Mesa 7i96 and LinuxCNC 2.8 PnCConf
8 years 3 months ago #114125 by andypugh
cmorley wrote: One problem with reading the runtime pins is that only tells you about _what is_ rather then _what can be_.
I think that the output lists the software modes available, so it is possible to conceive of the wizard loading and unloading the driver with a different process data mode each time.
This will not capture the hardware data modes, but you could reasonably expect the integrator to have configured that to suit their purposes.
8 years 3 months ago #115329 by ikkuh
PCW wrote: Yes, that is a RTAI kernel and RTAI verison of linuxcnc, it wont work with the 7I96
Took me a few weeks and a lot of swearing and reinstalling on different machines but now I know why I got the segmentation fault.
The error disappears when you sudo or run the mesaflash command as root.
8 years 3 months ago #115330 by PCW
You don't need sudo for Ethernet card access, what you do need is the latest
mesaflash (using sudo may just give the broken mesaflash version rights to corrupt memory it doesn't own)
I think this needs to be built from source _AND_ don't build master...
Checkout 3.3 before building, master does not have the 7I96 support
8 years 3 months ago #115331 by andypugh
PCW wrote: I think this needs to be built from source _AND_ don't build master...
Does that need fixing?
8 years 3 months ago #115333 by PCW
I dont know whats involved to get the latest mesaflash 3.3 changes merged into mesaflash master. Whether there even needs to be a development version of something so basic is also an open question
8 years 2 months ago - 8 years 2 months ago #115424 by ikkuh
PCW wrote: You don't need sudo for Ethernet card access, what you do need is the latest
I have two mesaflashes now, one from the repositories and one I build from the source at github.
The repo one:
ton@LinuxCNC-MESA:~$ mesaflash Mesaflash version 3.3.0~pre (built on Jun 28 2017 04:15:24 with libpci 3.1.9) Configuration and diagnostic tool for Mesa Electronics PCI(E)/ETH/EPP/USB boards (C) 2013-2015 Michael Geszkiewicz (contact: micges@wp.pl) (C) Mesa Electronics Try 'mesaflash --help' for more information
The one I build from github.com/micges/mesaflash
ton@LinuxCNC-MESA:~$ mesaflash/mesaflash Mesaflash version 3.3.0~pre (built on Aug 1 2018 19:07:16 with libpci 3.1.9) Configuration and diagnostic tool for Mesa Electronics PCI(E)/ETH/EPP/USB boards (C) 2013-2015 Michael Geszkiewicz (contact: micges@wp.pl) (C) Mesa Electronics Try 'mesaflash --help' for more information
Both mesaflash bins give me the segmentation fault.
I can not find the version you keep referring to. Where is this magical mesaflash hidden?
Btw: I am using the master-rt repo as I want 2.8 pre.
btw2: When I check the repositories there is just one mesaflash:
This change is not coming from a source that supports changelogs. Failed to fetch the changelog for mesaflash URI was: http://linuxcnc.org/dists/wheezy/base/binary-i386/mesaflash_3.3.0~pre0+dfsg-0_i386.changelog
Last edit: 8 years 2 months ago by ikkuh.
Time to create page: 0.468 seconds
