Stuck configuring 5i25 to run G540
6 years 4 months ago #172957 by naja452
Replied by naja452 on topic Stuck configuring 5i25 to run G540
cmorley wrote: can you post the INI file too please
Already attached to the first post.
6 years 4 months ago #172958 by Aciera
Replied by Aciera on topic Stuck configuring 5i25 to run G540
I'm not %100 sure I have the signals set up correctly, but I do have *an* axis on each Stepgen, so it should be moving even if the axis assignment is wrong
I meant more on the physical wiring side of things that is the step and direction signals coming from the mesa card going to the drives.
6 years 4 months ago #172959 by naja452
Yes, my test is to literally move the parallel cable from the mesa to the parallel port, boot up my old linuxcnc config, and jog it around. I close linuxcnc, move the cable to the mesa, reboot the computer, start the 6i25 config, and get what I'm getting now.
6 years 4 months ago #172961 by Aciera
I see, then it seems that there is something amiss with the 6i25 config. Unfortunately I'm not familiar with this mesa board so can't offer much in the way of support for that.
6 years 4 months ago #172972 by tommylight
Replied by tommylight on topic Stuck configuring 5i25 to run G540
Upload the correct files, please.
Uploaded file = cnc.hal
ini entry = Platform_5i25.hal
6 years 4 months ago - 6 years 3 months ago #172992 by naja452
tommylight wrote: Upload the correct files, please.
I wasn't thinking when I saved the files with a different name while pulling them off the CNC PC.
I tried uploading them with the correct names, but the uploader added a date to the filename.
Rest assured, the ini and Hal I uploaded go together.
Last edit: 6 years 3 months ago by naja452.
Time to create page: 0.273 seconds
