpio.008.in_not'
[86423.387787] HAL: creating parameter 'hm2_5i25.0.gpio.008.invert_output'
[86423.387804] HAL: creating parameter 'hm2_5i25.0.gpio.008.is_opendrain'
[86423.387821] HAL: creating pin 'hm2_5i25.0.gpio.009.in'
[86423.387838] HAL: creating pin 'hm2_5i25.0.gpio.009.in_not'
[86423.387857] HAL: creating parameter 'hm2_5i25.0.gpio.009.invert_output'
[86423.387874] HAL: creating parameter 'hm2_5i25.0.gpio.009.is_opendrain'
[86423.387892] HAL: creating pin 'hm2_5i25.0.gpio.010.in'
[86423.387910] HAL: creating pin 'hm2_5i25.0.gpio.010.in_not'
[86423.387929] HAL: creating parameter 'hm2_5i25.0.gpio.010.invert_output'
[86423.387946] HAL: creating parameter 'hm2_5i25.0.gpio.010.is_opendrain'
[86423.387964] HAL: creating pin 'hm2_5i25.0.gpio.010.out'
[86423.387983] HAL: creating parameter 'hm2_5i25.0.gpio.010.is_output'
[86423.388089] HAL: creating pin 'hm2_5i25.0.gpio.011.in'
[86423.388109] HAL: creating pin 'hm2_5i25.0.gpio.011.in_not'
[86423.388129] HAL: creating parameter 'hm2_5i25.0.gpio.011.invert_output'
[86423.388148] HAL: creating parameter 'hm2_5i25.0.gpio.011.is_opendrain'
[86423.388166] HAL: creating pin 'hm2_5i25.0.gpio.011.out'
[86423.388186] HAL: creating parameter 'hm2_5i25.0.gpio.011.is_output'
[86423.388205] HAL: creating pin 'hm2_5i25.0.gpio.012.in'
[86423.388224] HAL: creating pin 'hm2_5i25.0.gpio.012.in_not'
[86423.388245] HAL: creating parameter 'hm2_5i25.0.gpio.012.invert_output'
[86423.388264] HAL: creating parameter 'hm2_5i25.0.gpio.012.is_opendrain'
[86423.388283] HAL: creating pin 'hm2_5i25.0.gpio.012.out'
[86423.388303] HAL: creating parameter 'hm2_5i25.0.gpio.012.is_output'
[86423.388323] HAL: creating pin 'hm2_5i25.0.gpio.013.in'
[86423.388343] HAL: creating pin 'hm2_5i25.0.gpio.013.in_not'
[86423.388364] HAL: creating parameter 'hm2_5i25.0.gpio.013.invert_output'
[86423.388384] HAL: creating parameter 'hm2_5i25.0.gpio.013.is_opendrain'
[86423.388404] HAL: creating pin 'hm2_5i25.0.gpio.013.out'
[86423.388425] HAL: creating parameter 'hm2_5i25.0.gpio.013.is_output'
[86423.388445] HAL: creating pin 'hm2_5i25.0.gpio.014.in'
[86423.388466] HAL: creating pin 'hm2_5i25.0.gpio.014.in_not'
[86423.388488] HAL: creating pin 'hm2_5i25.0.gpio.015.in'
[86423.388510] HAL: creating pin 'hm2_5i25.0.gpio.015.in_not'
[86423.388532] HAL: creating pin 'hm2_5i25.0.gpio.016.in'
[86423.388554] HAL: creating pin 'hm2_5i25.0.gpio.016.in_not'
[86423.388577] HAL: creating pin 'hm2_5i25.0.gpio.017.in'
[86423.388600] HAL: creating pin 'hm2_5i25.0.gpio.017.in_not'
[86423.388623] HAL: creating parameter 'hm2_5i25.0.gpio.017.invert_output'
[86423.388644] HAL: creating parameter 'hm2_5i25.0.gpio.017.is_opendrain'
[86423.388665] HAL: creating pin 'hm2_5i25.0.gpio.018.in'
[86423.388688] HAL: creating pin 'hm2_5i25.0.gpio.018.in_not'
