- Thank you received: 13
Stephanisk wrote: Hi Todd, it looks like you know everything. You don't have time to spend a few days in Bruges and give me some classes? Or maybe where you live
I kind of read the same that 6i25 is same as 5i25 with a small change. How I do that I will ask once I have the hardware.
I would take the hardware they can deliver quickly from monstercnc, and that would be the 6i25 and 2x 7i85s. Seems to me more logic to use the same cards, I guess it would be easier than different cards. It seems like I would have sufficient input /outputs left to connect probes and limits-homes and e stop after connecting the 6 encoders and 6 step/dirs.
Todd Zuercher wrote: I am not certain if the 6i25 is directly supported either.(I think you have to set up the config for a 5i25 then edit the hal files to suit (a simple find and replace command).
