LC 2.9.4 Configuration - Unsupported Locale
24 Jun 2025 21:53 #330845 by electrosteam
LC 2.9.4 Configuration - Unsupported Locale was created by electrosteam
RPi 4B 4GB, Mesa 7i96, 3-axis vertical mill.
Mill runs LC 2.9.2 with Axis or Gmoccapy just fine.
First install of fresh L2.9.4, using PnCConfig and selecting Gmoccapy.
Get the error message of "Unsupported locale" when selecting [Forward] on the X-axis set-up page.
Used the LC 2.9.4 menu-config to set locale.
I am in Sydney, so tried "en_AU.UTF-8 UTF-8", a couple of other obvious ones, and "All".
Still getting the error.
Tried selecting [Back], but still get error.
Cancelled out and started again, but selected Axis.
Still getting error.
But realized that errors are generated at the step calculation stage also.
Thought this was cleared when I hand entered the correct value.
John.
24 Jun 2025 22:00 #330846 by unknown
Replied by unknown on topic LC 2.9.4 Configuration - Unsupported Locale
forum.linuxcnc.org/9-installing-linuxcnc...only?start=10#320959
Just about ecevrything to do with the Rpi images can be found in this thread, there is also an index to that thread here
forum.linuxcnc.org/38-general-linuxcnc-q...official-images-only
26 Jun 2025 04:55 #330887 by electrosteam
Replied by electrosteam on topic LC 2.9.4 Configuration - Unsupported Locale
Thanks for the link.
Looking at locale.
LC 2.9.2:
Menu-config has an extra step for setting locale.
When en_AU is selected, a pop-up shows C.UTF and en_AU.UTF, adds a warning about setting locale, then Ok to accept en_Au.
Then locales are generated before returning to the menu-config dialog.
LC 2.9.4
The extra step is not present.
The return to the dialog is too quick to see if a locale is generated.
Research on Debian locale seems to require editing of files.
I will start reviewing this tomorrow (and re-read the reference link).
27 Jun 2025 02:00 #330920 by electrosteam
1) Reviewed 2009 Debian documentation which suggested $ dpkg-reconfigure locales.
Along the way found instruction to use the Spacebar to select a locale from the list offered.
This is missing from the menu-config instructions.
When locale is selected with Spacebar, the missing step in previous post appears.
Tried it the sequence, and failed to set locale.
2) Reviewed a June 2023 suggestion from www.server-world, suggesting $ localectl.
Ran the sequence and failed.
3) Debian Wiki from 2022, section labelled "Manually".
$ sudo nano /etc/locale.gen
Long list of locales, all commented out.
Uncomment en_AU.UTF-8 UTF-8
$ sudo locale-gen
Locales are generated.
$ locale -a
C
C.utf8
POSIX
en_AU.utf-8
LogOut/In.
$ locale
Full suite of en_AU.
SO SUCCESS.
Ran PnCconf again.
SUCCESS.
I don't know if the LogOut/In step is listed in the official LC 2.9.4 instructions.
If so, I missed it.
Prospect for cutting metal with LC 2.9.4 looking good.
John.
The following user(s) said Thank You: sk_linuxcnc
28 Jul 2025 15:24 #332497 by sk_linuxcnc
Replied by sk_linuxcnc on topic LC 2.9.4 Configuration - Unsupported Locale
Thank you for posting about the other possible fixes along with their sources.
For me, just pressing the spacebar to select the locale worked fine.
(And yes i was foolishly stuck with this locale issue too, because i didnt know about the "space-bar" to actually mark the required locale in $ sudo menu-config > locale )
Time to create page: 0.234 seconds