[86423.388712] HAL: creating parameter 'hm2_5i25.0.gpio.018.invert_output'
[86423.388733] HAL: creating parameter 'hm2_5i25.0.gpio.018.is_opendrain'
[86423.388754] HAL: creating pin 'hm2_5i25.0.gpio.019.in'
[86423.388778] HAL: creating pin 'hm2_5i25.0.gpio.019.in_not'
[86423.388803] HAL: creating parameter 'hm2_5i25.0.gpio.019.invert_output'
[86423.388825] HAL: creating parameter 'hm2_5i25.0.gpio.019.is_opendrain'
[86423.388846] HAL: creating pin 'hm2_5i25.0.gpio.020.in'
[86423.388870] HAL: creating pin 'hm2_5i25.0.gpio.020.in_not'
[86423.388895] HAL: creating parameter 'hm2_5i25.0.gpio.020.invert_output'
[86423.388917] HAL: creating parameter 'hm2_5i25.0.gpio.020.is_opendrain'
[86423.388939] HAL: creating pin 'hm2_5i25.0.gpio.021.in'
[86423.388963] HAL: creating pin 'hm2_5i25.0.gpio.021.in_not'
[86423.388989] HAL: creating parameter 'hm2_5i25.0.gpio.021.invert_output'
[86423.389011] HAL: creating parameter 'hm2_5i25.0.gpio.021.is_opendrain'
[86423.389034] HAL: creating pin 'hm2_5i25.0.gpio.022.in'
[86423.389059] HAL: creating pin 'hm2_5i25.0.gpio.022.in_not'
[86423.389085] HAL: creating parameter 'hm2_5i25.0.gpio.022.invert_output'
[86423.389108] HAL: creating parameter 'hm2_5i25.0.gpio.022.is_opendrain'
[86423.389131] HAL: creating pin 'hm2_5i25.0.gpio.023.in'
[86423.389156] HAL: creating pin 'hm2_5i25.0.gpio.023.in_not'
[86423.389183] HAL: creating parameter 'hm2_5i25.0.gpio.023.invert_output'
[86423.389206] HAL: creating parameter 'hm2_5i25.0.gpio.023.is_opendrain'
[86423.389230] HAL: creating pin 'hm2_5i25.0.gpio.024.in'
[86423.389256] HAL: creating pin 'hm2_5i25.0.gpio.024.in_not'
[86423.389283] HAL: creating parameter 'hm2_5i25.0.gpio.024.invert_output'
[86423.389307] HAL: creating parameter 'hm2_5i25.0.gpio.024.is_opendrain'
[86423.389331] HAL: creating pin 'hm2_5i25.0.gpio.025.in'
[86423.389358] HAL: creating pin 'hm2_5i25.0.gpio.025.in_not'
[86423.389385] HAL: creating parameter 'hm2_5i25.0.gpio.025.invert_output'
[86423.389410] HAL: creating parameter 'hm2_5i25.0.gpio.025.is_opendrain'
[86423.389434] HAL: creating pin 'hm2_5i25.0.gpio.026.in'
[86423.389461] HAL: creating pin 'hm2_5i25.0.gpio.026.in_not'
[86423.389489] HAL: creating parameter 'hm2_5i25.0.gpio.026.invert_output'
[86423.389514] HAL: creating parameter 'hm2_5i25.0.gpio.026.is_opendrain'
[86423.389539] HAL: creating pin 'hm2_5i25.0.gpio.027.in'
[86423.389567] HAL: creating pin 'hm2_5i25.0.gpio.027.in_not'
[86423.389596] HAL: creating parameter 'hm2_5i25.0.gpio.027.invert_output'
[86423.389621] HAL: creating parameter 'hm2_5i25.0.gpio.027.is_opendrain'
[86423.389647] HAL: creating pin 'hm2_5i25.0.gpio.027.out'
[86423.389675] HAL: creating parameter 'hm2_5i25.0.gpio.027.is_output'
[86423.389701] HAL: creating pin 'hm2_5i25.0.gpio.028.in'
[86423.389730] HAL: creating pin 'hm2_5i25.0.gpio.028.in_not'
