[SOLVED] Mesa 7i80HD-16: startup errors
- travis036
- Thank you received: 32
12 Dec 2020 09:06 - 13 Dec 2020 09:32 #191715
by travis036
[SOLVED] Mesa 7i80HD-16: startup errors was created by travis036
just testing my 7i80HD-16, yet i get errors (attached: linuxcnc.report.txt) right from startup. if i remove (comment out) the offending line, it just finds another error... and so on.
Thanks in advance for any help
~Travis
~Travis
Last edit: 13 Dec 2020 09:32 by travis036.
- BeagleBrainz
- Visitor
12 Dec 2020 09:32 #191716
by BeagleBrainz
Replied by BeagleBrainz on topic Mesa 7i80HD-16: startup errors
Have you tried changing the prefix from hm2_7i80hd.0. to hm2_7i80.0. ?
As the pins seem to being reported with the prefix hm2_7i80.0 not hm2_7i80hd.0
- travis036
12 Dec 2020 09:36 #191717
by travis036
Replied by travis036 on topic Mesa 7i80HD-16: startup errors
i have not tried that (pretty new to Mesa cards). i will try it a bit later, when i get back out there, thanks!
~Travis
~Travis
- kavindu1
12 Dec 2020 10:13 #191721
by kavindu1
Replied by kavindu1 on topic Mesa 7i80HD-16: startup errors
i also had a same err with startup on my 7i80 hd
- travis036
12 Dec 2020 15:50 #191728
by travis036
changed all "hm2_7i80hd" to "hm2_7i80"
now a new set of errors (attached report). when i got an error from the stepgen associated with the charge_pump, i removed it to see if it would help, but then i got the same error for the stepgen 00. fortunately, i haven't connected this to my machine yet.
~Travis
~Travis
- Thank you received: 4915
12 Dec 2020 16:04 #191729
Replied by PCW on topic Mesa 7i80HD-16: startup errors
It appears that the configuration you have loaded in the FPGA card has no
stepgens present
stepgens present
- travis036
12 Dec 2020 16:14 #191730
by travis036
12 Dec 2020 16:30 #191732
Right but that does not mean you have the correct firmware installed in the 7I80
What does:
mesaflash --device 7i80hd --readhmid
report?
What does:
report?
- travis036
12 Dec 2020 16:31 #191733
by travis036
i think i assumed that the pncconf flashed the FPGA... how do i flash the FPGA card?
~Travis
~Travis
12 Dec 2020 16:43 #191735
with mesaflash
Time to create page: 0.108 seconds
