5i25 + 7i85s +....
9 years 11 months ago #82865 by casetero
Replied by casetero on topic 5i25 + 7i85s +....
I have already done that. In fact in the HAL configurator i see these PINs High (yellow):
hm2_5i25.0.gpio.002.out
hm2_5i25.0.gpio.002.is_output
But the PIN 13 of TB1 of the 7i85s continues low ( 0 V.)
Thank you.
9 years 11 months ago #82866 by PCW
Replied by PCW on topic 5i25 + 7i85s +....
try setting the out pin to 0
9 years 11 months ago #82867 by casetero
I change the state from high to low and continues 0 V. From low to high and continues 0 V.
The Pin 14 ( non-TX7 ) is always 5 V.
When i set num_stepgens=4, the PIN13 is always 5 V. So i guess the PIN isnt damaged, but there is something that blocks me to control it.
Thank you.
9 years 11 months ago #82868 by PCW
Very strange, maybe something wrong in the hal file
9 years 11 months ago #82870 by casetero
Ok, tomorrow i will try with STX0, the outoput of SERIAL of the 7i85s. Is this PIN suitable for my needs??
Another question, when i will install the 5i25_7i85sspx2i.bit, will i be able to use TX7 for ENABLE and TX6 for PWM, or TX7 wont be able to do gpio??
Thank you!!
9 years 11 months ago #82875 by PCW
Just tried this here:
LinuxCNC 2.7.7, Debian Wheezy
5I25 --> P3 --> 7I85S
5i25_7i85sx2.bit config, 3 stepgens enabled
setp hm2_5i25.0.gpio.002.is_output true
setp hm2_5i25.0.gpio.002.out true
setp hm2_5i25.0.gpio.002.out false
toggle 7I85S TB1 pins 13/14
setp hm2_5i25.0.gpio.003.is_output true
setp hm2_5i25.0.gpio.003.out true
setp hm2_5i25.0.gpio.003.out false
toggle 7I85S TB1 pins 11/12
Time to create page: 0.076 seconds