[86423.389789] HAL: creating parameter 'hm2_5i25.0.gpio.028.invert_output'
[86423.389817] HAL: creating parameter 'hm2_5i25.0.gpio.028.is_opendrain'
[86423.389843] HAL: creating pin 'hm2_5i25.0.gpio.028.out'
[86423.389873] HAL: creating parameter 'hm2_5i25.0.gpio.028.is_output'
[86423.389899] HAL: creating pin 'hm2_5i25.0.gpio.029.in'
[86423.389929] HAL: creating pin 'hm2_5i25.0.gpio.029.in_not'
[86423.389959] HAL: creating parameter 'hm2_5i25.0.gpio.029.invert_output'
[86423.389986] HAL: creating parameter 'hm2_5i25.0.gpio.029.is_opendrain'
[86423.390013] HAL: creating pin 'hm2_5i25.0.gpio.029.out'
[86423.390043] HAL: creating parameter 'hm2_5i25.0.gpio.029.is_output'
[86423.390071] HAL: creating pin 'hm2_5i25.0.gpio.030.in'
[86423.390107] HAL: creating pin 'hm2_5i25.0.gpio.030.in_not'
[86423.390138] HAL: creating parameter 'hm2_5i25.0.gpio.030.invert_output'
[86423.390166] HAL: creating parameter 'hm2_5i25.0.gpio.030.is_opendrain'
[86423.390194] HAL: creating pin 'hm2_5i25.0.gpio.030.out'
[86423.390225] HAL: creating parameter 'hm2_5i25.0.gpio.030.is_output'
[86423.390253] HAL: creating pin 'hm2_5i25.0.gpio.031.in'
[86423.390283] HAL: creating pin 'hm2_5i25.0.gpio.031.in_not'
[86423.390314] HAL: creating pin 'hm2_5i25.0.gpio.032.in'
[86423.390345] HAL: creating pin 'hm2_5i25.0.gpio.032.in_not'
[86423.390377] HAL: creating pin 'hm2_5i25.0.gpio.033.in'
[86423.390408] HAL: creating pin 'hm2_5i25.0.gpio.033.in_not'
[86423.390495] hm2/hm2_5i25.0: 34 I/O Pins used:
[86423.390508] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[86423.390518] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[86423.390528] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[86423.390538] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[86423.390548] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[86423.390558] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[86423.390568] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
[86423.390578] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
[86423.390588] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
[86423.390598] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
[86423.390608] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[86423.390616] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[86423.390624] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[86423.390632] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[86423.390642] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[86423.390652] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[86423.390661] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[86423.390671] hm2/hm2_5i25.0: IO Pin 017 (P2-01): StepGen #5, pin Direction (Output)
[86423.390681] hm2/hm2_5i25.0: IO Pin 018 (P2-14): StepGen #5, pin Step (Output)
