Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
9 years 1 month ago #98819 by tecno
Done some editing to HAL and now I have encoder working as well so G33.1 is functional
........encoder.00 to encoder.04
---Encoder feedback signals/setup---
setp hm2_7i76e.0.encoder.04.counter-mode 0
setp hm2_7i76e.0.encoder.04.filter 1
setp hm2_7i76e.0.encoder.04.index-invert 0
setp hm2_7i76e.0.encoder.04.index-mask 0
setp hm2_7i76e.0.encoder.04.index-mask-invert 0
net spindle-revs <= hm2_7i76e.0.encoder.04.position
net spindle-vel-fb-rps <= hm2_7i76e.0.encoder.04.velocity
net spindle-index-enable <=> hm2_7i76e.0.encoder.04.index-enable
9 years 1 month ago #98911 by andypugh
Glad to hear it, and I think this means that your 7i76 cards are not broken?
Is it all working now, or are there remaining problems?
9 years 1 month ago #98915 by tecno
Hello Andy,
First of all I am very grateful of all help I have received from you and others on this forum.
The 7i76e in my milling machine appears to be OK.
( the other for lathe is not OK pin 13 is busted, but more of this in another thread later on)
Stil have to tweak motor parameters but I think I can do this if not I will ask for help.
Remaining, well it is time to get all added peripherals to work. First in line is my MPG, see link below.
forum.linuxcnc.org/24-hal-components/332...of-3-to-output#98841
Update as regards the selector swithes, X1-X10-X100 works OK looking with Halshow.
Off - X - Y - Z is behaving odd so it might be so that I have to move those wires to other Inputs.
Will get back to this later today maybe. Sun is shining and have some gardening to do before upcoming rainstorm.
9 years 1 month ago #98938 by tecno
Problem solved = 1 wire not seated properly.
9 years 1 month ago #99002 by tecno
Here my config to my milling machine that now is working with basics.
File Name: mpg_2017-09-15-3.hal
File Size:2.06 KB
File Name: combimillx...15-4.ini
File Size:4.69 KB
File Name: combimillx...15-4.hal
File Size:16.48 KB
Maybe this can be of help to other newbies like me :)
9 years 3 weeks ago #100231 by zinsade
Replied by zinsade on topic This post is for "Andypugh"
Hello Andy,
I know it is not the right place to write this.
But I see no other way to contact you.
In the Liuxcnc-WIKI in the "SpindleOrientation" section, only one part is shown for the spindle orientation.
To be able to follow your idea I am missing a lot of information.
Is it possible to get the corresponding files?
Can you post all files for a really working machine here?
Only for information. I use a 5i76 / 7i76 combination with a Lenze 8201-E VFD under Linuxcnc V2.7.11.
Sorry, but I do not speak English and use the Google translator here.
Best regards
Peter
Time to create page: 0.144 seconds
