Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
8 years 10 months ago #103440 by tecno
Have today 3D printed some parts for the gearbox discussed earlier.
Will be glued to housing
SMC D-Y7P
Arm to be glued on selector.
Will try to get the inductive sensor for Hi/Lo gear fixed hopefully tomorrow.
8 years 10 months ago #103442 by rodw
8 years 10 months ago #103443 by tecno
Gday Rod, thanks.
I hope it will serve me well.
8 years 10 months ago #103461 by tecno
So now also Hi / Lo gear detector in place. Using Contrinex LHK-3031-303 with adjustable 'focus'.
Time to install the cables to a RJ45 connector
8 years 10 months ago #103487 by tecno
Cabling ready and tested so now it is time to tinker how to get this all working.
With above I get 100 to 2500 rpm, spindle motor fixed to high speed = 2850 rpm and Hi / Lo + Gears A to E.
So what would be the best way to get this working? Yes there are combinations of settings allowing two ranges.
Any pointers on what to read?
8 years 10 months ago #103488 by rodw
Have a look at lut5 as that gives you 5 bits of input. Its pretty cryptic but I am sure Andy will help you. He's the expert on it.
I think once you resolve lut 5 to a speed, you should be able to use a mux2 to multiply the result by 1 or 2 depending on the hi/lo gear selection.
Time to create page: 0.206 seconds