[86423.390691] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #6, pin Direction (Output)
[86423.390702] hm2/hm2_5i25.0: IO Pin 020 (P2-15): StepGen #6, pin Step (Output)
[86423.390711] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #7, pin Direction (Output)
[86423.390722] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #7, pin Step (Output)
[86423.390732] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #8, pin Direction (Output)
[86423.390742] hm2/hm2_5i25.0: IO Pin 024 (P2-17): StepGen #8, pin Step (Output)
[86423.390752] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #9, pin Direction (Output)
[86423.390762] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #9, pin Step (Output)
[86423.390771] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[86423.390779] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[86423.390787] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[86423.390795] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[86423.390804] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Encoder #1, pin Index (Input)
[86423.390814] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Encoder #1, pin B (Input)
[86423.390823] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Encoder #1, pin A (Input)
[86423.390831] hm2/hm2_5i25.0: HM2 Modules used:
[86423.390838] hm2/hm2_5i25.0: Encoders: 2
[86423.390848] hm2/hm2_5i25.0: clock_frequency: 33333333 Hz (33.333 MHz)
[86423.390855] hm2/hm2_5i25.0: version: 2
[86423.390863] hm2/hm2_5i25.0: counter_addr: 0x3000
[86423.390870] hm2/hm2_5i25.0: latch_control_addr: 0x3100
[86423.390878] hm2/hm2_5i25.0: timestamp_div_addr: 0x3200
[86423.390886] hm2/hm2_5i25.0: timestamp_count_addr: 0x3300
[86423.390893] hm2/hm2_5i25.0: filter_rate_addr: 0x3400
[86423.390901] hm2/hm2_5i25.0: timestamp_div: 0x001F
[86423.390908] hm2/hm2_5i25.0: instance 0:
[86423.390914] hm2/hm2_5i25.0: hw:
[86423.390922] hm2/hm2_5i25.0: counter = 78ec.0004
[86423.390930] hm2/hm2_5i25.0: latch/control = 0000.0800
[86423.390938] hm2/hm2_5i25.0: prev_control = 0000.0800
[86423.390945] hm2/hm2_5i25.0: instance 1:
[86423.390951] hm2/hm2_5i25.0: hw:
[86423.390958] hm2/hm2_5i25.0: counter = 0000.0000
[86423.390966] hm2/hm2_5i25.0: latch/control = 0000.0800
[86423.390975] hm2/hm2_5i25.0: prev_control = 0000.0800
[86423.390982] hm2/hm2_5i25.0: resolvers: 0
[86423.390989] hm2/hm2_5i25.0: PWMGen: 0
[86423.390996] hm2/hm2_5i25.0: 3-phase PWMGen: 0
[86423.391003] hm2/hm2_5i25.0: SSerial: 0
[86423.391009] hm2/hm2_5i25.0: version 0
[86423.391016] hm2/hm2_5i25.0: StepGen: 10
[86423.391025] hm2/hm2_5i25.0: clock_frequency: 33333333 Hz (33.333 MHz)
[86423.391033] hm2/hm2_5i25.0: version: 2
[86423.391040] hm2/hm2_5i25.0: step_rate_addr: 0x2000
[86423.391048] hm2/hm2_5i25.0: accumulator_addr: 0x2100
[86423.391055] hm2/hm2_5i25.0: mode_addr: 0x2200
