Gerber 408 retrofit
3 years 2 months ago #278382 by Gerber408
Replied by Gerber408 on topic Gerber 408 retrofit
I am preparing for a Gerber 408 retrofit. The machine was given to me (can't beat FREE). It does work with original software.
I will probably go ahead and replace original servo motors with steppers. Anyone with experience on this have a recommendation for size of motor. Looks like NEMA23/24  would fit, but I'm worried they won't have enough torque. Would love to hear your experience.
3 years 2 months ago #278386 by fdarling
Replied by fdarling on topic Gerber 408 retrofit
Replacing the brushed DC servos with steppers will reduce the maximum speed of the machine and lower the accuracy/reliability. The original motors have an unusual frame size, neither NEMA (23, 34, etc.) nor metric servo (60mm, 80mm, etc.) standards. You'll not only have to fabricate adapter plates, but also replace some other parts such as the timing belt pulleys since they were meant for the odd-sized 11mm shaft that Gerber put on their motors.
I have yet to see a Gerber a bad servo motor. I have looked into getting the encoders replaced should they go bad (haven't seen that), and I have replaced the brushes on the motors (preventative maintenance). The "Achilles heel" of Gerber Sabre is that their Y axis leadscrews (or at least their plastic leadnuts) wear out. I am looking into a ballscrew replacement solution, I know of another person that had success with this.
Regarding controlling the original motors, if you want to retrofit with LinuxCNC you can keep the amplifiers and use the encoder feedback to control them in "torque mode" from LinuxCNC. This is what I recommend as it gives you the best performance, and you don't have to replace anything. As I have posted, I am actively working on a drop-in motherboard for people such as yourself.
However, if you want to control the servos from simplistic CNC controls that only deal with open loop step/direction, then motor power voltage permitting you can use a Gecko G320X:
www.geckodrive.com/product/g320x-digital-servo-drive/
The downside is that you will have to tune the PID settings using a screwdriver with the Gecko drive's potentiometers, and can only tell what is going on using the LEDs and audible oscillation. Very different from being able to use halscope!
You'll also want to convert the encoder's differential signal to single ended as close to the Gecko drive as possible so that you maintain noise immunity, using something like Mesa's ENCY:
store.mesanet.com/index.php?route=produc...oduct&product_id=304
3 years 2 months ago #278389 by SkyMoCo
Replied by SkyMoCo on topic Gerber 408 retrofit
Will you also provide the LinuxCNC config that goes along with the board when you get it done. A "plug and play" solution.
3 years 2 months ago #278390 by fdarling
Yes, not only will I provide the LinuxCNC configuration, but I will provide a completely pre-configured LinuxCNC compatible PC with the kit. I use HP Compaq Elite 8200/8300 models, as they have been proven to have good real-time performance.
3 years 2 months ago #278398 by Gerber408
I also may be interested in this solution. How can I contact you? I can't seem to find a DM function on this board.
3 years 2 months ago #278400 by fdarling
I cannot find any way to direct message either... Maybe they removed it due to spam problems? At any rate, you can contact me by emailing my forum username at gmail.
Time to create page: 0.103 seconds
