Gscreen - a GTK / Glade / Python based screen
In that case I would have expected a comma-separator to work. (and the fact that is doesn't sounds like a bug)newbynobi wrote: do you mean setting my computer to English locale?
Mine is De_de set to German.
- newbynobi
- Thank you received: 394
gmoccapy
now.
Should this be the final name?
Norbert
- Thank you received: 2181
I didn't program it. Never thought of it.
Actually the calculator widget doesn't either.
Though Gscreen, it's self has been programmed for locale but I have not tested it much.
I need a running bug / feature list - as I can't get to all this right away.
I'll try to remember to look into these.
newbynobi wrote: So, everything has been renamed to
gmoccapy
now.
Norbert
mmm G i'd like some MOCCA PY...
gmocca_py
g_mocca_py
It's your screen - call it as you like
I like the play on mocca pie
i was going to recommend you put all the image files in a folder so it is easier to copy them into another folder.
Chris M
andypugh wrote:
And I forget to pre-select so often that I am probably going to edit Axis on my lathe to have two separate buttons.cmorley wrote: AXIS uses touch-off and you pre-select whether its for origin setting or tool setting.
(Because if you get it wrong, the whole tool table ends up wrong)
Ya I thought that may be a problem so looks like we will do it with separate buttons on the tool page.
Chris M
karlkec wrote:
I think having it on the tool table page would work well. Include the ability to change tools from there too (tool index button). Could even highlight the row in the tool table matrix for the currently-loaded tool. When a tool is touched off the values in the tool table matrix should update. My thinking is that the tool table page would have everything necessary to set up all the tools in the changer.cmorley wrote: at the moment I know that tool setting to a common point is missing, I'm just not sure how best to do it.
I would like something more obvious.
I could have the tool setting buttons show up when the tool table is showing ....
Chris M
Karl
Ya that sounds pretty good
I could pop up a dialog that lets you move the highlight bar then press change tool.
This is very like run-at-line dialog.
I'm not sure how to handle tool offset selection.
Chris M
