Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
9 years 2 weeks ago #100288 by andypugh
Do you mean this page: wiki.linuxcnc.org/cgi-bin/wiki.pl?SpindleOrient
Or the other one? wiki.linuxcnc.org/cgi-bin/wiki.pl?SpindleOrientation
I should perhaps admit that I have never actually needed to set up spindle-orientation on a real machine.
However, it is configured on this virtual machine:
github.com/LinuxCNC/linuxcnc/blob/master...olchange/spindle.hal
You can run that config (safely, even connected to your real machine) from the config picker:
sim/axis/vismach/VMC-toochange
9 years 1 week ago #100625 by zinsade
Replied by zinsade on topic This post is for "Andypugh"
Hello Andy,
You write:
I mean both sides.
I've seen the flow chart.
However, I do not yet understand the basic relationships, in particular the connection of the inputs of the encoder to the spindle output. It is an -A + A, -B + B, -Z + Z encoder with 1250 pulses per revolution, where -Z + Z is the index signal. I use a 5i25-7i76 combination. The encoder I have connected and I can see the pins in the Hal.
The VMC simulated machine from the Linuxcnc selection I have looked at me but can not connect to my real machine. I can not recognize the connections to my 7i76 there.
Best regards from Germany
Peter
9 years 1 week ago #100629 by andypugh
It would be almost identical with a 7i76. Except that the "encoder.N.." pins become "hm2_5i25.0.encoder.00..." and the VFD outputs become hm2_5i25.0.7i76.0.0.spindir / spinena / spinout.
9 years 1 week ago #100697 by zinsade
Hello Andy,
I can not do it.
the following error appears:
>>> hal: 86: signal 'spindle-pwm' of type 'bit' can not add pin 'hm2_5i25.0.7i76.0.0.spinout' of type 'float' <<<
What is wrong?
This is my .hal
# Dateiname = 8AMP-Test-Spindel-vismach.hal ############################################################ #--- 8AMP-Test-Spindel-vismach.hal ---Stand 2017-10-22 ---# ############################################################ #----------------------------------------------------------- # HAL config file for vismach simulation of vertical milling machine # This file deomstrates closed-loop spindle control in both position and # Velocity modes. # see http://wiki.linuxcnc.org/cgi-bin/wiki.pl?SpindleOrient for a diagram # Note that the connections of the signals to "hardware" are all in the # sim_vmc.hal file rather than here # First load 2x pid components. These would normally have to be loaded at # the same time as the Axis PID components # Initialize the pwmgen ------ nachgetragen loadrt pwmgen output_type=0 addf pwmgen.update servo-thread addf pwmgen.make-pulses servo-thread setp pwmgen.0.pwm-freq 100.0 #setp pwmgen.0.min-dc 0.18 setp pwmgen.0.scale 400 #setp pwmgen.0.dither-pwm true loadrt pid num_chan=2 addf pid.0.do-pid-calcs servo-thread # Velocity addf pid.1.do-pid-calcs servo-thread # Position loadrt orient addf orient.0 servo-thread #loadrt mux2 -- This has already been loaded in the sim_vmc.hal loadrt mux2 addf mux2.0 servo-thread # chooses which pid output goes to the spindle speed control #Use this to detect that the spindle is oriented #in the 2.8 release there will be a pin for this as an output of the orient comp #and the edge-detector is not needed #loadrt near count=1 (loaded in sim_vmc.hal) loadrt near count=1 loadrt edge addf near.0 servo-thread addf edge.0 servo-thread setp edge.0.both 0 setp edge.0.in-edge 0 setp edge.0.out-width-ns 10000000 #----------nachgetragen # connect the HAL encoder inputs to the real encoder. net spindle-phase-a encoder.1.phase-A <= hm2_5i25.0.encoder.00.input-a net spindle-phase-b encoder.1.phase-B <= hm2_5i25.0.encoder.00.input-b net spindle-index encoder.1.phase-Z <= hm2_5i25.0.encoder.00.input-index net spindle-pos pid.1.feedback orient.0.position net spindle-vel pid.0.feedback hm2_5i25.0.encoder.00.velocity net spindle-vel-cmd motion.spindle-speed-out pid.0.command net spindle-vel-pid pid.0.output mux2.0.in0 net spindle-pos pid.1.feedback orient.0.position near.0.in1 hm2_5i25.0.encoder.00.position net spindle-pos-cmd orient.0.command pid.1.command near.0.in2 net spindle-angle motion.spindle-orient-angle orient.0.angle net spindle-pos-pid pid.1.output mux2.0.in1 setp near.0.difference 0.0005 net spindle-in-pos-raw near.0.out edge.0.in #not needed v2.8+, use orient.0.is-oriented net spindle-in-pos edge.0.out motion.spindle-is-oriented # this switches modes net orient-mode motion.spindle-orient orient.0.enable pid.1.enable mux2.0.sel net velocity-mode motion.spindle-on pid.0.enable pwmgen.0.enable net orient-dir motion.spindle-orient-mode orient.0.mode # this is simple for the simulated spindle. net spindle-cmd mux2.0.out #for a real spindle run by a VFD loadrt abs count=1 addf abs.0 servo-thread net spindle-cmd mux2.0.out abs.0.in net spindle-cmd-abs abs.0.out pwmgen.0.value net spindle-pwm pwmgen.0.pwm hm2_5i25.0.7i76.0.0.spinout net spindle-fwd abs.0.is-positive hm2_5i25.0.7i76.0.0.spindir # Tune the PID from the INI values setp pid.0.Pgain [SPINDLE_9]PGAIN_V setp pid.0.Igain [SPINDLE_9]IGAIN_V setp pid.0.Dgain [SPINDLE_9]DGAIN_V setp pid.0.FF0 [SPINDLE_9]FF0_V setp pid.0.FF1 [SPINDLE_9]FF1_V setp pid.1.Pgain [SPINDLE_9]PGAIN_P setp pid.1.Igain [SPINDLE_9]IGAIN_P setp pid.1.Dgain [SPINDLE_9]DGAIN_P setp pid.1.FF0 [SPINDLE_9]FF0_P setp pid.1.FF1 [SPINDLE_9]FF1_P #-----------------------------------------------------------
best regards
peter
9 years 1 week ago #100698 by PCW
That hal file seems like it came from a parallel port configuration so not really suitable for a 5I25/7I76
I would start with a PNCCONF created configuration for the 5I25/7I76
9 years 1 week ago #100699 by andypugh
peter: I think the rest is OK, but the spindle pwm is for a parallel port.
Peter: You actually have too _much_ in the HAL file. Delete all references to the pwmgen HAL component, and connect the abs function outputs directly to the 7i76 spindle pins.
You also don't need this section:
The only 7i76 encoder pins that you need in the HAL are the position and velocity output pins.
Time to create page: 0.087 seconds
