5i25 + 7i85s +....
9 years 11 months ago #83124 by PCW
Replied by PCW on topic 5i25 + 7i85s +....
Dont know if its your issue but at the minimum you should set the PWM output type ( to 1 )
and PWM frequency ( to 5000 for the Spinx1 ) in your hal file
9 years 11 months ago #83130 by casetero
Replied by casetero on topic 5i25 + 7i85s +....
I have set that two things in the HAL file, but continues doing the same. I didnt set the control-type in the HAL file because i checked with HAL configuration and it showed 1 , so i guessed that was the predeterminated value.
With the configuration i have the TX6 of the 7i85s should change its state by changing the direction of rotation, shouldnt it??
Thank you.
9 years 11 months ago #83134 by casetero
If i wire the DIR to non-TX6 it works, because this PIN is always LOW, so it works clock-wise all the time.
But now i have the problem with the TX7, the SPIN1X is always sending 10 V ( the reference of my VFD), no matter which value has pwmgen.00.value. Furthermore, if i push the stop button, TX7 continues HIGH ( the voltimeter reads 3,7 V ), no matter what i do in linuxcnc, TX7 is always HIGH, like TX6.
I think my problem is that TX6 and TX7 are not controlable by linuxcnc. My version of linuxcnc is 2.7.4, should i upgrade??
Thank you.
9 years 11 months ago - 9 years 11 months ago #83141 by PCW
Are you sure you have a 7I85S, not a 7I85?
(check label on back of card)
This is very unlikely to be a LinuxCNC version dependent problem
(None of the PWM/driver code has changed for many years)
How is the 7I85S powered?
Last edit: 9 years 11 months ago by PCW.
9 years 11 months ago #83142 by casetero
I think is a 7i85s. How can i diferenciate it??
Actually i control 3 motors with step+dir. I think this can be done just by 7i85s, cant it?
In the page of mesanet i cant see any differences in the photos.
Thank you.
9 years 11 months ago - 9 years 11 months ago #83143 by casetero
I cant see the back of the card now because is mounted in a electric box, all wired. Im pretty sure that is a 7i85s, because i bought it with this post:
forum.linuxcnc.org/27-driver-boards/26525-mesa-doubt
When i did mesaflash --device 5i25 --readhmid before flashing it i saw sep/dir outputs. The 7i85 can handle step/dir outputs too?
I have stepgens working with it since i installed it.
Thank you.
EDIT: It is powered with the DB-25 paralel port cable from the 5i25.
Last edit: 9 years 11 months ago by casetero.
Time to create page: 0.134 seconds
