5i25 + 7i85s +....
9 years 10 months ago #84941 by PCW
Replied by PCW on topic 5i25 + 7i85s +....
1600 steps = 16mm motion so
100 steps = 1mm motion
so the scale is 100 (steps per mm)
9 years 10 months ago #84942 by Emanresu
Replied by Emanresu on topic 5i25 + 7i85s +....
Yep, so we both are better in calculating then my PC :)
9 years 10 months ago #84961 by Emanresu
Todd Zuercher was also right...
After a while of hand editing, it is almost more comfortable than pncconf.
Is it possible, that Linux CNC cant operate above 6000mm/min?
It doesnt matter, what my Stepscale is. Above 6000mm/min ill get a "joint 0 following error".
-> 500stp/mm * 6.000mm/min = 3.000.000stp/min -> 50Khz -> Error at about 6200mm/min
-> 100stp/mm * 6.000mm/min = 600.000stp/min -> 10Khz -> Error at about 6200mm/min
Open loop so far. No encoder.
9 years 10 months ago - 9 years 10 months ago #84963 by PCW
No, Linuxcnc has no important speed limitations
(I have a test config that does about 3 million mm/m = ~90 MPH and 10 MHz step rates)
If you get a following error, its probably a hal/ini file problem of some kind
If you post you hal and ini files I can probably see what's wrong
Last edit: 9 years 10 months ago by PCW.
9 years 10 months ago #84971 by Emanresu
I didnt know LinuxCNC is also used for Bullriding O.o
Sadly as a usual Windows user im accustomed to input fields, buttons and little popup infoboxes.
But after the last days i have to say, its amazing to work "the Linux way"!
All my respekt to you guys for creating an Software Package like this!
I just love the endless possibilitys!
And i figured my problem out. (*proud*)
PID MAX_OUTPUT was set to 100
Here is my HAL anyway. Im interested in your opinion about my segmentation.
For some reason i just realized how HAL works while i created my own order.
Warning: Spoiler!
9 years 10 months ago #84972 by andypugh
Replied by andypugh on topic 5i25 + 7i85s +....
Glad you sorted it out.
And any file layout that works and makes sense to you is OK, they are your files, after all :-)
(and yours are a lot neater than mine)
The following user(s) said Thank You: Emanresu
