Something funny with my .hal created in pncconf
16 Oct 2013 22:41 #39971 by macona
The only jumpers I have changed are the W2's on the 5i25 and the 7i76 and W1 on the 7i69. I remember looking at W3 last night and it is to the left.
I assume the second set of serial lines is just passed through to the terminal block through a differential driver. If that is the case even if there was something messed up with the 7i76 I still should be getting something on the 7i69. I see no comm activity on it's led.
16 Oct 2013 23:23 - 16 Oct 2013 23:24 #39976 by PCW
Weird... bad or partially plugged in cable maybe?
I dont see many things that could cause both the 7I76 field I/O and the 7I69 not to work
(only thing in common really is the cable and I think a 3.3V regulator on the non isolated side)
The whole card set may need to be returned to evaluate whats going on
Last edit: 16 Oct 2013 23:24 by PCW.
17 Oct 2013 09:37 #39990 by macona
I got a RMA for the card set. Before I send it off I decided to try it in another compter, an old P4 I had lying around. Installed a fresh copy of linuxcnc and dropped in my config files from the other computer. It works... Green light starts blinking on the i69.
Put it back in the other machine. Nothing, Try another PCI slot, nothing, try different power supply, nothing. The only thing I have not tried is reinstalling linuxcnc on that machine. Guess that is next. Any other ideas?
-Jerry
17 Oct 2013 11:18 #39991 by PCW
A re-install will very likely not make any difference.
Theres either an incompatibility of some kind with the non-working
motherboard and the 5I25 or a problem with the PCI interface on the
non-working MB.
For the driver to get as far as it did , it has to be a fairly subtle problem
(since config reads, config writes, and memory reads must be working)
17 Oct 2013 11:24 #39992 by macona
I was doing quite a bit of messing around trying to get a firewire camera working on the system and figured I might have messed something up. And you were right, a reinstall made no difference. This is an industrial PC system with a SBC on a ISA/PCI backplane. All the other cards work, USB, Wifi, etc. It must be this is just incompatible.
With this card, will it matter what kind of processor I am using? It's getting to a point where it is easier to find CoreDuos and stuff like that than old P4's.
17 Oct 2013 14:02 #39993 by macona
Got everything reinstalled in a different machine. Bad thing is I cant disable ACPI on this MoBo. Would this cause this random message I get on startup of LinuxCNC in dmesg:
[ 1222.442914] In recent history there were
[ 1222.442916] 3003862, 3029872, 2918310, 3317888, and 2671530
[ 1222.442918] elapsed clocks between calls to the motion controller.
[ 1222.442926] This time, there were 3531150 which is so anomalously
[ 1222.442928] large that it probably signifies a problem with your
[ 1222.442930] realtime configuration. For the rest of this run of
[ 1222.442932] EMC, this message will be suppressed.
[ 1222.442934]
17 Oct 2013 18:46 #40001 by andypugh
It shouldn't matter, no. Atoms work very nicely.
17 Oct 2013 22:27 #40017 by PCW
If you dont mind, can you try reinstalling the 5I25 in the industrial
PC system and then posting the results of lspci -vvv here?
(you can just post the 5I25 relevant part to save clutter)
There _may_ be any easy fix
18 Oct 2013 01:20 #40026 by macona
No, it's not a big deal. I'll give it a try tonight. The p4 it is working in right now shows jitter up to 350,000 every once in a while. It's does not seem to be an smi issue at this point, it just seems random.
18 Oct 2013 08:01 - 18 Oct 2013 08:03 #40030 by macona
macona@Laser:~$ lspci -vvv
00:00.0 Host bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX Host bridge (rev 03)
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
	Latency: 32
	Region 0: Memory at d0000000 (32-bit, prefetchable) [size=64M]
	Capabilities: <access denied>
	Kernel driver in use: agpgart-intel
	Kernel modules: intel-agp
00:01.0 PCI bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge (rev 03)
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 64
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
	I/O behind bridge: 0000d000-0000dfff
	Memory behind bridge: d4000000-d7ffffff
	Prefetchable memory behind bridge: 20000000-200fffff
	Secondary status: 66MHz+ FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
	BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B+
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Kernel modules: shpchp
00:07.0 ISA bridge: Intel Corporation 82371AB/EB/MB PIIX4 ISA (rev 02)
	Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
00:07.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev 01) (prog-if 80 [Master])
	Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 32
	Region 0: [virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=8]
	Region 1: [virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=1]
	Region 2: [virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=8]
	Region 3: [virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=1]
	Region 4: I/O ports at f000 [size=16]
	Kernel driver in use: ata_piix
00:07.2 USB Controller: Intel Corporation 82371AB/EB/MB PIIX4 USB (rev 01)
	Latency: 32
	Interrupt: pin D routed to IRQ 11
	Region 4: I/O ports at e000 [size=32]
	Kernel driver in use: uhci_hcd
00:07.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 02)
	Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin ? routed to IRQ 9
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c-piix4
00:11.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 62)
	Subsystem: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 32, Cache Line Size: 32 bytes
	Interrupt: pin A routed to IRQ 9
	Region 4: I/O ports at e400 [size=32]
00:11.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 62)
	Interrupt: pin B routed to IRQ 10
	Region 4: I/O ports at e800 [size=32]
00:11.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 65) (prog-if 20)
	Subsystem: VIA Technologies, Inc. USB 2.0
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin C routed to IRQ 5
	Region 0: Memory at d8018000 (32-bit, non-prefetchable) [size=256]
	Kernel driver in use: ehci_hcd
00:12.0 DPIO module: Device 2718:5125
	Subsystem: Device 2718:5125
	Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Interrupt: pin A routed to IRQ 11
	Region 0: Memory at d8000000 (32-bit, non-prefetchable) [size=64K]
00:13.0 Network controller: RaLink RT2561/RT61 rev B 802.11g
	Subsystem: Device 1948:3c83
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=slow >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Interrupt: pin A routed to IRQ 5
	Region 0: Memory at d8010000 (32-bit, non-prefetchable) [size=32K]
	Kernel driver in use: rt61pci
	Kernel modules: rt61pci
00:14.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev 46) (prog-if 10)
	Subsystem: VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller
	Latency: 32 (8000ns max), Cache Line Size: 32 bytes
	Interrupt: pin A routed to IRQ 10
	Region 0: Memory at d8019000 (32-bit, non-prefetchable) [size=2K]
	Region 1: I/O ports at ec00 [size=128]
	Kernel driver in use: ohci1394
	Kernel modules: firewire-ohci, ohci1394
01:00.0 VGA compatible controller: ATI Technologies Inc 3D Rage Pro AGP 1X/2X (rev 5c)
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping+ SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 32 (2000ns min), Cache Line Size: 32 bytes
	Region 0: Memory at d4000000 (32-bit, non-prefetchable) [size=16M]
	Region 1: I/O ports at d000 [size=256]
	Region 2: Memory at d6000000 (32-bit, non-prefetchable) [size=4K]
	[virtual] Expansion ROM at 20000000 [disabled] [size=128K]
	Kernel modules: atyfb
Last edit: 18 Oct 2013 08:03 by macona.
Time to create page: 0.195 seconds
