Stuck configuring 5i25 to run G540
6 years 4 months ago #172950 by Aciera
Replied by Aciera on topic Stuck configuring 5i25 to run G540
Are the motors energized? i.e. can you turn the shafts by hand or not?
Have you connected the step/dir signals correctly?
6 years 4 months ago #172952 by cmorley
Replied by cmorley on topic Stuck configuring 5i25 to run G540
I notice you said you used 5i25x2 in pncconf which is not possible.
Did you mean G540x2? details like this can be very important.
Chris
6 years 4 months ago - 6 years 4 months ago #172953 by naja452
Replied by naja452 on topic Stuck configuring 5i25 to run G540
PCW wrote: GPIO16 is plain GPIO bit that connects to P3 DB25 pin 13
its always available in a G540x2 configuration
(since it has no alternate function in that configuration)
I do see that GPIO16 is connected to parallel pin 13, but it's the only switch not working. And if you check the halhmid dump I attached, it's the only GPIO OF 13-16 (DB 10-13) that says "None" and doesn't work. Does the "NONE" indicate that no function is set in that bitfile? It just seemed like an odd correlation.
Last edit: 6 years 4 months ago by naja452.
6 years 4 months ago - 6 years 4 months ago #172954 by naja452
Aciera wrote: Are the motors energized? i.e. can you turn the shafts by hand or not?
Yes, the motor drivers are on and they have detent. I'm not %100 sure I have the signals set up correctly, but I do have *an* axis on each Stepgen, so it should be moving even if the axis assignment is wrong. Right? I do have my Hal attached at the top.
6 years 4 months ago #172955 by naja452
cmorley wrote: I notice you said you used 5i25x2 in pncconf which is not possible.
Chris
Yes, I meant g540x2, that was a typo. Thanks :)
6 years 4 months ago #172956 by cmorley
can you post the INI file too please
Time to create page: 0.230 seconds
