5i25 + 7i85s +....
10 years 4 months ago #75334 by PCW
Replied by PCW on topic 5i25 + 7i85s +....
Ability to use muxed encoder pins as general purpose inputs
was one reason the A,B.INDEX input pins were added to the encoder driver
Normally you would set the inputs to TTL mode
The encoder inputs are then TTL compatible with a 2K pullup to 5V
10 years 4 months ago #75560 by casetero
Replied by casetero on topic 5i25 + 7i85s +....
Hi again,
Ive been fighting with the 7i85s posibilities and finally i got my system working properly. Linuxnc is able to know which limit is being activated allowing the movement in the right direction of the axis, and not allowing in the wrong direction.
The 7i85s, as PCW said, can handle these PINS as GPIO´s too. It works fine.
PCW i will send you and email requesting you a Spin1x right now.
Thank you all.
10 years 4 months ago #75612 by casetero
I´ve realized that i can make the purchase of the card via web.
Do i need any special connector or cable to link the spin1x to my system?
I need to know it to purchase all the items i need for my purpose.
Thank you all.
10 years 4 months ago #75645 by PCW
No special connector needed but you do need 3 output bits:
PWM
ENA
DIR
(or 2 if you dont need to reverse)
9 years 11 months ago #82604 by casetero
Hi again,
Im going to wire my SPIN1X. I have some doubts at respect.
I have to supply the SPIN1X with 5V, independently of which is my reference voltage of my VFD is ( in this case 10V), havent i??
If this is true, where do i have to wire my VFD reference voltage?? I suposse is 10 V to SP+ and 0 V to SP- , but as i see in the manual of the SPIN1X these are output PINS, so im confused.
In the manual of my VFD i have one PIN that says " Output power supply of frequency reference". I suppose this will go to SP+.
I have another PIN that says " Common Value of frequency reference". I suppose this will go to SP-.
And another PIN that says " Input of frequency reference". I suppose this will go to SPV.
Am i correct??
Thank you very much!!
9 years 11 months ago #82605 by andypugh
Replied by andypugh on topic 5i25 + 7i85s +....
Just wire as described in the VFD manual, treating CCW+ and CCW- as a reverse push-button, CW+ and CW- as a forward button and ENA+ ansd ENA- as an ON switch. Then SP+, SP- and SPV are wired in the same place as a speed potentiometer.
Unlike a physical button, the polarity of the switch outputs matters.