[86423.391062] hm2/hm2_5i25.0: dir_setup_time_addr: 0x2300
[86423.391070] hm2/hm2_5i25.0: dir_hold_time_addr: 0x2400
[86423.391078] hm2/hm2_5i25.0: pulse_width_addr: 0x2500
[86423.391086] hm2/hm2_5i25.0: pulse_idle_width_addr: 0x2600
[86423.391094] hm2/hm2_5i25.0: table_sequence_data_setup_addr: 0x2700
[86423.391102] hm2/hm2_5i25.0: table_sequence_length_addr: 0x2800
[86423.391110] hm2/hm2_5i25.0: master_dds_addr: 0x2900
[86423.391117] hm2/hm2_5i25.0: instance 0:
[86423.391124] hm2/hm2_5i25.0: enable = 0
[86423.391130] hm2/hm2_5i25.0: hw:
[86423.391137] hm2/hm2_5i25.0: step_rate = 0x00000000
[86423.391145] hm2/hm2_5i25.0: accumulator = 0x00000000
[86423.391153] hm2/hm2_5i25.0: mode = 0x00000000
[86423.391161] hm2/hm2_5i25.0: dir_setup_time = 0x00003FFE (491490 ns)
[86423.391171] hm2/hm2_5i25.0: dir_hold_time = 0x00003FFE (491490 ns)
[86423.391180] hm2/hm2_5i25.0: pulse_width = 0x00003FFE (491490 ns)
[86423.391190] hm2/hm2_5i25.0: pulse_idle_width = 0x00003FFE (491490 ns)
[86423.391197] hm2/hm2_5i25.0: instance 1:
[86423.391204] hm2/hm2_5i25.0: enable = 0
[86423.391210] hm2/hm2_5i25.0: hw:
[86423.391217] hm2/hm2_5i25.0: step_rate = 0x00000000
[86423.391225] hm2/hm2_5i25.0: accumulator = 0x00000000
[86423.391232] hm2/hm2_5i25.0: mode = 0x00000000
[86423.391241] hm2/hm2_5i25.0: dir_setup_time = 0x00003FFE (491490 ns)
[86423.391250] hm2/hm2_5i25.0: dir_hold_time = 0x00003FFE (491490 ns)
[86423.391259] hm2/hm2_5i25.0: pulse_width = 0x00003FFE (491490 ns)
[86423.391268] hm2/hm2_5i25.0: pulse_idle_width = 0x00003FFE (491490 ns)
[86423.391276] hm2/hm2_5i25.0: instance 2:
[86423.391283] hm2/hm2_5i25.0: enable = 0
[86423.391289] hm2/hm2_5i25.0: hw:
[86423.391296] hm2/hm2_5i25.0: step_rate = 0x00000000
[86423.391304] hm2/hm2_5i25.0: accumulator = 0x00000000
[86423.391311] hm2/hm2_5i25.0: mode = 0x00000000
[86423.391320] hm2/hm2_5i25.0: dir_setup_time = 0x00003FFE (491490 ns)
[86423.391329] hm2/hm2_5i25.0: dir_hold_time = 0x00003FFE (491490 ns)
[86423.391338] hm2/hm2_5i25.0: pulse_width = 0x00003FFE (491490 ns)
[86423.391347] hm2/hm2_5i25.0: pulse_idle_width = 0x00003FFE (491490 ns)
[86423.391355] hm2/hm2_5i25.0: instance 3:
[86423.391361] hm2/hm2_5i25.0: enable = 0
[86423.391368] hm2/hm2_5i25.0: hw:
[86423.391375] hm2/hm2_5i25.0: step_rate = 0x00000000
[86423.391382] hm2/hm2_5i25.0: accumulator = 0x00000000
[86423.391390] hm2/hm2_5i25.0: mode = 0x00000000
[86423.391398] hm2/hm2_5i25.0: dir_setup_time = 0x00003FFE (491490 ns)
[86423.391407] hm2/hm2_5i25.0: dir_hold_time = 0x00003FFE (491490 ns)
[86423.391416] hm2/hm2_5i25.0: pulse_width = 0x00003FFE (491490 ns)
[86423.391425] hm2/hm2_5i25.0: pulse_idle_width = 0x00003FFE (491490 ns)
[86423.391433] hm2/hm2_5i25.0: instance 4:
[86423.391440] hm2/hm2_5i25.0: enable = 0
[86423.391446] hm2/hm2_5i25.0: hw:
[86423.391453] hm2/hm2_5i25.0: step_rate = 0x00000000
