Index homing Mesa 7i96s
29 May 2024 21:31 #301779 by PCW
Replied by PCW on topic Index homing Mesa 7i96s
1. Is your hardware using inmux (needs external mux) or inm (direct inputs)
(the pins and module id sections are different for these)
2. The inm or inmux width tag must be the number of inm or inmux inputs
(0xb  or 11 on a 7I96S)
30 May 2024 02:52 #301805 by besriworld
Replied by besriworld on topic Index homing Mesa 7i96s
Yes, the board has multiplexers. . I have to use inmuх.
Before adding the shared encoder index pulse . The board was working. I will try to compile the firmware with last line included.
(InMWidth0Tag, x"00", NullTag, x"00", NullAddr&PadT, x"00", x"00", x"0x00000b")
Yes, this line is missing in the examples I looked at .
There are 24 inputs pin on the board .On mesa the board uses 6 pins (5 outputs and 1 input)
For x"0x00000b" I have to put the number 18 .
thank you very much for the help
30 May 2024 03:06 #301807 by PCW
The inmux has a different module ID section entry:
package PIN_SV8_7I36x2D_72 is
    constant ModuleID : ModuleIDType :=(
        (HM2DPLLTag,        x"00",    ClockLowTag,    x"01",    HM2DPLLBaseRateAddr&PadT,    HM2DPLLNumRegs,            x"00",    HM2DPLLMPBitMask),
        (WatchDogTag,        x"00",    ClockLowTag,    x"01",    WatchDogTimeAddr&PadT,        WatchDogNumRegs,        x"00",    WatchDogMPBitMask),
        (IOPortTag,            x"00",    ClockLowTag,    x"03",    PortAddr&PadT,                IOPortNumRegs,            x"00",    IOPortMPBitMask),
        (InMuxTag,            x"00",    ClockLowTag,    x"02",    InMuxControlAddr&PadT,        InMuxNumRegs,            x"00",    InmuxMPBitMask),
        (MuxedQcountTag,    MQCRev,    ClockLowTag,    x"08",    MuxedQcounterAddr&PadT,        MuxedQCounterNumRegs,    x"00",    MuxedQCounterMPBitMask),
        (MuxedQCountSelTag,    x"00",    ClockLowTag,    x"01",    NullAddr&PadT,                x"00",                    x"00",    x"00000000"),
        (PWMTag,            x"01",    ClockHighTag,    x"08",    PWMValAddr&PadT,            PWMNumRegs,                x"00",    PWMMPBitMask),
          (SSerialTag,        x"00",  ClockLowTag,    x"01",  SSerialCommandAddr&PadT,    SSerialNumRegs,         x"10",  SSerialMPBitMask),
        (LEDTag,            x"00",    ClockLowTag,    x"01",    LEDAddr&PadT,                LEDNumRegs,                x"00",    LEDMPBitMask),
        (NullTag,            x"00",    NullTag,        x"00",    NullAddr&PadT,                x"00",                    x"00",    x"00000000"),
        (InMuxWidth0Tag,    x"00",    NullTag,        x"00",    NullAddr&PadT,                x"00",                    x"00",    x"00000020"), -- hide this tag here until we find a better way
        (InMuxWidth1Tag,    x"00",    NullTag,        x"00",    NullAddr&PadT,                x"00",                    x"00",    x"00000020") -- hide this tag here until we find a better way
Note that this example uses 2 inmux interfaces both with a width of 32 (0x20)
30 May 2024 04:50 #301814 by besriworld
Hi, it doesn't want to compile. After 5-10 minutes the calculated bit file is missing. Can you try to compile it ? Thanks!
