2 steppers on one axis 5i25 - 7i76
- Thank you received: 4154
21 Feb 2018 20:15 #106312
Save your config. I think that master might apply a script to change your config when you open it again.
Compare it with what CNCzombie posted but basically start with the ini file and replace the geometry with XYZ and the trivkins stuff to XYZY. Remove the A AXIS. Make sure the 2 Y joints are set identically.
You might like to look in the hal file and edit the stepgen settings so they refer to y1 instead of a. Don't forget the loadrt and addf statements as well. I'm not 100% sure this is required as the joints rule supreme in master.
Don't worry about Chris's comments about experience. I knew no more than you when I got this going.... Talk about the deep end.
Chis, if its OK, I'll send you an email via the forum and sort out the config sample from there. I think it would be good to sort out pncconf a bit better.
Replied by rodw on topic 2 steppers on one axis 5i25 - 7i76
Ok, I updated to 2.8. I think I want the joints. I created a .hal and .ini file in pncconf using the X Y Z A. How do I convert the A to a Y?
- DanMN
- Thank you received: 10
21 Feb 2018 20:23 #106313
by DanMN
Replied by DanMN on topic 2 steppers on one axis 5i25 - 7i76
It's punch list time. Here's my stab at the correct INI file. I removed the A-axis references and used Joint_3 as the mirror image of Joint_1. Those two sections will ALWAYS need to stay in sync in every way. I usually edit one and then paste the edits over the top of the second joint to make sure I don't miss any changes.
I changed the kins and traj coordinates to match a gantry config - in your case it's XYZY
I'll spend a few minutes looking through the HAL, and see what I can give you jump start that. There are a lot more edits in the HAL than the INI at this point. No guarantees I'll be 100%, but you can tweak this to perfection. I have mine working, so I'm not far off.
# Generated by PNCconf at Wed Feb 21 12:46:39 2018
# overwritten when you run PNCconf again
[EMC]
MACHINE = bob_ross
DEBUG = 0
VERSION = 1.0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/chadrat6458/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = bob_ross.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYZY
[TRAJ]
COORDINATES = X Y Z Y
MAX_ANGULAR_VELOCITY = 360.00
DEFAULT_ANGULAR_VELOCITY = 36.00
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 2.50
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Joint 0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
STEPGEN_MAXVEL = 31.25
STEPGEN_MAXACCEL = 937.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
# Axis X
[AXIS_X]
MAX_VELOCITY = 25.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
# Joint 1 - the first joint of Y-axis
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
# Joint 3 - the 2nd joint of Y-axis
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_Y]
MAX_VELOCITY = 25.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
# Joint 2
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0.0
# Axis Z
[AXIS_Z]
MAX_VELOCITY = 25.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.01
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
[EMC]
MACHINE = bob_ross
DEBUG = 0
VERSION = 1.0
[DISPLAY]
DISPLAY = axis
INTRO_TIME = 5
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
[HOSTMOT2]
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
[HALUI]
[KINS]
JOINTS = 4
[TRAJ]
LINEAR_UNITS = mm
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
# Joint 0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
# Axis X
[AXIS_X]
MAX_VELOCITY = 25.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_Y]
MAX_VELOCITY = 25.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
# Joint 2
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0.0
# Axis Z
[AXIS_Z]
MAX_VELOCITY = 25.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.01
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
- DanMN
21 Feb 2018 20:39 #106314
by DanMN
Here's my stab at the HAL. No guarantees. You may have to track down any differences in the configuration related to the original A-axis being rotary vs. linear. I gave it a look-over and nothing mugged me -- but that doesn't mean there isn't something buried somewhere.
I didn't rename the PID, so you'll have "a" references all through your "Y2" config. If the cosmetics bother you, it's changeable. Your limit switch signals will be prefixes with "a", for instance. In my config, I changed it to be dead obvious to me, so if you look through my examples, you can see how I formatted that.