[86423.391461] hm2/hm2_5i25.0: accumulator = 0x00000000
[86423.391468] hm2/hm2_5i25.0: mode = 0x00000000
[86423.391477] hm2/hm2_5i25.0: dir_setup_time = 0x00003FFE (491490 ns)
[86423.391486] hm2/hm2_5i25.0: dir_hold_time = 0x00003FFE (491490 ns)
[86423.391495] hm2/hm2_5i25.0: pulse_width = 0x00003FFE (491490 ns)
[86423.391504] hm2/hm2_5i25.0: pulse_idle_width = 0x00003FFE (491490 ns)
[86423.391512] hm2/hm2_5i25.0: instance 5:
[86423.391519] hm2/hm2_5i25.0: enable = 0
[86423.391525] hm2/hm2_5i25.0: hw:
[86423.391532] hm2/hm2_5i25.0: step_rate = 0x00000000
[86423.391539] hm2/hm2_5i25.0: accumulator = 0x00000000
[86423.391547] hm2/hm2_5i25.0: mode = 0x00000000
[86423.391555] hm2/hm2_5i25.0: dir_setup_time = 0x00003FFE (491490 ns)
[86423.391564] hm2/hm2_5i25.0: dir_hold_time = 0x00003FFE (491490 ns)
[86423.391573] hm2/hm2_5i25.0: pulse_width = 0x00003FFE (491490 ns)
[86423.391582] hm2/hm2_5i25.0: pulse_idle_width = 0x00003FFE (491490 ns)
[86423.391590] hm2/hm2_5i25.0: instance 6:
[86423.391597] hm2/hm2_5i25.0: enable = 0
[86423.391603] hm2/hm2_5i25.0: hw:
[86423.391610] hm2/hm2_5i25.0: step_rate = 0x00000000
[86423.391618] hm2/hm2_5i25.0: accumulator = 0x00000000
[86423.391625] hm2/hm2_5i25.0: mode = 0x00000000
[86423.391634] hm2/hm2_5i25.0: dir_setup_time = 0x00003FFE (491490 ns)
[86423.391643] hm2/hm2_5i25.0: dir_hold_time = 0x00003FFE (491490 ns)
[86423.391652] hm2/hm2_5i25.0: pulse_width = 0x00003FFE (491490 ns)
[86423.391661] hm2/hm2_5i25.0: pulse_idle_width = 0x00003FFE (491490 ns)
[86423.391669] hm2/hm2_5i25.0: instance 7:
[86423.391676] hm2/hm2_5i25.0: enable = 0
[86423.391682] hm2/hm2_5i25.0: hw:
[86423.391689] hm2/hm2_5i25.0: step_rate = 0x00000000
[86423.391696] hm2/hm2_5i25.0: accumulator = 0x00000000
[86423.391704] hm2/hm2_5i25.0: mode = 0x00000000
[86423.391712] hm2/hm2_5i25.0: dir_setup_time = 0x00003FFE (491490 ns)
[86423.391721] hm2/hm2_5i25.0: dir_hold_time = 0x00003FFE (491490 ns)
[86423.391730] hm2/hm2_5i25.0: pulse_width = 0x00003FFE (491490 ns)
[86423.391740] hm2/hm2_5i25.0: pulse_idle_width = 0x00003FFE (491490 ns)
[86423.391747] hm2/hm2_5i25.0: instance 8:
[86423.391754] hm2/hm2_5i25.0: enable = 0
[86423.391760] hm2/hm2_5i25.0: hw:
[86423.391767] hm2/hm2_5i25.0: step_rate = 0x00000000
[86423.391775] hm2/hm2_5i25.0: accumulator = 0x00000000
[86423.391782] hm2/hm2_5i25.0: mode = 0x00000000
[86423.391791] hm2/hm2_5i25.0: dir_setup_time = 0x00003FFE (491490 ns)
[86423.391800] hm2/hm2_5i25.0: dir_hold_time = 0x00003FFE (491490 ns)
[86423.391809] hm2/hm2_5i25.0: pulse_width = 0x00003FFE (491490 ns)
[86423.391818] hm2/hm2_5i25.0: pulse_idle_width = 0x00003FFE (491490 ns)
[86423.391826] hm2/hm2_5i25.0: instance 9:
[86423.391833] hm2/hm2_5i25.0: enable = 0
[86423.391839] hm2/hm2_5i25.0: hw:
[86423.391846] hm2/hm2_5i25.0: step_rate = 0x00000000