File Name: PIN_5ABOBx...Copy.rar
File Size:3 KB
30 May 2024 04:59 #301815 by PCW
I see two errors with a quick look:
1:
        (InMuxTag,     x"00",   ClockLowTag,   x"00",   InMuxControlAddr&PadT,     InMuxNumRegs,        x"00",   InmuxMPBitMask),
(you are specifying 0 inmux modules, this should be x"01")
2:
        IOPortTag & x"17" & NullTag & NullPin,              -- I/O 33    PIN 25       free
        -- 26 HDR    -- IDC 26
        IOPortTag & x"06" & NullTag & NullPin,                -- I/O 34    PIN 1            just GPIO_6
        IOPortTag & x"07" & NullTag & NullPin,                -- I/O 35   PIN 2            just GPIO_7
        IOPortTag & x"04" & NullTag & NullPin,           -- I/O 36   PIN 3           just GPIO_4
        IOPortTag & x"05" & NullTag & NullPin,                -- I/O 37    PIN 4            just GPIO_5
        IOPortTag & x"02" & NullTag & NullPin,              -- I/O 38    PIN 5           just GPIO_2
        IOPortTag & x"03" & NullTag & NullPin,                -- I/O 39    PIN 6            just GPIO_3
        IOPortTag & x"00" & NullTag & NullPin,             -- I/O 40    PIN 7            just GPIO_0
        IOPortTag & x"01" & NullTag & NullPin,                -- I/O 41    PIN 8            just GPIO_1
        IOPortTag & x"08" & NullTag & NullPin,              -- I/O 42    PIN 9            just GPIO_8
        IOPortTag & x"09" & NullTag & NullPin,             -- I/O 43    PIN 11        just GPIO_9
        IOPortTag & x"10" & NullTag & NullPin,              -- I/O 44    PIN 13       just GPIO_10
        IOPortTag & x"11" & NullTag & NullPin,             -- I/O 45    PIN 15        just GPIO_11
        IOPortTag & x"12" & NullTag & NullPin,              -- I/O 46    PIN 17        just GPIO_12
        IOPortTag & x"13" & NullTag & NullPin,                -- I/O 47    PIN 19        just GPIO_13
        IOPortTag & x"14" & NullTag & NullPin,              -- I/O 48    PIN 21          just GPIO_14
        IOPortTag & x"15" & NullTag & NullPin,             -- I/O 49    PIN 23        just GPIO_15
        IOPortTag & x"16" & NullTag & NullPin,           -- I/O 50    PIN 25        just GPIO_16
The second column numbers need to all be x"00" (you cannot renumber GPIO)
30 May 2024 05:06 #301817 by PCW
Also you may simply be running out of room...
(Usually the will be a reported as an error in the mapping phase)
30 May 2024 09:40 - 30 May 2024 10:38 #301832 by besriworld
Yes, I tried but again the bit file doesn't compile.
For testing, I removed 2 step generators and there is no change. I am attaching the log file from ISE Design Suite 14.7
I apologize for taking up so much of your time.Thank you very much for the help !
File Name: log.txt
File Size:286 KB
PS. I did an experiment. I removed the changes for the shared index. I left only the new changes on the multiplexer inputs. Again the bit file is not created.
Last edit: 30 May 2024 10:38 by besriworld.
30 May 2024 11:25 - 30 May 2024 11:44 #301837 by besriworld
New update .I can manually create a bit file . But it comes with several warning messages and one error
WARNING:Bitgen:284 - Setting next_config_register_write to Disable will cause
   the next_config_addr, next_config_new_mode, and next_config_boot_mode options
   to be ignored and their respective register writes to be excluded from the
   bitstream.
INFO:Bitgen:341 - This design is using one or more 9K Block RAMs (RAMB8BWER).
   9K Block RAM initialization data, both user defined and default, requires a
   special bit stream format.  For more information, please reference Xilinx
   Answer Record 39999.
WARNING:PhysDesignRules:367 - The signal
   <ahostmot2/makesserialmod.makesserials[0].asserial/processor/StackRam/Mram_RA
   M1_RAMD_D1_O> is incomplete. The signal does not drive any load pins in the
   design.
   M2_RAMD_D1_O> is incomplete. The signal does not drive any load pins in the
   design.
INFO:PhysDesignRules:1861 - To achieve optimal frequency synthesis performance
   with the CLKFX and CLKFX180 outputs of the DCM comp ClockMult1, consult the
   device Data Sheet.
   with the CLKFX and CLKFX180 outputs of the DCM comp ClockMult2, consult the
   device Data Sheet.
WARNING:PhysDesignRules:2410 - This design is using one or more 9K Block RAMs
   (RAMB8BWER).  9K Block RAM initialization data, both user defined and
   default, may be incorrect and should not be used.  For more information,
   please reference Xilinx Answer Record 39999.
FATAL_ERROR:Bitstream:stanbsbitfile.c:3408:1.57 - Incorrect number of bits in
   bitstream (18) for FDRI write.   For technical support on this issue, please
   visit www.xilinx.com/support.
File Name: log2.txt
File Size:2 KB
PS. I loaded the file into the board it seems to work.  The multiplexer pins are visible in the HAL
If the board works, the error is not important?
Last edit: 30 May 2024 11:44 by besriworld.
30 May 2024 13:19 #301840 by PCW
Yeah the log file was OK (though it looked like you did not select the option to make the bit file)
It looks like the bit file error is related to running ISE on Windows 10 or 11 but not selecting compatibility mode
(I always use Linux now so I've never seen that error)
30 May 2024 13:28 - 30 May 2024 15:24 #301841 by besriworld
Thank you very much! Yes, the OS is Windows 10.
Last edit: 30 May 2024 15:24 by besriworld.
Time to create page: 0.312 seconds
