You can use halscope, but it does require having differential output encoders and a Mesa board with encoder inputs, and very good knowledge of wiring/powering stuff as Gecko has its own power for encoders and so does Mesa, making sure those are at the same 0/zero/gnd/potential is absolutely important, and using the +5V only from Gecko to power encoders.The downside is that you will have to tune the PID settings using a screwdriver with the Gecko drive's potentiometers, and can only tell what is going on using the LEDs and audible oscillation. Very different from being able to use halscope!
You are correct that you can still use HALscope with the Gecko drives, however if you already have the hardware that can deal with interfacing the encoders to LinuxCNC, then why aren't you just using that setup permanently? It's much easier to tune the PID from the "calibration" dialog within LinuxCNC, rather than use the potentiometers on the Gecko drive.
So not easy/comfortable/possible always.
I Am using it, well not me but a client i retrofitted the machines for:
So, if I understand correctly, the step on time, step space, direction hold, direction space should be doubled as a starting point?
I found this info online and believe that it may be accurate:
for the X, and Y axis which should allow me to calculate my scaling.
servo encoder counts per revolution: 4000
Servo teeth: 28
Lead screw teeth: 70
Pitch: 20mm
counts per mm: 500
