[SOLVED] Mesa 7i80HD-16: startup errors
  • travis036
  • travis036's Avatar Topic Author
  • Elite Member
  • Elite Member
12 Dec 2020 09:06 - 13 Dec 2020 09:32 #191715 by travis036
[SOLVED] Mesa 7i80HD-16: startup errors was created by travis036
just testing my 7i80HD-16, yet i get errors (attached: linuxcnc.report.txt) right from startup. if i remove (comment out) the offending line, it just finds another error... and so on.
Thanks in advance for any help :)
~Travis
Last edit: 13 Dec 2020 09:32 by travis036.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
12 Dec 2020 09:32 #191716 by BeagleBrainz
Replied by BeagleBrainz on topic Mesa 7i80HD-16: startup errors
Have you tried changing the prefix from hm2_7i80hd.0. to hm2_7i80.0. ?
As the pins seem to being reported with the prefix hm2_7i80.0 not hm2_7i80hd.0
  • travis036
  • Elite Member
  • Elite Member
12 Dec 2020 09:36 #191717 by travis036
Replied by travis036 on topic Mesa 7i80HD-16: startup errors
i have not tried that (pretty new to Mesa cards). i will try it a bit later, when i get back out there, thanks!
~Travis
12 Dec 2020 10:13 #191721 by kavindu1
Replied by kavindu1 on topic Mesa 7i80HD-16: startup errors
i also had a same err with startup on my 7i80 hd
  • travis036
  • Elite Member
  • Elite Member
12 Dec 2020 15:50 #191728 by travis036
changed all "hm2_7i80hd" to "hm2_7i80"
now a new set of errors (attached report). when i got an error from the stepgen associated with the charge_pump, i removed it to see if it would help, but then i got the same error for the stepgen 00. fortunately, i haven't connected this to my machine yet. ;)
~Travis
12 Dec 2020 16:04 #191729 by PCW
Replied by PCW on topic Mesa 7i80HD-16: startup errors
It appears that the configuration you have loaded in the FPGA card has no
stepgens present
  • travis036
  • Elite Member
  • Elite Member
12 Dec 2020 16:14 #191730 by travis036
this is what i am using...
~Travis
12 Dec 2020 16:30 #191732 by PCW
Right but that does not mean you have the correct firmware installed in the 7I80
What does:
mesaflash --device 7i80hd --readhmid
report?
  • travis036
  • Elite Member
  • Elite Member
12 Dec 2020 16:31 #191733 by travis036
i think i assumed that the pncconf flashed the FPGA... how do i flash the FPGA card?
~Travis
12 Dec 2020 16:43 #191735 by PCW
with mesaflash
Time to create page: 0.940 seconds
