5i25 + 7i85s +....
9 years 9 months ago - 9 years 9 months ago #85081 by andypugh
Replied by andypugh on topic 5i25 + 7i85s +....
Emanresu wrote: Above 2m/min i run into joint following error at the "Down-Ramp"
Up-Ramp and Movement up to 30m/min everything is just fine.
But as soon as i lift my Finger from the Arrow-key... GANG, fullstop.
This might be because the drives are not actually capable of braking fast enough.
But, it can also be caused by not setting a DEFAULT_LINEAR_ACCELERATION in the [TRAJ] section of the INI. So try that first.
linuxcnc.org/docs/devel/html/config/ini-...g.html#_traj_section
Last edit: 9 years 9 months ago by andypugh.
The following user(s) said Thank You: Emanresu
9 years 9 months ago #85091 by Emanresu
Replied by Emanresu on topic 5i25 + 7i85s +....
So i guess there is no other input PIN for axis then axis.0.motor-pos-fb.
Some Kind of "just look, dont use" PIN.
Here we go: No DEFAULT_LINEAR_ACCELERATION
[TRAJ] AXES = 3 COORDINATES = X Y Z LINEAR_UNITS = mm ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 8.00 MAX_LINEAR_VELOCITY = 500
I just dont understand why ACCeleration works and DECeleration leads into an error.
I use Leadshine EL5-1500. They have an integrated oscilloscope.
At an Acceleration of 100 ive just 0,008 missmatch. And at 500 like i set in Linux just 0,002.
Schould be ok tho. (2500 line encoder. So it wont be more precise then 0,002 anyway)
9 years 9 months ago #85094 by andypugh
Does adding the DEFAULT_LINEAR_ACCELERATION fix the problem?
9 years 9 months ago #85096 by Emanresu
Nope, still the same.
I also wonder how TRAJ works together with AXIS.
For example changing MAX_LINEAR_VELOCITY in TRAJ seems to affect nothing.
9 years 9 months ago #85097 by PCW
Replied by PCW on topic 5i25 + 7i85s +....
Are you using encoder feedback to close the position loop?
If so, loop tuning will be quite different than the local stepgen tuning
9 years 9 months ago #85098 by andypugh
The [TRAJ] settings only really have much effect with non-identity kinematics (which can include gantries, sometimes).
Is your stepgen_maxaccel bigger than the joint accel limit? (it needs to be, to give a bit of headroom)
Is LinuxCNC using the encoder or a step-generator to drive joint.N.motor-pos-fb ?
Time to create page: 0.116 seconds
