TTL (PWM) Laser head and Mesa 7i76
4 years 8 months ago #234140 by RoberCNC
Hi PCW.
Just flashed the firmware and verified, it seems to be everything ok.
Now I have some doubts, the first of all I run the Pncconf Wizard and I don´t know what I must to choose on the Mesa Card 0 step at Board Name selection tab (5i25, 5i25-Internal Data, etc...) neither at firmware selector, the 7i76_pwmd doesn´t appears as such.
In the other hand I supposed that with this new firmware I have to remap and reconfig all the pinouts I have, isn´t it?
Thank you very much as allways.
Rober
4 years 8 months ago - 4 years 8 months ago #234146 by PCW
pncconf is not going to help at this point.
I would use your existing 7I76 configuration (if you have one)
as none of the 7I76 connections have changed, only a added PWM
generator and a couple of step generators have been added to P2
so the only changes needed to your existing hal file are adding
the laser PWM support.
Last edit: 4 years 8 months ago by PCW.
4 years 8 months ago #234149 by RoberCNC
Hummmm I don´t know if I would be able to handle this, yes I have operating configuration, I had rather, now it doesn´t run :)
How can I map or know the chinese BB pins and the BB itselfs denomination?
It smells as a new challenge and learning for me.
4 years 8 months ago - 4 years 8 months ago #234167 by PCW
The firmware did not change any 7I76 connections
so your original hal/ini files should work
The PWM output is on DB25 pin 8 (mesaflash should show this)
4 years 8 months ago #234178 by RoberCNC
Well now I am unable to run the configuration that was operational, I launch the application and I get the error screen with a bunch of lines that pin do not exist.
If the firmware doesn't change anything (I thought so too) what could be the cause?
4 years 8 months ago #234181 by PCW
What pins are missing and what does:
mesaflash --device 5i25 --readhmid
report?
Time to create page: 0.317 seconds
