Something funny with my .hal created in pncconf
18 Oct 2013 08:19 #40031 by macona
Well, it's working on the industrial PC. I turned the FSB speed down from 133mhz to 100mhz and it works. But boy is the system slow at 700mhz (PIII)
I have another similar system with a slightly newer SBC and am going to try that board. If not I might look at finding a P4 SBC to go in this rack.
Here is the same dump:
sMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 64
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
	I/O behind bridge: 0000d000-0000dfff
	Memory behind bridge: d4000000-d7ffffff
	Prefetchable memory behind bridge: 20000000-200fffff
	Secondary status: 66MHz+ FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
	BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B+
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Kernel modules: shpchp
00:07.0 ISA bridge: Intel Corporation 82371AB/EB/MB PIIX4 ISA (rev 02)
	Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
00:07.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev 01) (prog-if 80 [Master])
	Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 32
	Region 0: [virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=8]
	Region 1: [virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=1]
	Region 2: [virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=8]
	Region 3: [virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=1]
	Region 4: I/O ports at f000 [size=16]
	Kernel driver in use: ata_piix
00:07.2 USB Controller: Intel Corporation 82371AB/EB/MB PIIX4 USB (rev 01)
	Latency: 32
	Interrupt: pin D routed to IRQ 11
	Region 4: I/O ports at e000 [size=32]
	Kernel driver in use: uhci_hcd
00:07.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 02)
	Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin ? routed to IRQ 9
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c-piix4
00:11.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 62)
	Subsystem: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 32, Cache Line Size: 32 bytes
	Interrupt: pin A routed to IRQ 9
	Region 4: I/O ports at e400 [size=32]
	Capabilities: <access denied>
00:11.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 62)
	Interrupt: pin B routed to IRQ 10
	Region 4: I/O ports at e800 [size=32]
00:11.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 65) (prog-if 20)
	Subsystem: VIA Technologies, Inc. USB 2.0
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin C routed to IRQ 5
	Region 0: Memory at d8018000 (32-bit, non-prefetchable) [size=256]
	Kernel driver in use: ehci_hcd
00:12.0 DPIO module: Device 2718:5125
	Subsystem: Device 2718:5125
	Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Interrupt: pin A routed to IRQ 11
	Region 0: Memory at d8000000 (32-bit, non-prefetchable) [size=64K]
	Kernel driver in use: hm2_pci
00:13.0 Network controller: RaLink RT2561/RT61 rev B 802.11g
	Subsystem: Device 1948:3c83
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=slow >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Interrupt: pin A routed to IRQ 5
	Region 0: Memory at d8010000 (32-bit, non-prefetchable) [size=32K]
	Kernel driver in use: rt61pci
	Kernel modules: rt61pci
00:14.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev 46) (prog-if 10)
	Subsystem: VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller
	Latency: 32 (8000ns max), Cache Line Size: 32 bytes
	Interrupt: pin A routed to IRQ 10
	Region 0: Memory at d8019000 (32-bit, non-prefetchable) [size=2K]
	Region 1: I/O ports at ec00 [size=128]
	Kernel driver in use: ohci1394
	Kernel modules: firewire-ohci, ohci1394
01:00.0 VGA compatible controller: ATI Technologies Inc 3D Rage Pro AGP 1X/2X (rev 5c)
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping+ SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 32 (2000ns min), Cache Line Size: 32 bytes
	Region 0: Memory at d4000000 (32-bit, non-prefetchable) [size=16M]
	Region 1: I/O ports at d000 [size=256]
	Region 2: Memory at d6000000 (32-bit, non-prefetchable) [size=4K]
	[virtual] Expansion ROM at 20000000 [disabled] [size=128K]
	Kernel modules: atyfb
Time to create page: 0.046 seconds
