5i25+7i76 wired pendant help please
- Toolman321
- Topic Author
9 years 2 weeks ago #100758
by Toolman321
5i25+7i76 wired pendant help please was created by Toolman321
Hello I have the I/0 boards 5i25 and 7i76. So far I managed to wire up a stepper drive and get it to move. I’ve no other experience with linuxcnc or Mesa cards.
I recently bought an mpg pendant which is a 100ppr pulse generator with two switches, one for axis select x y z a and one for increments.
I would like to connect the mpg to the 7i76 and make it work but I don’t know how to do that and your help will be much appreciated.
Many thanks
Many thanks
- Thank you received: 2620
9 years 2 weeks ago #100768
Replied by andypugh on topic 5i25+7i76 wired pendant help please
You probably want to use an mpg encoder on the 7i76 rather than the spindle encoder. To do that you need to set the 7i76 to mpg mode. This converts some of the GPIO pins to encoder inputs.
Page 18 here: www.mesanet.com/pdf/parallel/7i76man.pdf
Note that these are single-ended encoders, so I think you just ignore the /A and /B pins.
To set the 7i76 to MPG mode change the "loadrt hm2_pci" line in the HAL file to include config="sserial_port_0=20xxxxxx"
(keep anything else that already exists in that config string)
Then you should see hm2_5i35.0.7i76.enc0 and enc1 which should increment as you turn the knob.
The following user(s) said Thank You: Toolman321
9 years 2 weeks ago #100811
Replied by rodw on topic 5i25+7i76 wired pendant help please
Once you get it enabled, there is a worked example of a single axis MPG for a 7i76e on my build thread
forum.linuxcnc.org/show-your-stuff/32029...tter-build?start=200
You just need to add the axis selection switch to this which is not difficult and there is a good example in the MPG docs.
linuxcnc.org/docs/html/examples/mpg.html
- Toolman321
- Topic Author
9 years 2 weeks ago #100851
by Toolman321
Replied by Toolman321 on topic 5i25+7i76 wired pendant help please
‘Then you should see hm2_5i35.0.7i76.enc0 and enc1 which should increment as you turn the knob.’
I think I’ve changed to mode 2 and I’ve been back through the pncconf wizard and it all looks the same to me?
Can you tell me where I might see that please? Is it in the Hal file?
Many thanks
Many thanks
9 years 2 weeks ago #100855
Yes, you will see it in the HAL. Pncconf has done its job at this point, you are at the hand-customisation stage.
(and pncconf doesn't know about smart serial modes as far as I know, and will in fact revert your config if you run it)
I would now suggest wiring up the pendant ant watching the HAL pins change in Halshow (use the Watch tab, as that updates live). If the wiring is correct you should see the encoder counts change and various things happen on the GPIO.
9 years 2 weeks ago #100856
You won't see anything in pnccnonf. Its designed to create a basic config that gets your steppers or servos running.
Everything is in your HAL file as per my example and you have to edit it by hand from here on. There is a LinuxCNC module called Halshow that will show you the status of the pins in real time. It is usually available from a menu option or button in the GUI you are using. Thats what you need to use to see enc1 incrementing.
- Toolman321
- Topic Author
8 years 4 months ago #112214
by Toolman321
I finally read all of the information and now I have all the connectors I need to make the pendant work, however I’ve now changed the machine design slightly and now I’m looking to interface the pendant directly(or indirectly) to the Mesa 5i25, via the 26 pin header (p2 I think).
Is it possible I can use another breakout board on this connector just for the pendant, or would I be best using the redundant paraport on the mb?
My reason for asking this is because I’ve changed enclosures and now I have all the pc hardware in one box including 5i25, and in the other box I have the machine control electronics including the 7i76.
Many thanks
Many thanks
8 years 4 months ago #112215
If there is space in the pendant you could consider a 7i73 connected to the 7i76 serial expansion port.
But if you want to connect direct to the extra port on the 5i25 you can.
With care you can connect directly (I have done it many times to other FPGA boards)
I have found these convenient for connecting discrete wires to Mesa board headers: uk.rs-online.com/web/c/connectors/pcb-co...searchTerm=M20%20pcb
They don't have a 2 x 13 that is an exact match to the 5i25, but you can cut them down and put more than one in the header side by side, etc. You may not need all the pins anyway.
Note that terminals are extra and need a rather small crimping tool.
- Toolman321
- Topic Author
8 years 4 months ago #112403
by Toolman321
Thanks for the useful information provided here.
Atm I have a 7i76 in p3 of my 5i25, is there any reason why I can’t use a common 5 axis bob plugged into p2?
Pncconf is currently configured for 2x7i76.
Many thanks
Many thanks
8 years 4 months ago #112406
You can use a cheap Mach3 BoB connected to P2. Breakout cables to connect a back-panel 25-pin D-sub are inexpensive:
www.amazon.com/s/ref=nb_sb_noss?url=sear...arallel++port+header
If you limit the number of stapgens and smart-serial ports in the config="" part of the HAL file then all those pins will be seen as GPIO. (And you will probably find that there is a handy set of encoder pins available too).
Time to create page: 0.079 seconds
