7i96 pncconf issue?
5 years 8 months ago - 5 years 8 months ago #198877 by PCW
Replied by PCW on topic 7i96 pncconf issue?
If only step4/dir4 works and step/dir 0,1,2,3 don't work and they are set up identically in hal
that suggests that the driver chips that connect to step/dir outputs 0,1,2,3 have been
damaged.
You can verify that outputs work by measuring the step+ and step-
and dir+ and dir- outputs when linuxCNC is running and after you have exited LinuxCNC.
With no load, these outputs should be very close to 5V in one state and close to 0V in the other
Last edit: 5 years 8 months ago by PCW.
5 years 8 months ago #198879 by Bearfood
Replied by Bearfood on topic 7i96 pncconf issue?
Is there something I have to do to configure the card with Mesaflash or something?
5 years 8 months ago #198881 by PCW
This would not be a firmware issue
5 years 8 months ago #198885 by Bearfood
Okay, my multimeter stopped working a few months back so I now have one on order. I should really have one anyways.
Thanks for all the help! I really appreciate it!
I'm not sure I understood your earlier comment on DIR- and STEP- to 7196 ground. Do you have a diagram I could refer to?
5 years 8 months ago #198993 by Bearfood
The Multimeter didn't take long to get here. Here are the results.
Linuxcnc on, card powered
Step1 =4.38v
Step2 = 4.38v
Step3 = 4.46v
Step4 = 4.47v
Step5 = 5.1v
Lunuxcnc off but card powered
Step1 = 4.38v
Step2 = 4.38v
Step3 4.46v
Step4 = 4.47v
Step5 = 3.9v
So all Axis are the same except Step5 which is the working step. Not sure where to go from here.
5 years 8 months ago #199002 by PCW
Can you check the stepN+ and stepN- to ground?
Time to create page: 0.210 seconds