[86423.391853] hm2/hm2_5i25.0: accumulator = 0x00000000
[86423.391861] hm2/hm2_5i25.0: mode = 0x00000000
[86423.391869] hm2/hm2_5i25.0: dir_setup_time = 0x00003FFE (491490 ns)
[86423.391878] hm2/hm2_5i25.0: dir_hold_time = 0x00003FFE (491490 ns)
[86423.391887] hm2/hm2_5i25.0: pulse_width = 0x00003FFE (491490 ns)
[86423.391897] hm2/hm2_5i25.0: pulse_idle_width = 0x00003FFE (491490 ns)
[86423.391905] hm2/hm2_5i25.0: IO Ports: 2
[86423.391914] hm2/hm2_5i25.0: clock_frequency: 33333333 Hz (33.333 MHz)
[86423.391921] hm2/hm2_5i25.0: version: 0
[86423.391928] hm2/hm2_5i25.0: data_addr: 0x1000
[86423.391936] hm2/hm2_5i25.0: ddr_addr: 0x1100
[86423.391943] hm2/hm2_5i25.0: alt_source_addr: 0x1200
[86423.391951] hm2/hm2_5i25.0: open_drain_addr: 0x1300
[86423.391958] hm2/hm2_5i25.0: output_invert_addr: 0x1400
[86423.391965] hm2/hm2_5i25.0: instance 0:
[86423.391973] hm2/hm2_5i25.0: data_read = 0x003C00
[86423.391980] hm2/hm2_5i25.0: data_write = 0x000000
[86423.391988] hm2/hm2_5i25.0: ddr = 0x0003FF
[86423.391995] hm2/hm2_5i25.0: alt_source = 0x01C3FF
[86423.392003] hm2/hm2_5i25.0: open_drain = 0x000000
[86423.392010] hm2/hm2_5i25.0: output_invert = 0x000000
[86423.392017] hm2/hm2_5i25.0: instance 1:
[86423.392024] hm2/hm2_5i25.0: data_read = 0x01FC00
[86423.392032] hm2/hm2_5i25.0: data_write = 0x000000
[86423.392039] hm2/hm2_5i25.0: ddr = 0x0003FF
[86423.392046] hm2/hm2_5i25.0: alt_source = 0x01C3FF
[86423.392053] hm2/hm2_5i25.0: open_drain = 0x000000
[86423.392061] hm2/hm2_5i25.0: output_invert = 0x000000
[86423.392068] hm2/hm2_5i25.0: Watchdog: 1
[86423.392077] hm2/hm2_5i25.0: clock_frequency: 33333333 Hz (33.333 MHz)
[86423.392085] hm2/hm2_5i25.0: version: 0
[86423.392092] hm2/hm2_5i25.0: timer_addr: 0x0C00
[86423.392099] hm2/hm2_5i25.0: status_addr: 0x0D00
[86423.392106] hm2/hm2_5i25.0: reset_addr: 0x0E00
[86423.392113] hm2/hm2_5i25.0: instance 0:
[86423.392121] hm2/hm2_5i25.0: param timeout_ns = 5000000
[86423.392128] hm2/hm2_5i25.0: pin has_bit = 0
[86423.392136] hm2/hm2_5i25.0: reg timer = 0x80000000
[86423.392145] HAL: exporting function 'hm2_5i25.0.read'
[86423.392155] HAL: creating parameter 'hm2_5i25.0.read.time'
[86423.392180] HAL: creating parameter 'hm2_5i25.0.read.tmax'
[86423.392203] HAL: exporting function 'hm2_5i25.0.write'
[86423.392212] HAL: creating parameter 'hm2_5i25.0.write.time'
[86423.392266] HAL: creating parameter 'hm2_5i25.0.write.tmax'
[86423.392304] HAL: exporting function 'hm2_5i25.0.read_gpio'
[86423.392313] HAL: creating parameter 'hm2_5i25.0.read_gpio.time'
[86423.392338] HAL: creating parameter 'hm2_5i25.0.read_gpio.tmax'
[86423.392362] HAL: exporting function 'hm2_5i25.0.write_gpio'
[86423.392371] HAL: creating parameter 'hm2_5i25.0.write_gpio.time'
[86423.392410] HAL: creating parameter 'hm2_5i25.0.write_gpio.tmax'
