Mesa 7i96 and LinuxCNC 2.8 PnCConf
8 years 3 months ago - 8 years 3 months ago #113908 by PCW
Replied by PCW on topic Mesa 7i96 and LinuxCNC 2.8 PnCConf
I think readhmid is really not what you want
Probably it would be more useful to list the available pins and parameters
with:
halcmd load hostmot2
halcmd load hm2_%interface
halcmd show all hm2 > allpinsandparams
The GPIO stuff is less necessary with 2.8 (and when supported the 7I96 inputs will become InM's which are no longer GPIO )
2.8 also supports the GPIO aliases so things like stepgen pin polarity
are referenced to the stepgen number, not GPIO pins, so are portable between config files.
Last edit: 8 years 3 months ago by PCW.
8 years 3 months ago - 8 years 3 months ago #113911 by cmorley
Replied by cmorley on topic Mesa 7i96 and LinuxCNC 2.8 PnCConf
One problem with reading the runtime pins is that only tells you about _what is_ rather then _what can be_.
Pncconf is for configuration so it needs to know _what can be_
Also the user really needs to know what the components physical pin number is.
In the beginning the XML file (which are converted readhmid files) told you what it could be and where it was at. - not so true now.
It seems I need info from the hardware about what it can do (based on the components) and a masking template to filter what the physical card limits are.
This mask could possibly map components to physical pins too - I think.
But the mask would have to be made for every card.
more thought needed...
Chris M
Last edit: 8 years 3 months ago by cmorley.
8 years 3 months ago #113915 by PCW
The run time pins/parameter do tell you what can be for a given firmware (if you dont limit the number of module instances in the driver config line)
The metadata about a particular card is constant so at some point should probably go into the IDROM, but could be a separate file per card for now
It would be nice to have the physical pin mapping but its not necessarily a 1-1 mapping with GPIO so as long as the manual for things like the 7I96 state the normal pinout the configuration utility really need only deal with module numbers
(and these are available in the pin/parameter listings)
8 years 3 months ago #113916 by cmorley
Well for instance if the card uses mux encoders you lose two encoders for each instance you turn off. You can't know that from runtime pins. Also from run time pins
you can't tell what components on the card can be turned off to reveal GPIO or not.
It doesn't tell you if the encoder is slow speed or high speed.
It doesn't tell you about modes...
It tells you 'based on how you just loaded me this is what you can configure'
metadata about the card on the card would be great. readhmid used to be enough for most situations but not so anymore.
Physical mapping of pins is a pretty big deal - fairly constant source of questions and surely user stress.. looking up info and mapping from manual is an error prone pain - not to mention linuxcnc doesn't supply Mesacard manuals so it's something else they must download. In fact I recently added a pic of the 7i76/7i77, in pncconf to help with that.
It's an interesting problem :)
Chris M
8 years 3 months ago #113919 by PCW
Muxed encoders are enabled 1 by 1 in the driver command line just like regular encoders
Not sure what you mean by low and high speed encoders (there are MPG encoders but those have different pin names)
By modes do you mean sserial modes? these can be probed with mesaflash:
mesaflash --device 7i76e --addr 10.10.10.10 --sserial
SSLBP port 0:
SSLBP Version: 1.43
SSLBP Channels: 3
SSLBP Baud Rate: 2500000
sserial device at channel 0: 7I76 GPIO (unit 0x12345678)
SwRevision = 14
HwRevision = 1
NVBaudRate = 2.5Mb
NVUnitNumber = 0x12345678
NVWatchDogTimeout = 50ms
SOFTWARE MODE IO_Spin [index 00]
SOFTWARE MODE IO_Ana_Spin [index 01]
SOFTWARE MODE IO_Enc_Ana_Spin_FV [index 02]
8 years 3 months ago #113924 by cmorley
I didn't know that about mux encoders.
Yes thats what I meant by encoders. are all MPG encoder named similarly on sserial cards?
Maybe I should knock together a proof of concept of reading runtime pins to see what is possible ... when I get some time :)
Thanks Peter
Time to create page: 0.173 seconds