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.a,pid.s
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.a.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_5i25.0.write servo-thread
# external output signals
# external input signals
# JOINT X
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# Step Gen signals/setup
setp hm2_5i25.0.stepgen.02.dirsetup [JOINT_0]DIRSETUP
setp hm2_5i25.0.stepgen.02.dirhold [JOINT_0]DIRHOLD
setp hm2_5i25.0.stepgen.02.steplen [JOINT_0]STEPLEN
setp hm2_5i25.0.stepgen.02.stepspace [JOINT_0]STEPSPACE
setp hm2_5i25.0.stepgen.02.position-scale [JOINT_0]STEP_SCALE
setp hm2_5i25.0.stepgen.02.step_type 0
setp hm2_5i25.0.stepgen.02.control-type 1
setp hm2_5i25.0.stepgen.02.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.02.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output <= hm2_5i25.0.stepgen.02.velocity-cmd
net x-pos-fb <= hm2_5i25.0.stepgen.02.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => hm2_5i25.0.stepgen.02.enable
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# JOINT Y1
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror .0005
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_5i25.0.stepgen.00.dirsetup [JOINT_1]DIRSETUP
setp hm2_5i25.0.stepgen.00.dirhold [JOINT_1]DIRHOLD
setp hm2_5i25.0.stepgen.00.steplen [JOINT_1]STEPLEN
setp hm2_5i25.0.stepgen.00.stepspace [JOINT_1]STEPSPACE
setp hm2_5i25.0.stepgen.00.position-scale [JOINT_1]STEP_SCALE
setp hm2_5i25.0.stepgen.00.step_type 0
setp hm2_5i25.0.stepgen.00.control-type 1
setp hm2_5i25.0.stepgen.00.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.00.maxvel [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd <= joint.1.motor-pos-cmd
net y-vel-cmd <= joint.1.vel-cmd
net y-output <= hm2_5i25.0.stepgen.00.velocity-cmd
net y-pos-fb <= hm2_5i25.0.stepgen.00.position-fb
net y-pos-fb => joint.1.motor-pos-fb
net y-enable <= joint.1.amp-enable-out
net y-enable => hm2_5i25.0.stepgen.00.enable
net y-home-sw => joint.1.home-sw-in
net y-neg-limit => joint.1.neg-lim-sw-in
net y-pos-limit => joint.1.pos-lim-sw-in
# JOINT Y2
setp pid.a.Pgain [JOINT_3]P
setp pid.a.Igain [JOINT_3]I
setp pid.a.Dgain [JOINT_3]D
setp pid.a.bias [JOINT_3]BIAS
setp pid.a.FF0 [JOINT_3]FF0
setp pid.a.FF1 [JOINT_3]FF1
setp pid.a.FF2 [JOINT_3]FF2
setp pid.a.deadband [JOINT_3]DEADBAND
setp pid.a.maxoutput [JOINT_3]MAX_OUTPUT
setp pid.a.error-previous-target true
setp pid.a.maxerror .0005
net a-index-enable <=> pid.a.index-enable
net a-enable => pid.a.enable
net a-pos-cmd => pid.a.command
net a-vel-cmd => pid.a.command-deriv
net a-pos-fb => pid.a.feedback
net a-output => pid.a.output
setp hm2_5i25.0.stepgen.01.dirsetup [JOINT_3]DIRSETUP
setp hm2_5i25.0.stepgen.01.dirhold [JOINT_3]DIRHOLD
setp hm2_5i25.0.stepgen.01.steplen [JOINT_3]STEPLEN
setp hm2_5i25.0.stepgen.01.stepspace [JOINT_3]STEPSPACE
setp hm2_5i25.0.stepgen.01.position-scale [JOINT_3]STEP_SCALE
setp hm2_5i25.0.stepgen.01.step_type 0
setp hm2_5i25.0.stepgen.01.control-type 1
setp hm2_5i25.0.stepgen.01.maxaccel [JOINT_3]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.01.maxvel [JOINT_3]STEPGEN_MAXVEL
net a-pos-cmd <= joint.3.motor-pos-cmd
net a-vel-cmd <= joint.3.vel-cmd
net a-output <= hm2_5i25.0.stepgen.01.velocity-cmd
net a-pos-fb <= hm2_5i25.0.stepgen.01.position-fb
net a-pos-fb => joint.3.motor-pos-fb
net a-enable <= joint.3.amp-enable-out
net a-enable => hm2_5i25.0.stepgen.01.enable
net a-home-sw => joint.3.home-sw-in
net a-neg-limit => joint.3.neg-lim-sw-in
net a-pos-limit => joint.3.pos-lim-sw-in
# JOINT Z
setp pid.z.Pgain [JOINT_2]P
setp pid.z.Igain [JOINT_2]I
setp pid.z.Dgain [JOINT_2]D
setp pid.z.bias [JOINT_2]BIAS
setp pid.z.FF0 [JOINT_2]FF0
setp pid.z.FF1 [JOINT_2]FF1
setp pid.z.FF2 [JOINT_2]FF2
setp pid.z.deadband [JOINT_2]DEADBAND
setp pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_5i25.0.stepgen.03.dirsetup [JOINT_2]DIRSETUP
setp hm2_5i25.0.stepgen.03.dirhold [JOINT_2]DIRHOLD
setp hm2_5i25.0.stepgen.03.steplen [JOINT_2]STEPLEN
setp hm2_5i25.0.stepgen.03.stepspace [JOINT_2]STEPSPACE
setp hm2_5i25.0.stepgen.03.position-scale [JOINT_2]STEP_SCALE