[86423.392448] hm2/hm2_5i25.0: registered
[86423.392456] hm2_5i25.0: initialized AnyIO board at 0000:00:12.0
[86463.503625] hm2_5i25.0: dropping AnyIO board at 0000:00:12.0
[86463.503646] hm2/hm2_5i25.0: unregistered
[86463.505820] hm2_pci: driver unloaded
[86463.505836] HAL: removing component 05
[86463.505920] RTAPI: module 5 exiting
[86463.505940] RTAPI: module 5 exited, name: 'HAL_hm2_pci'
[86463.505947] HAL: component 05 removed, name = 'hm2_pci'
[86463.522968] hm2: unloading
[86463.522984] HAL: removing component 04
[86463.522996] RTAPI: module 4 exiting
[86463.523019] RTAPI: module 4 exited, name: 'HAL_hostmot2'
[86463.523027] HAL: component 04 removed, name = 'hostmot2'
[86463.610985] HAL_LIB: removing kernel lib
[86463.611075] RTAPI: shmem 01 freed by module 01
[86463.611083] RTAPI: module 1 exiting
[86463.611103] RTAPI: module 1 exited, name: 'HAL_LIB'
[86463.611110] HAL_LIB: kernel lib removed successfully
[86463.620504] RTAPI: Exiting
[86463.620556] RTAPI: Exit complete
[86463.629321] RTAI[math]: unloaded.
[86463.776452] SCHED releases registered named ALIEN RTGLBH
[86463.791416] RTAI[malloc]: unloaded.
[86463.890756] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[86463.899489] I-pipe: Domain RTAI unregistered.
[86463.899513] RTAI[hal]: unmounted.
- Thank you received: 5298
16 Oct 2013 21:46 #39966
Replied by PCW on topic Something funny with my .hal created in pncconf
What are your 7I76 and 7I73 jumper settings?
16 Oct 2013 21:56 #39968
Well, it looks OK at the 5i25 end, it just isn't "seeing" any smart-serial modules.
I don't suppose you have the jumpers in the "setup" position?
Jumper W3 must be to the left
Here you go:
[86423.215049] hm2/hm2_5i25.0: Module Descriptor 3 at 0x0464: [86423.215058] hm2/hm2_5i25.0: General Function Tag: 193 (Smart Serial Interface) ... [86423.228548] hm2/hm2_5i25.0: sserial_num_instances = 1 [86423.228557] hm2/hm2_5i25.0: sec unit = 0, sec pin = 1 [86423.228564] hm2/hm2_5i25.0: sec unit = 0, sec pin = 1 [86423.228572] hm2/hm2_5i25.0: sec unit = 0, sec pin = 2 [86423.228579] hm2/hm2_5i25.0: sec unit = 0, sec pin = 2 [86423.228588] hm2/hm2_5i25.0: sec unit = 0, sec pin = 3 [86423.228595] hm2/hm2_5i25.0: sec unit = 0, sec pin = 3 [86423.228602] hm2/hm2_5i25.0: sec unit = 0, sec pin = 4 [86423.228609] hm2/hm2_5i25.0: sec unit = 0, sec pin = 4 [86423.228617] hm2/hm2_5i25.0: num channels = 4 [86423.228820] hm2/hm2_5i25.0: Smart Serial Firmware Version 38 [86423.228976] hm2/hm2_5i25.0: Start-mode = f01 [86423.228982] hm2/hm2_5i25.0: Start-mode = f03 [86423.228989] hm2/hm2_5i25.0: Start-mode = f07 [86423.228996] hm2/hm2_5i25.0: Start-mode = f0f [86423.269913] hm2/hm2_5i25.0: MD 3: 1x Smart Serial Interface v0: accepted, using 0
- Configuring LinuxCNC
- Configuration Tools
- PnCConf Wizard
- Something funny with my .hal created in pncconf
