Stuck configuring 5i25 to run G540
6 years 3 months ago #173912 by PCW
Replied by PCW on topic Stuck configuring 5i25 to run G540
Checking the loaded output voltage would probably tell
P2 uses a different bus chip but it may use the same 4V (not sure)
If the G540 only outputs 3.3V signals you could set the I/O tolerance for
3.3V and then the bus interface chips are powered by 5V
(unfortunately the G540 manual has no output signal specs)
6 years 3 months ago - 6 years 3 months ago #173913 by naja452
Replied by naja452 on topic Stuck configuring 5i25 to run G540
Looks like there's a PI5C PCI bus chip for each port, fingers crossed.
EDIT: you beat me to it.
Last edit: 6 years 3 months ago by naja452.
6 years 3 months ago #173915 by naja452
PCW wrote: If the G540 only outputs 3.3V signals you could set the I/O tolerance for
Are you able to elaborate on this? What do you mean by "set the I/O tolerance", is this HW, SW, what device is it on etc.
I guess I don't fully follow what action you're proposing.
6 years 3 months ago - 6 years 3 months ago #173916 by naja452
Scratch that, I found the W3 jumper on the 5i25 that does what you suggested, I'll try that.
EDIT: I just checked the G540 Rev8 manual, looks like the spec sheet says input is 3.3-5v.
Fingers crossed!
6 years 3 months ago #173917 by naja452
Holy crap it works.
6 years 3 months ago - 6 years 3 months ago #173921 by PCW
Note: The G540 manual does not say what the output levels are
I would check that the G540 is not outputting 5V levels
Last edit: 6 years 3 months ago by PCW.
Time to create page: 0.276 seconds
