- Thank you received: 127
rodw wrote: Have a look at lut5 as that gives you 5 bits of input.
It is probably something you could do with a mux. You need 5 input bits so probably mux_generic using “ff32”
I might have done this if the hi/lo ratios could have been locked down to a simple multiple of the base ratio but that did not appear to be the case.
pin out float speed "speed in RPM";
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
setp hm2_7i76e.0.encoder.04.counter-mode 0
setp hm2_7i76e.0.encoder.04.filter 1
setp hm2_7i76e.0.encoder.04.index-invert 0
setp hm2_7i76e.0.encoder.04.index-mask 0
setp hm2_7i76e.0.encoder.04.index-mask-invert 0
# setp hm2_7i76e.0.encoder.00.scale [SPINDLE_9]ENCODER_SCALE
net spindle-revs <= hm2_7i76e.0.encoder.04.position
net spindle-vel-fb-rps <= hm2_7i76e.0.encoder.04.velocity
net spindle-index-enable <=> hm2_7i76e.0.encoder.04.index-enable
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
setp hm2_7i76e.0.7i76.0.0.spinout-scalemax 2400
setp hm2_7i76e.0.7i76.0.0.spinout-maxlim 2500
net spindle-enable hm2_7i76e.0.7i76.0.0.spinena
net spindle-vel-cmd-rpm-abs hm2_7i76e.0.7i76.0.0.spinout
net spindle-ccw hm2_7i76e.0.7i76.0.0.spindir
Lo is 50% of Hi or do I misunderstand this?
