7i76e: MPG and Analog inputs with pncconf?
- Thank you received: 2181
12 Jan 2019 10:05 #124022
Replied by cmorley on topic 7i76e: MPG and Analog inputs with pncconf?
I confirmed the error in pncconf and just pushed a fix - it will take a bit of time for it to cycle through - unless you are compiling source code.
Thanks for the information.
Chris M
Chris M
The following user(s) said Thank You: trilobyte
- trilobyte
- Thank you received: 5
12 Jan 2019 10:44 - 12 Jan 2019 10:46 #124024
by trilobyte
Replied by trilobyte on topic 7i76e: MPG and Analog inputs with pncconf?
@cmorley: Tnx! I'll try it tomorrow.
@rodw: tnx for the code. i use two mpg and 4 potentiometers and a joystick with 4 tact switches.
at the moment im searching for a solution to connect the potentiometer to the jog speed.
this is my control panel:
peter
ps: a picture of the machine (schaublin 125cnc)
peter
Last edit: 12 Jan 2019 10:46 by trilobyte.
- Thank you received: 4149
12 Jan 2019 11:57 #124025
Replied by rodw on topic 7i76e: MPG and Analog inputs with pncconf?
We don't change jog speed with linuxcnc. We change the jog scale which sets how far you move per MPG click. eg. 1mm, 0.1mm, 0.01mm. Therefore, we need to set specific values with a switch or some other discrete input.
I didn't create the system I described. I just followed the example in the docs. linuxcnc.org/docs/html/examples/mpg.html
Personally, I think the potentiometer is a poor choice and suggest you replace it with a binary coded switch (or a multi pole rotary switch but it will use more inputs).
If you do persist with your potentiometer, I would have a look at the lincurve component, it should let you to map to an appropriate scale value as the voltage exceeds a specific voltage threshold but I have not used it.
- Mike_Eitel
- Thank you received: 183
12 Jan 2019 12:58 #124030
by Mike_Eitel
Replied by Mike_Eitel on topic 7i76e: MPG and Analog inputs with pncconf?
Hi
You have an example in the config i've send you in file mpg.hal.
Mike
Mike
- trilobyte
12 Jan 2019 13:00 #124031
by trilobyte
- trilobyte
12 Jan 2019 17:43 #124036
by trilobyte
i'd like adjust the speed of continous jogging not jog with a given step with.
is this possible with a potentiometer via analog in?
12 Jan 2019 21:40 #124045
There are .ini file variables used by the axis gui under the [DISPLAY] section to set the jog parameters. Your modified GUI needs to work with these or use an alternative method from .ini file variables to configure the GUI.
DEFAULT_LINEAR_VELOCITY sets the default jog speed.
For hardware, have a look at the halui component as it has a number of pins dealing with jogging which I understand are designed for hardware control.
However, if you have the MPG dials, I found you don't use continuous jogging as you'll just use the MPG with a scale of 1mm.
12 Jan 2019 21:42 #124046
This pin might do what you want
halui.jog−speed
halui.jog−speed
- phillc54
- Thank you received: 2100
12 Jan 2019 23:47 #124055
by phillc54
Replied by phillc54 on topic 7i76e: MPG and Analog inputs with pncconf?
You can access that slider from python via a .axisrc file in your home directory or by a file pointed to by USER_COMMAND_FILE in the [DISPLAY] section of your ini file.
Defaults are:
lower value = 0.06
upper value = 1.0
resolution = 0.02
To change some/all of these: (upper value should not be > 1)
To read the current value:
To set a new value:
You can also define a function that is called every time Axis updates itself:
Cheers, Phill.
Defaults are:
lower value = 0.06
upper value = 1.0
resolution = 0.02
root_window.tk.call('.pane.top.jogspeed.s','configure','-from','0.01','to','1.0','-resolution','.010')To read the current value:
value = float(root_window.tk.call('.pane.top.jogspeed.s','get'))
print 'value =', valueTo set a new value:
value = 0.75
root_window.tk.call('.pane.top.jogspeed.s','set',value)You can also define a function that is called every time Axis updates itself:
def user_live_update():
print float(root_window.tk.call('.pane.top.jogspeed.s','get'))Cheers, Phill.
- trilobyte
13 Jan 2019 09:20 #124064
by trilobyte
@cmorley: it works now!
i made a working setup with the fixed pncconf. the mpgs for x and z are working, i can set the step width via two inputs.
i also have now the joystick wired to 4 inputs. pncconf made a setup with a fixed value for jog speed:
"net jog-speed halui.axis.jog-speed"
"sets jog-speed 100.000000"
this jog function is different to the arrow keys on the keyboard.
that's not what I expected, but it is no problem.
the question is: can i set this value für jog-speed with the analog input?
@phillc54: tnx for this explanation. maybe i can use this function to move the slider to the same value as the jog-speed has
peter
peter
Time to create page: 0.335 seconds
