7i76e with 7i85S to control 9 steppers
  • cogzoid
  • Topic Author
  • New Member
  • New Member
8 years 2 weeks ago #118967 by cogzoid
Replied by cogzoid on topic 7i76e with 7i85S to control 9 steppers
Thanks for the help!
I've attached the output of the --readhmid command. It doesn't specify exactly the name of the uploaded firmware, but it's probably the 7i76e_7i76x1_7i85x1D.bit, (hence the 9 Steppers). I'm a little confused by the pinout designations since the numbers don't seem related to the 7i76e board.
As for the wiring, I've got 24V going to the field I/O, as well as pins 22/23 on TB3.
I've got 5V going to the P3 connector.
The only other wires are the Step and Dir pairs attached to TB1 Pin2-5 (X-axis) going to my Stepper Driver (also running off of 24V).
I've also attached the .hal and .ini files in case those might show some stupid error I made.
Thanks again... this stuff has quite a learning curve.
8 years 2 weeks ago #118968 by PCW
One fairly obvious thing is that there are very few step drives that will work with a 1 usec step pulse, you might try changing this to 5 usec
Also what type of drives do you have and how exactly are you wiring them?
8 years 2 weeks ago #118971 by rodw
Do your steppers have holding torque (eg locked) when the system is powered up? They should be. The stepper enable signal is actually a disable signal so if you connected the 7i76e EN+ and EN- signals to your stepper drivers, you have probably disabled your steppers. If so just unplug the EN+ and EN- wires from your drivers. I got caught with this when I moved from an Arduino to LCNC.
  • cogzoid
  • Topic Author
  • New Member
  • New Member
8 years 2 weeks ago #118979 by cogzoid
I'll try extending the Step and Direction Pulses, but I thought for sure I'd still be able to see them on the oscilloscope... I had also assumed that the default values would be close.
As for the stepper motor and drivers, they're the one part of the whole system that I have a decent grasp on. I had learned my lesson with the Enable pins pretty early in the process while trying to use Enable as an e-stop solution. The stepper is definitely locked up when it's supposed to be now.
The drivers works great for me in other situations, and the motor is a nema17 stepper just for testing on the bench.
Thanks for all the help, I'll try again tomorrow morning and report back.
  • cogzoid
  • Topic Author
  • New Member
  • New Member
8 years 2 weeks ago #119009 by cogzoid
I edited the .ini to have 5000 nanoseconds for the pulses and still didn't get any action. Attached are some pictures of how it's all wired up. I double checked after the photos and found Dir+ and Dir- wires to have been swapped, but still no signals.
I'm a bit confused about the need for the 5V to P3, but I checked with and without that hooked up. Either way I see no change in any behaviors.
Should I try re-flashing with a firmware version without the 7i85?
I'm open to any other suggestions on things to check.
8 years 2 weeks ago #119010 by PCW
Another odd thing in the hal/ini files:
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 5000000
Normally you would use a 1 ms servo thread not 5 ms so this becomes a problem with the default watchdog timeout:
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
Time to create page: 0.392 seconds
