TTL (PWM) Laser head and Mesa 7i76
4 years 10 months ago #228292 by RoberCNC
Sorry, the P2 wanted to say, I got confused, P3 (the DB25) I have it busy with the 7i76.
I have asked if the pins are the same to prepare the wire.
4 years 10 months ago #228294 by PCW
On P2, HDR Pin 1 connects to DB25 Pin 1, but the other pins are
not in order because of the way DB25 and HDR26 pins are numbered.
You don't need a special cable however just a flat cable with IDC
connectors (one HDR26 , one DB25) on each end.
(Mesa can supply these)
The following user(s) said Thank You: RoberCNC
4 years 10 months ago #228297 by RoberCNC
Ok, I'll wait to do it then with the pins you tell me based on the custom firmware.
4 years 9 months ago - 4 years 9 months ago #233424 by RoberCNC
Hi PCW, is there news of the custom firmware?
Last edit: 4 years 9 months ago by RoberCNC.
4 years 9 months ago #233480 by PCW
Here is a 5i25 config with PWM on P2 (it also adds 2 more step/dir outputs)
File Name: 5i25_7i76_pwmd.zip
File Size:97.45 KB
4 years 9 months ago #233488 by RoberCNC
Very grateful PCW!!!
I understand that the pinout of the Chinese BB is like the one it has.
I see that in the zip comes a .vhd file, what is it for?
The .bit I imagine is to flash the 5i25 again like I did when I bought it.
Thank you very much, really, how much I want to try it
Time to create page: 0.075 seconds
