Call external subroutine not working in recent versions of LCNC
7 years 8 months ago #126206 by shipmodeller
Pretty sure I supplied those files before .. and remember.. what you "simulated" did not seem to address the issue.. but I thank you for your effort. I have put up my ini file, and the hal files for you to look at. I don't know what is going on, I suspect rights issues... I can load those files via midi all day long, UNTIL I load up another file, then I lose it. So, the main question I will pose again, should I push this as a defect, and if so, what documentation should I upload? Very big thanks...
Right now, I am getting around all this by loading the toolchange program manually for each tool I need. PIB.. :-)
File Name: custom.hal
File Size:1 KB
File Name: custom_postgui.hal
File Size:2 KB
File Name: my-mill_20...2-11.hal
File Size:6 KB
File Name: my-mill_20...2-11.ini
File Size:3 KB
7 years 8 months ago #126218 by andypugh
Does the "metal touchoff" work properly?
One difference I do see is that there is a classicladder interlock on the toolchange3 button, that seems to be checking mode.is-mdi
What happens if you switch to the MDI tab, _don't_ run an MDI command and then press the button?
7 years 8 months ago #126219 by shipmodeller
Well, the metal touchoff .. was working in the prior release.. yes. ( 0 added for offset.. ) So when I did wood, the .625 was added. When I did metal, nothing was added to touch zero.
So.. the number 1 issue as reflected in my original post is:
1: From boot, I can go tot he Midi panel and execute the o<xxx> call tool change without problem.
2: The button doesn't seem to work till i do that .
3: But, once I load a GCODE file into the system, the midi command won't find the toolchange file anymore and the button no longer functions.
7 years 8 months ago #126220 by andypugh
Can you do a quick test? Open a Halmeter and look at halui.mdi-command-00 and make sure that it does go "true" when you press the button in the scenario where you are seeing a problem?
7 years 8 months ago #126229 by shipmodeller
Booting up and getting ready... will send you results
7 years 8 months ago #126230 by shipmodeller
1: Homed unit
2: Pressed First button ... halui.mdi-command-00 == false
3: Went to mdi tab - pressed button -> halui.mdi-command-00 == false
4: entered o<toolchange3> call in mdi window. Toolchange executed correctly
5: Pressed First Button -> halui.mdi-command-00 = true and toolchange worked
6: Loaded "Checkers.ngc"
7: Pressed first buttin -> halui.mdi-command-00 == false.. No tool change
8: Mdi panel - tried to do o<toolchange3> call -> failed ..error message failed to find Otoolchange3 before EOF
