5i25 + 7i85s +....
9 years 11 months ago - 9 years 11 months ago #82829 by casetero
Replied by casetero on topic 5i25 + 7i85s +....
Sorry for the delay.
My 7i85s is attached to the DB25 on bracket of the 5i25. So i guess the PIN i have to use is the hm2_5i25.0.gpio.019.out.
I have set the HAL file to num_stepgens=3.
The thing is that the LED of the SPIN1X of the ENABLE (green one) is always on. I change the value of the hm2_5i25.0.gpio.019.out to 1 with this line:
halcmd setp hm2_5i25.0.gpio.019.out 1
In fact, i see in the HAL configurator that this PIN change his color to yellow ( i guess that means that this PIN is ON). But the LED of the SPIN1X is always on, so i think im doing something wrong.
Thank you!
Last edit: 9 years 11 months ago by casetero.
9 years 11 months ago #82830 by PCW
Replied by PCW on topic 5i25 + 7i85s +....
Again: You probably want to use 5i25_7i85sspx2.bit since it has PWM gens on TX6 and TX7 (on both P3 and P2)
( this config puts the PWM generator that the SPINX1 requires in place of Stepgen3 on P3)
If you want to play around with the GPIO pins, note that GPIO19 is on P2 NOT the DB25 (P3)
GPIO 2 is the GPIO that drives TX7 on P3
9 years 11 months ago #82831 by casetero
When i will install the 5i25_7i85sspx2.bit, then the TX7 and TX6 will be PWM only? I would like to use one for PWM control of the SPIN1X and the other one to ENABLE.
Im trying to do this before because i want to be capable of control my SPIN1X before messing up with the PWM signal. I have tried with the hm2_5i25.0.gpio.002.out:
halcmd setp hm2_5i25.0.gpio.002.out 1
The LED for ENABLE continues always ON, no matter if the hm2_5i25.0.gpio.002.out PIN is set to 1 or 0.
Does affect here the line of the HAL file sserial_port_0=000xxx ??
Thank you!
9 years 11 months ago #82834 by PCW
That suggests you have the DB25 pinout wrong
Rather than wire up the SPINX1, check the DB25 pins with a voltmeter
ALL I/O pins should be high before LinuxCNC is launched
9 years 11 months ago #82863 by casetero
I´ve been testing the 7i85s with a voltimeter.
When I launch Linuxcnc with num_stegens=3 the PIN 13 of TB1 ( where is located the TX7) is set as 0 V.
When I launch Linuxcnc with num_stegens=4 the PIN 13 of TB1 ( where is located the TX7) is set as 5 V.
I think this is normal.
The problem is that i can´t control the state of this PIN via halcmd. I guess that when linuxcnc launched with num_stegens=3, I should be capable of change the state of the PIN 13 of TB1 by the command:
But the PIN continues showing 0 V.
The PIN 14 of TB1 ( where is located non-TX7) works normally and always is the non state of TX7.
Maybe the ENABLE PIN of the SPIN1X is not wired in the correct place. Ive wired it at the PIN 13 of TB1 of the 7i85s daughter card.
Thank you!!
9 years 11 months ago - 9 years 11 months ago #82864 by PCW
To get an GPIO output to work you first need to set the GPIO pin into output mode:
halcmd setp hm2_5i25.0.gpio.002.is_output 1
Last edit: 9 years 11 months ago by PCW.
Time to create page: 0.250 seconds
