Huanyang VFD and Mesa 7i76e stuck at 6000 rpm
6 years 3 months ago #175338 by PCW
It sounds like the drive runs at 6000 RPM for 0V input
if so the lincurve values are wrong since you want a
Y value (output) of 0 at a commanded RPM of 6000
Also if you have a output scale of 26000 and a maxoutput of 24000
you can never get full output (these should both be left at 24000)
6 years 3 months ago - 6 years 3 months ago #175340 by Stran_ge
the thing is at m3 s1 where it shouldnt be turning i measure 0.03v and get perfect 6000 rpm
at m3 s6000 i get 2.3 v and 10300 rpm and at m3 s7000 i get 2.7 volt and 11000 rpm
i already changed that output scale back to 24000 but it didnt change anything
Last edit: 6 years 3 months ago by Stran_ge.
6 years 3 months ago #175341 by PCW
Right, so your linscale values are wrong,
Y should be 0 when X is 6000, you have that backwards
6 years 3 months ago #175343 by Stran_ge
so it should be this way:
# ---auto rpm: 1-6000 = 6000 / 24000 max setp lincurve.0.x-val-00 0 setp lincurve.0.y-val-00 0 setp lincurve.0.x-val-01 6000 setp lincurve.0.y-val-01 0 setp lincurve.0.x-val-02 6000 setp lincurve.0.y-val-02 6000 setp lincurve.0.x-val-03 24000 setp lincurve.0.y-val-03 24000
6 years 3 months ago - 6 years 3 months ago #175344 by PCW
Point 02 is wrong and will cause you to get about 2.5V with a 6000 RPM command instead of 0V
Do you get 24000 RPM at 10V?
Last edit: 6 years 3 months ago by PCW.
6 years 3 months ago - 6 years 3 months ago #175345 by Stran_ge
the maximum is 23xxx rpm at 9.1 volt
Time to create page: 0.069 seconds
