Index homing Mesa 7i96s
21 Nov 2024 04:13 - 21 Nov 2024 04:14 #314965 by GeckoWorks
Replied by GeckoWorks on topic Index homing Mesa 7i96s
Index (Z pulse) Homing on Delta Servos
I hope it's OK I add a bit more info to this thread specifically in regards to Delta servos. I bought some used ones quite cheaply. To me, it's a better deal than the no name ones as the Deltas have much better documentation and a proper tuning/setup software. (Actually, I am almost sure at least some of Automation Direct's servo series are rebranded Deltas, too.)
Earlier in the thread PCW mentioned a potential speed issue where the Mesa input may not be fast enough to read the index signal unless the index is somehow slowed down. But perhaps the following tidbit I found will help with this (it's from a different controller manufacturer describing  how to wire up index homing  ):
For proper operation it is necessary to rearrange DELTA drives default settings. Number of pulses of drives’ output encoder – should be shifted to a lower value to ensure adequate INDEX signal pulse length. P1-46 parameter set by default on 2500 pulses – set on 500 pulses per rev or less. This change has no influence on servo drives working precision because their internal procedures work on encoder full accuracy anyway.
PCW also suggested on email that I slow down the homing speed (home to regular limit/home switch can be faster, but then slow down the home to index/Z pulse after that). So, maybe a combination of lowering the pulse value for the encoder and slowing down the home speed a bit is the ticket.
Again, if you have B3s, A2s or perhaps A3s(?) you can try making the servo drives handle the homing routine.
Last edit: 21 Nov 2024 04:14 by GeckoWorks.
21 Nov 2024 13:19 #314979 by GeckoWorks
Yes, this firmware should work (though would need to be modified to add the fourth axis index input)
Great, thanks.
4th is in the future, no need for it for a while:)
07 Feb 2025 10:24 #320903 by GeckoWorks
Hi Peter,
My boards arrived a while back and now, finding some time to dive into this - my first ever - Lcnc install. To recap, I have a 7i96s and the new 7i84u but I am looking to use the servos index pulse for homing. Now, the question is, is there a FW which has both the daughterboard plus the index pulse functionality included? Or would I have to somehow add the 7i84u manually and how would I go about that?
07 Feb 2025 16:43 - 09 Jul 2026 14:38 #320923 by PCW
Replied by PCW on topic Index homing Mesa 7i96s
If by daughtercard you mean the 7I84U, any firmware with a sserial port will do.
(basically any 7I96S firmware that does not use the serial expansion for modbus etc)
Last edit: 09 Jul 2026 14:38 by PCW.
The following user(s) said Thank You: GeckoWorks
08 Feb 2025 02:38 #320953 by GeckoWorks
(basically and 7I96S firmware that does not use the serial expansion for modbus etc)
Yep, the 7I84U would be the daughtercard to the 7I96s.
OK, I will try making it work with the FW you linked above.
As an aside, I have it downloaded already but have a bit of an issue making it show up in MesaCT even though I think it's in the right folder, but that's probably just me still overseeing something - will read some more posts and/or try mesaflash in the terminal.
14 Feb 2025 10:15 #321530 by GeckoWorks
Sorry for being daft, but I reflashed the board with the FW you uploaded here. So far so good, but just checking - does this FW have the serial port feature, so I can connect to the 7I84U without having do download anything else for any of the two boards?
09 Jul 2026 09:23 - 09 Jul 2026 09:24 #347627 by GeckoWorks
Hi again Peter,
I didn't get far last time we talked about this - but the machine is finally coming apart next week for your cards and LCNC upgrade.
But I read this whole thread again and early on, I think you mentioned that the encoder input on the 7I96s can also be split up to work for Z-index homing?
I don't need a spindle encoder and the MPG can go on normal pins too, right?
So, does this mean I can get three index pulses onto a 7I96s in a faster, more proper encoder way and not have to use the isolated IOs?
Ideally, I would need four as I also have a rotary incoming. But if four true encoder inputs is not possible, there's an easy workaround: I can use Delta B3 on the rotary and they can home to index internally in the drive with just a single normal DI and DO.
Last edit: 09 Jul 2026 09:24 by GeckoWorks.
09 Jul 2026 14:51 #347632 by PCW
Yes, it's possible to have 7I96S firmware that wires the 3 encoder inputs as step/dir index signals.
09 Jul 2026 22:06 #347644 by PCW
I should note that existing firmware 7i96sd_esdid.bin has that setup:
Encoder A = Stepgen 0 Index
Encoder B = Stepgen 1 Index
Encoder I =  Stepgen 2 Index
10 Jul 2026 02:46 - 10 Jul 2026 02:56 #347652 by GeckoWorks
Thanks so much Peter,
I will make a note to grab 7i96sd_esdid.bin.
If anyone else comes across this in the future and wants to do index homing and have Delta servos I am now almost sure the Delta B3 drivers can home internally. (B2s can not).
You would wire the switch/sensor to the drive, not to the Mesa and then set up speed parameters and such in the drive. For homing, you'd then send a command to the drive to home (one DO) and once homing was done, the drive would report back to the Mesa (one DI) that the homing was done.
However, I have B2 drives for XYZ and one B3 coming in for a rotary build hence why I needed to do index homing via the Mesa.
Last edit: 10 Jul 2026 02:56 by GeckoWorks.
Time to create page: 0.157 seconds
