TTL (PWM) Laser head and Mesa 7i76
3 years 1 month ago #281653 by swepeter
Thank you so much!
Found the thread: forum.linuxcnc.org/10-advanced-configura...m67-and-m68?start=10
If someone stumbles on this some time.
I did end up ordering the amazon card.
3 years 1 month ago - 3 years 1 month ago #281655 by swepeter
Will this be correct for me also:
#LASER
# loadrt pwmgen output_type=0
addf pwmgen.make-pulses base-thread
setp pwmgen.0.enable TRUE
net analogout motion.analog-out-00 => pwmgen.0.value
net laserpwm pwmgen.0.pwm => parport.0.pin-01-out
but with  parport.0.pin-02-out
Last edit: 3 years 1 month ago by swepeter.
3 years 1 month ago - 3 years 1 month ago #281661 by PCW
Since the 7I96 has a hardware PWM generator, the setup would be different
You also likely need to enable the  laser with a 7I96 SSR or other output
that is controlled  by  Linuxcnc and disabled by a watchdog bite
setp   hm2_7i96.0.pwmgen.00.output-type 1
setp   hm2_7i96.0.pwmgen.00.scale 100
setp    hm2_7i96.0..pwmgen.pwm_frequency 5000
setp hm2_7i96.0..pwmgen.00.enable true
Note that the enable  should be probably be netted to a MACHINE_ON type
signal, rather than just forced on with a setp statement.
net analogout motion.analog-out-00 => hm2_7i96.0.pwmgen.00.value
Last edit: 3 years 1 month ago by PCW. Reason: clarify
3 years 1 month ago - 3 years 1 month ago #281872 by swepeter
Hi Again
I just received my card and want to double check anything before connecting it.
Am I thinking right here:
photos.app.goo.gl/y17RPj5UASp3UYWJ8
12V in to power the card and then the PWM port next to it to connect to the laser?
thanks again
3 years 1 month ago - 3 years 1 month ago #281873 by PCW
No, that's the 0-10V analog output
The (5V) PWM output would be on P2 (XCLK)
3 years 4 weeks ago #282077 by swepeter
Something really strange is going on.i have a PS for 5 V that powers the raspberry pi and the mesa card and I have a PS for 12V that I have connected to the BOB to. when I connect the cable between the mesa and the BOB there is something that starts beeping and the 5V PS only gives out 1V and the Pi dont start of cause. What can cause this?
photos.app.goo.gl/TdpXLu7YHBWZhK1X7
Time to create page: 0.370 seconds
