7i96 pncconf issue?
5 years 8 months ago #198194 by PCW
Replied by PCW on topic 7i96 pncconf issue?
OK if the icon moves that means that you are getting commanded positions
from LinuxCNC and valid feedback positions from the 7I96, so the most likely issue
is wiring or timing or an electrical fault
5 years 8 months ago #198195 by Bearfood
Replied by Bearfood on topic 7i96 pncconf issue?
On the TB6600's I see a green LED on the X which works and then green + blue on the other 4. There's no documentation that identifies a blue light as far as I can tell.
5 years 8 months ago #198196 by PCW
You might try lengthening the step pulse to say 10 usec (10000 ns)
I think some of the packaged TB6600 drives need pretty
long step lengths
5 years 8 months ago #198198 by Bearfood
Tried that and no change.
I switched the wires from the7i96 to y1 driver over to the x driver and I can control the y motor off the x driver. I also can switch the wires from the motors to the x driver and can control the motors. I'm really starting to think that 4 out of 5 of my brand new drivers are the problem and that darn blue light means something bad.
5 years 8 months ago #198534 by Bearfood
As a follow up here. I contacted the seller of the TB6600 and explained that 4 out of 5 TB6600's were not working and showing a green plus a blue light and asked what the blue light was indicating. In response they said they'd ship me 4 new stepper drivers so I guess that means that the Blue light is not good.
Thanks for looking at this!
5 years 8 months ago #198535 by tommylight
Replied by tommylight on topic 7i96 pncconf issue?
Blue light is OK on those drives, it goes on and off when stepping during normal work.
If they are the ones with a really small Toshiba chip with 109 at the end of the name, they are pretty nice and not easy to kill.
You should take the time and check them properly, before requesting RMA.
Time to create page: 0.370 seconds