setp hm2_5i25.0.stepgen.03.step_type 0
setp hm2_5i25.0.stepgen.03.control-type 1
setp hm2_5i25.0.stepgen.03.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.03.maxvel [JOINT_2]STEPGEN_MAXVEL
net z-pos-cmd <= joint.2.motor-pos-cmd
net z-vel-cmd <= joint.2.vel-cmd
net z-output <= hm2_5i25.0.stepgen.03.velocity-cmd
net z-pos-fb <= hm2_5i25.0.stepgen.03.position-fb
net z-pos-fb => joint.2.motor-pos-fb
net z-enable <= joint.2.amp-enable-out
net z-enable => hm2_5i25.0.stepgen.03.enable
net z-home-sw => joint.2.home-sw-in
net z-neg-limit => joint.2.neg-lim-sw-in
net z-pos-limit => joint.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
net axis-select-a halui.axis.a.select
net jog-a-pos halui.axis.a.plus
net jog-a-neg halui.axis.a.minus
net jog-a-analog halui.axis.a.analog
net a-is-homed halui.joint.3.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
loadrt hostmot2
# JOINT X
# JOINT Y1
# JOINT Y2
# JOINT Z
# SPINDLE S
- chadrat6458
21 Feb 2018 20:47 #106315
by chadrat6458
Replied by chadrat6458 on topic 2 steppers on one axis 5i25 - 7i76
Ok, I think I got my .hal and .ini files looking good. I will move my computer out to the shop tomorrow and try it out again. I don't have my home/limit switches on my machine. Will that be a problem? I thought I would get it moving then add the switches. This is not my first rodeo. I built another machine. I used the stepconf. It used a regular bob instead of the mesa cards. I have attached the current .hal and .ini. If you guys could look them over and tell me what you think. Thanks.
21 Feb 2018 20:51 #106316
Wow, CNCZombie, looks great.
If you have any troubles,
Try increasing these values in the ini file for each axis to say 5000.
And if you get following errors, this part is significant so increas them to 50% larger
For Chris's benefit, I think in master and the changes in it, these
Should be defined as
That would correctly align them with joints and avoid a lot of unnecessary editing when chopping and changing axes to ensure meaningful names (which I've done a couple of times).
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000And if you get following errors, this part is significant so increas them to 50% larger
STEPGEN_MAXACCEL = 937.50For Chris's benefit, I think in master and the changes in it, these
loadrt pid names=pid.x,pid.y,pid.z,pid.a,pid.sShould be defined as
loadrt pid names=pid.0,pid.1,pid.2,pid.3,pid.4That would correctly align them with joints and avoid a lot of unnecessary editing when chopping and changing axes to ensure meaningful names (which I've done a couple of times).
- DanMN
21 Feb 2018 20:53 #106317
by DanMN
# Joint 3
[JOINT_3]
TYPE = ANGULAR <--- Change to LINEAR
You can get started without limits -- you just have to zero the machine somewhere safe and not push it. I temporarily rigged several microswitches linked to e-stop while I was learning the details of homing sequences. It saved me a few end-of-travel collisions and frantic slapping at the e-stop button.
[JOINT_3]
- DanMN
21 Feb 2018 20:56 #106318
by DanMN
I wholeheartedly agree with your suggestions on the naming conventions. The cleaner you make it, the easier it is to slog through the 3000 edits you'll make before it's "perfect". I'm still about 1,864 edit away...
21 Feb 2018 20:58 #106319
Note my comments were directed at CNCzombie's config not yours.
The homing is different in master so make sure you drill down to the right documents
linuxcnc.org/docs/devel/html/config/ini-homing.html
Immediate homing is covered.
Set the homing sequence for Joints 1 and 3 to -1 and you are done!
When you do get your home switches in place, all you need to do to square the gantry is change the HOME_OFFSET
Also I found if you have a shared home/limit switch you need to move the axis off the limit switch with an offset otherwise you will get a limit error as soon as homing is complete (becasue the switch is enabled)
- Thank you received: 2181
21 Feb 2018 23:09 #106320
Replied by cmorley on topic 2 steppers on one axis 5i25 - 7i76
Sound good Rodw
22 Feb 2018 01:56 #106326
Sound good Rodw
Message sent
Time to create page: 0.160 seconds
