Mesa 7i96 and LinuxCNC 2.8 PnCConf
6 years 2 months ago #180215 by PCW
what is the input common connected to?
Sounds more like a wiring error of some kind
(missing common connection?)
6 years 2 months ago #180221 by Aldenflorio
The common is connected to the V-
6 years 2 months ago #180226 by PCW
is V- connected to frame ground?
It really sounds like some kind of wiring error
6 years 2 months ago - 6 years 2 months ago #180227 by Aldenflorio
No v- isn’t. It goes from v+ to limit switch, other wire from limit switch to input on Mesa. Then com is v-
Last edit: 6 years 2 months ago by Aldenflorio.
6 years 2 months ago #180229 by PCW
My guess would be that you have a large AC (maybe HF)
voltage from V- to frame ground.
6 years 2 months ago - 6 years 2 months ago #180230 by Aldenflorio
I’m not sure. I’m going to make a larger control box and see if that helps. Things are a bit close. But is the wiring right with what I said?
Time to create page: 0.152 seconds
