Call external subroutine not working in recent versions of LCNC
shipmodeller wrote: Booting up and getting ready... will send you results
1: Homed unit
2: Pressed First button ... halui.mdi-command-00 == false
3: Went to mdi tab - pressed button -> halui.mdi-command-00 == false
4: entered o<toolchange3> call in mdi window. Toolchange executed correctly
5: Pressed First Button -> halui.mdi-command-00 = true and toolchange worked
OK, so this so far sounds as though the subroutine call does work as long as halui.mdi-command-00 is actually driven true, and that the problem appears to be in the classic-ladder interlock.
What does the Classic Ladder system do?
What happens if you miss it out? ie change this in the postgui hal file
6: Loaded "Checkers.ngc"
7: Pressed first buttin -> halui.mdi-command-00 == false.. No tool change
8: Mdi panel - tried to do o<toolchange3> call -> failed ..error message failed to find Otoolchange3 before EOF
Let us skip over that last error for a moment, that sounds different...
- shipmodeller
- Thank you received: 3
When I returned the file to the original state, and # out the added line.. LinuxCNC came up
shipmodeller wrote: How can I say this gently? .... it hosed the system, linuxCNC won't come up
Ah, yes. I made a silly error, the net command needs a signal
It might be useful to also halmeter motion.in-position and halui.mode.is-mdi as those seem to be the inputs to the classic ladder.
(and you still haven't explained what the CL logic is internally)
- shipmodeller
Of course, nothing changed with the Load file then no button. Please note that after the load of a file, I can still Zero XY with the Buttons. I just can't call in a toolchange.
I don't understand what you meant by "didn't explain CL" I don't know what CL means, and I don't see where you asked for that... but I might have missed that.
So the major problem now is the File load disables both mdi and button firing of toolchange.
And I just now have upgraded to the latest patch .. 4559
shipmodeller wrote: Of course, nothing changed with the Load file then no button.
I don't think that there is any "of course" about that.
Do you definitely see halui.mdi-command-00 go true with nothing else happening?
CL == Classic Ladder. You have some ladder logic in your original HAL file, but haven't told us what it does.
Does nothing at all happen, or do you get the error that you showed earlier?
- shipmodeller
I'm sorry about the CL issue, I didn't write that portion.. I modified the toolchange code, but the HAL stuff was copied, and copied.. I'm retired, been a coder of 53 years.. but now, just want to use the stuff... this used to work in previous versions before the 2.8 update. So, still feel strongly like something is changing ownership rights.. but I don't know how to drill down to find this, or how to setup any logs useful for this group to solve this.
If you think something in the CL is hosing this, then just tell me what file it is that sets that up, and I'll push it .. otherwise, I need to close up shop for night.. been a very long day
