Mesa 7i96 and LinuxCNC 2.8 PnCConf
8 years 2 months ago #115425 by PCW
github.com/micges/mesaflash
As I mentioned, you must checkout 3.3 _not_ mesaflash master
This has nothing to do with the LinuxCNC version
You can select the branch with a button on the left side of the file listing on
GitHub
3.3 has Latest commit 5dc2dd1 on Jun 9
8 years 2 months ago #115428 by ikkuh
PCW wrote: github.com/micges/mesaflash
(that was not really clear to me. I read it to say that the latest version was available through the repos)
Ok, it works now. Good to see that the transformers are really ssr's.
7 years 11 months ago #119949 by snugglylovemuffin
How are you managing your endstops? I modified a 7i76 wizard file for my machine but my endstops aren't showing that they're tripping.
7 years 11 months ago #119953 by PCW
7I96 inputs 0..11 map directly to GPIO hal pins 000..011
Have you tried using halshow to check the inputs and verify that your home and or limit switches work as expected?
I would always do this before proceeding
7 years 11 months ago #119996 by snugglylovemuffin
My switches are normally closed w/ 24v going to the input on the TB3 header.
I have my HAL file, I'm just not sure if this is the proper way to write that the pins are NC for this board, as using other examples has proved fruitless.
7 years 11 months ago #120000 by tommylight
in_not
should be
in-not
Time to create page: 0.376 seconds
